Question about Broan-NuTone N-8663RP Combination Light Fan Exhaust Fan
I installed a Nutone Bathroom Exaust fan/Light combo #8663RP at my home several years ago. It has worked fine until last week, when it started making a funny noise. I took out the motor/fan assembly and it looks like the fan blade is slightly loose on its shaft and scrapes against the motor mounting plate, slowing down the motor and, I'm sure, doing it no good. The motor sounds fine (no bearing noise) and when I hold it upside down, there is no problem, no scraping. There was a lot of dust and gunk inside the whole fan unit and there is insulation over the top of it, but the instructions say that it is suitable for use in insulated ceilings.Do I need an entire motor/fan assembly or can it be repaired short of that? thanks for your help
  • 706 Answers
Hello georod01,
Pretty simple problem and you have a few options.. first off.. If you take the fan/motor assembly out of the housing ( meaning : unplug the motor ... power off of course... and remove the sheetmetal screws that secure the mount that holds the fan/motor to the housing.....) You may have already done this... On some models, there is a set screw that secures the fan to the motor shaft.. you may be able to snug that up to stop the wobble... If the motor is OK and the fan is spinning but making contact with the housing.. It may not be centered in the housing so you may be able to better orient it..
If that fails to solve your problem, you can get a fan/motor assembly at home depot and either transfer it from the new bracket to the original ( if they are different).. or transfer just the fan blade onto the old motor... I think it costs about $8 - $12 for that and they are not usually easy to find but they do sell them...try the plumbing section...
As for suitability in an insulated area.. you should have no problems unless you put the wrong bulb size in the holder.. most of them have an over-temp cutoff sensor built in.. The fan motor is not much of a heat source... Hope that helps...
Posted on Jan 30, 2010
    Problem Solver:
  • 7 Answers
These complete units are very inexpensive...by the time you get the what if parts...you will be close to replacing the unit cost wise... plus you will have a clean new look on the grill and on the light lense...
Posted on Feb 27, 2010
I installed the Nutone vent fan light combo with night light and I want to put the fan and light (not night light) on one switch, and not use the night light at all, is this possible? Thank you.
yes there should be 3 wires coming from light one for light one for fan and one for night light just dont hook up night light wire should work fine tape or cape the wire you dont want to use. good luck
Aug 05, 2011 | Broan-NuTone N-8663RP Combination Light...
A Bryant 3 way independent rocker switch with red, black and white wires for 3 lights in bathroom one switch not working can i replace it with a Broan Nutone P66V three function control
397bfdd.jpgLeviton triple switch
fe442eb.jpgNutone P66V
Nutone looks like an ordinary three-switch combo being marketed as a bathroom 'fan switch.'
The screws on the device would tell the story.
Look at the Leviton screws:
The switch has dark-colored screw on one side >> the hot from breaker always connects to dark screws.
Other side of switch has 3 silver-colored screws, but these can be brass colored screws > the wires to fan light and heater connect to each of these screws.
Most likely the Nutone switch is identical to the Leviton
I say this because the descriptor on Amazon describes it as a 'fan' switch.
It's being marketed as a bathroom fan-light combo switch >>> so it looks like an ordinary three-combo switch
Oct 28, 2010 | Broan-NuTone P66V Fan Control Switch
I have a Nu-tone 8663 RP Combo fan and light. The unit has been a great unit for a good number of years. The fan is shot. Motor bearings I think. How can I get a replacement fan assy. ?
I just ordered a replacement fan motor for this same exhaust fan. I got it from here, http://www.electricmotorwarehouse.com/aosmith/nutone/nutone1.htm
It's this one,
1.2 amps, 115 volts 60hz
1550 RPM; Shaft 1/4" x 1"
Rotation = CCW
3.3" Diameter Motor
2 Mounting Studs Opposite Shaft End
Motor Case Length 1 15/16"
2-Prong 115 Volt plug
For Model 8663RP, 8673RP
8664RP (86933-000)
86933000, JA2B104N, JA2B104
can substitute 99080517
Part # 86933
$43.95
It's on the first page, and the 8th motor on the page at the time of this post. Hope this helps!
Oct 20, 2010 | Broan-NuTone N-8663RP Combination Light...
Looking for repacement globe for bath room exaust fan
Hi there, What I would do without knowing what kind of exhaust fan you have is Google it online. Or, if you have the make, model number, etc., and take it down to your nearest home depot, lowe's, etc., or heating and supply company close to you. These are pretty common exhaust fans, so you should have no problem finding a replacement. Good Luck with this, and if you have an other problem regarding your fan, feel free to contact me and I'd be willing to help you out.  - Jim
May 20, 2010 | Broan-NuTone N-8663RP Combination Light...
How do I change the light bulb and/or night light for my NuTone bathroom Fan-Light Model 8663RP?
The whole cover/grill/globe pulls straight down to expose the bulbs. There are two heavy "V" springs, one opposite the other, that hold the grill to the fan box. You need to overcome the holding power of these two springs to pull the grill down. If necessary, you may want to run around the edge with a sharp knife in the event it was painted in place.
Mar 30, 2010 | Broan-NuTone N-8663RP Combination Light...
I need an exploded picturial view of the BROAN fan and light kit. Thanks
go to www.broan.com from there you can look up that fan/light combo and download the installation manual which will give you the exploded view.
Broan Bathroom Fan Care and Cleaning
heatman101
Jul 02, 2009 | Broan-NuTone N-8663RP Combination Light...
The Fan in my Nutone bathroom light/fan is not working...
It is really easy to change the motor yourself. It is about a 15 minute job. You just need to find your model number and then you can buy the complete motor assembly. https://www.centralvacuumstores.com/model_number_help.php
Mar 28, 2009 | Broan-NuTone N-8663RP Combination Light...
Broan-NuTone N-8663RP Combination Light Fan Exhaust Fan Logo
1,388 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
Craig Dupler
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
