Question about Samsung LE40R74BDX 40 in. LCD Television
My samsung series 6 650 LCD tv is crooked when it sits on the stand. How can I fix this problem?
SOURCE: samsung series 6 37" lcd tv No Picture
audio section
Posted on May 22, 2008
SOURCE: how to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
Posted on Feb 09, 2008
roety
  • 585 Answers
SOURCE: Heads are cut off on my LCD TV on a samsung 46
Hi my name is Eric,
I hope I can help you with your issue ,
 There are a few buttons on your remotes to push for size, on the TV remote P-size to full. fill or just, on a cable/satelitte box
# key is zoom (brighthouse) aspect/format to stretch , make sure you only have 1080i as the output resolution in cable box display settings.
unzoom it and you'll see the edges, thats all
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
Posted on Sep 09, 2009
  • 127 Answers
SOURCE: I have a Samsung Series 6-650 LCD TV (Model #
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Posted on Mar 02, 2010
  • 122 Answers
SOURCE: Samsung LCD TV series 5 240Vac, 50Hz will it work with 60Hz?
no only the voltage is critical.the only point is you have to select right counrty and tv sound and picture system on setup menu!
Posted on Jun 06, 2010
Samsung flat screen tv no picture sound only, I have checked all connections and remote still same problem.
The T con board is faulty. It is the board with flat ribbon cables going to the bottom of the screen. It is not hard to replace this board. You can get one from here:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Jan 01, 2016 | Samsung Televison & Video
Tip
Input Switching Issues with Harmony and Samsung TV's
The following 2008 Samsung TV’s have Anynet+:
LCD
All 9 Series LCD TVs (LNxxA950)
All 8 Series LCD TVs (LNxxA850, LNxxA860)
All 7 Series LCD TVs (LNxxA750)
Most of the 6 Series LCD TVs (LNxxA650, LNxxA630) excluding the 19” and 22” models
All of the 5 Series LCD TVs (LNxxA550, LNxxA540, LNxxA530)
Most of the 4 Series LCD TVs (LNxxA450) excluding the 19”, 22”, and 26” models
Plasma
All 7 Series Plasma TVs (PNxxA750, PNxxA760)
All 6 Series Plasma TVs (PNxxA650)
All 5 Series Plasma TVs (PNxxA550, PNxxA530)
Half of the 4 Series Plasma TVs (PNxxA450) excluding the 410 line (PNxxA410)
DLP
All 7 Series DLP TV’s (HLxxA750)
All 6 Series DLP TV’s (HLxxA650)
All 5 Series DLP TV’s (HLxxA510)
2007 Samsung TVs With Anynet+
The following 2007 Samsung TVs have Anynet+:
Note: Excluding all 26" models and below.
LCD
All 81F series (LN-Txx81F)
All 71F series (LN-Txx71F)
All 65F series (LN-Txx65F)
All 61F series (LN-Txx61F)
All 53H series (LN-Txx53H)
Plasma
FP-T5084
FP-T6374
HP-T4254
HP-T4264
HP-T5054
HP-T5064
DLP
All 89S series
HL-Txx89S
HL-T7288W
Information on Samsung TVs that support AnyNet has been refered to from: http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view.jsp?isARS=Y&SITE_ID=1&AT_ID=18104&ARS_ID=8514159
How To Disable Samsung Anynet+ so your Harmony Remote Control properly controls your devices. This mainly impacts Input Switching.
1) Press your Tools Button.
2) Scroll down to Anynet and press your Select Button.
3) Once on the Anynet screen, please press your Left/Right Button(s) to select the Off Setting on the Anynet+ (HDMI-CEC)
4) Scroll down to the Auto Turn Off and select No.
Once this is completed, please turn off your TV and all device and power them back on using the Harmony Remote. Also please test this in the Activities mode, if this does not work, please e-mail us back for further assistance.
on Feb 10, 2010 | Logitech Harmony 880 LCD Remote Control
Sit and Stand Double Stroller looks crooked in the back... How do I fix this?
Hi Jessica, it depends on where it is crooked, most times this can be fixed, but sometimes the whole geometry of the buggy is destroyed. It really is a case-to-case issue.
Nina
Jul 27, 2014 | Baby Gear
Volume bar stands at 200 every time i start my Samsung LCD
set the volume down extremely low power the tv down by plugging out and put on again should be then at set volume,the tv's now days have memory so it should start up at volume preset
Dec 21, 2013 | Samsung LN-S2651D 26 in. LCD Television
Samsung tv wont turn on stand by button just keeps
hi,
your lcd tv got to replace the ip board (power board) the capacitor has already exhusted.
Apr 19, 2010 | Samsung LE40M91B 40 in. LCD TV
I just purchased a JVC 47'' LCD just need to know how to remove the stand. I have it hanging on a Unti do not need the stand.
1. remove the 4 screws on the back of the TV (these are located in the deep holes above the stand)
2. after the screws are removed, the TV will lift from the stand.
The stands sits inside the TV. after the screws are removed the TV will still sit on the stand. you (and someone else) will need to lift it from the stand.
Nov 10, 2009 | JVC LT-47X788 47 in. LCD HDTV
Television tiliting forward on stand on 42LG3000
is the surface that the tv is sitting on flat and level? if you continue to have problems, take it back to the store where u made the purchase or call LG customer service. could just be a bad stand
Apr 06, 2009 | LG 42LG30 42 in. LCD HDTV
TV shutting off randomly
it looks like a faulty mains board. you need to upgrade the tv software with the latest update. if the tv is not accepting the upgrade then it can be a crook mains board.
hope it helps! please rate my comments :D
Mar 19, 2009 | Samsung LN32A550 32 in. LCD TV
How to remove the stand from samsung LCD TV
Feb 07, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Samsung LE40R74BDX 40 in. LCD Television Logo
1,360 people viewed this question
Henry  Thomas
Henry Thomas
