Question about Kenmore Washing Machines
Need to change switch on washer serial #CR3248773, type III, Model #110-25842400. Can not get the top off to get to problem. Can you help?
    President:
  • 1,937 Answers
First, see the Sears PARTS site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.25842400
Next, see the following :
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=eec0c3d748908e30ea65cb552b05ae70
Some washers use End Caps on the console which pop off and reveal two screws which hold the console on.
Others don't have end caps so you'll have to slip a thin putty knife under the ends of the console to release the console.
Posted on Jan 31, 2010
My magtag washer leaks only when i am filling it
First you need to list the model number and possibly the serial number if you can find it in order for me to figure out what type of washer it is then i can help you. I will also need to know whether it is a top load or a front load. Thank You. You may need to re-ask the question with the model number and serial number or message me at etsi00257@hotmail.com because I am a certified appliance repairman and have repaired quite a few Maytag washers.
Mar 10, 2013 | Washing Machines
My washer is leaking when i fill it
First you need to list the model number and possibly the serial number if you can find it in order for me to figure out what type of washer it is then i can help you. I will also need to know whether it is a top load or a front load. Thank You. You may need to re-ask the question with the model number and serial number or email me at etsi00257@hotmail.com because i am a certified appliance repairman.
Washer wont drain
First you need to list the model number and possibly the serial number if you can find it in order for me to figure out what type of washer it is then i can help you. I will also need to know whether it is a top load or a front load. Thank You. You may need to re-ask the question with the model number and serial number.
I have a Kenmore 70 series model # 22702 serial CL3881209 type lll. It willnot spin all other functions work fine.
check the safety switch in the door,, you can jumper it to see if it fixes your problem, lemme know if you need more info
Jun 12, 2011 | Kenmore 22422 Top Load Washer
I have an whirlpool ultimate care II Imperial Series Model # LSN2000JQ2 Serial:CM2819491 Type: III That will fill but won't agitate. Is this something I can really fix on my own?
Could be a problem with the lid switch or motor coupling. Does it drain? Does it spin?
when its time to agitate or spin, do you hear the motor?
Lets start with the lid switch. open the lid and use a screw driver to push the switch down. pay attention to see if you hear it click. Try to run the unit with the screw driver holding down the switch.
Let me know what happens so I can further assist you.
Feb 20, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
There is a leak in the bottom of our washing machine
If the leak is from the front, you will need a pump. If in the rear check the water valve and the inlet hoses. Also if a lg leak check the hose from the pump to the drain grommet. They sometimes split.
Apr 07, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer won't spin
most likely just clutch ck for oil or water on it if oil most likely top seal gearcase is leaking ..remove agitator cap remove bolt in middle of agitator ..remove console screws remove clips under console holding cabinet on remove cabinet ..lean washer back remove pump then motor remove the 3 bolts holding gearcase in remove gearcase clutch is silver disk on top of gearcase with band inside ..band is actual clutch may try cleaning it but not hopeful about it being a permanet fix
Nov 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
