Question about Acer NSK8458AN Keyboard
Green keys on bilingual (EN FR) keyboard
Anything in French on my keyboard is in green but I cannot figure out how to access the green keys.
  • 5 more comments
  • janesy Mar 09, 2008
    I have an acer aspire 5320 notebook and the French keys on my keyboard is in green but I cannot figure out how to access the green keys.
  • Vista-junk Mar 12, 2008
    I was typing along in Mocrsoft Word and suddenly, by fluke, all the apostrphes and question marks are showing up as french characters- e's and u's with accents. I can't figure out how to get rid of them. It's only happening in Word.
  • Anonymous Apr 27, 2008
    What change is necessary to ensure that the white symbol appears when I type the symbol for at
    How do I move my keyboard response to the white symbol from the french?
  • silvert Mar 19, 2009
    The green keys correspond to another language, but I cannot figure out what the language is. Some of the text on the keys is French, but I have tried several language settings (two for Canadian French, France, Belgium) and none fit.
  • Harald Holczer
    Harald Holczer Dec 06, 2013
    Lindsay 195 Thank you thank you thank you! Harald
  • Harald Holczer
    Lindsay 195 Thank you, thank you, thank you
Finally I figured it out. Hold the shift control function keys at the same time. This will turn the green key function on and off.
Posted on Nov 19, 2009
  • 1 more comment
  • tipicosden Aug 20, 2011
    This is the answer....100% guaranteed. i just tried it and it worked. I had this LT for a year now and that's the 1st time I didn't need to reboot. Awesome...Dude, yer the man...Thanx...I know a lot of ppl who were tryna figure that out...a lot of ppl will be pleased because of you. Cheers !!!
  • Ilya Oct 17, 2011
    It turns only some keys into "green" mode on my laptop (Acer 5742-6406). Complete solution is to switch to a french keyboard layout (keyboard icon in the lower right corner)
  • TriLinks Jan 10, 2013
    did not work
Here is your solution, you have a bilingual keyboard language installed or two or more different languages installed and when you press left alt and left shift it cycles through them you can go into your keyboard settings and change the languages if you want this to stop happening or just press those keys a few times to get it back to normal....
PS: some french characters need you to press the right alt(or alt car) and the key... hope i helped now back to hacking wow actually how i figured this out... don't ask...
All Shall Bow Before Me For I Am Jesus!!!
Posted on Apr 28, 2008
  • Miz M Oct 24, 2011
    thank god! (not really but...) i finally got a right answer to my problem, only an hour later & after even more screwy things on the keyboard happened after trying others suggestions.U DA MAN!!! Thanks.
There is a little keyboard symbol on the right hand side of the taskbar. Click on it for language options. It's the fastest way to fix it, but to prevent accidentally switching the language option is probably inevitable, as there is a keyboard shortcut that is easily accidentally typed.
Posted on Apr 29, 2008
  • rainfall1 Aug 25, 2010
    Thank you so much .. that was soooo easy and it worked
  • 4 Answers
The solution is to press alt and than shift on the left side of the keyboard. This turns off the green keys and turns on the white keys.
Posted on Mar 24, 2010
The best solution so it shouldn't happen again ( unless you require the French#**# keys) is to go to go to start: type keyboard go to Dvorak keyboard & change other settings, keyboard & languages(at this point make a floating language bar that should show up on top right of screen.... Go to general set to en-can & find United States International ( they invented the typewriter ) move it to the top & delete the multi- canadian language , the French etc that way when you hit hot keys in error you go between canadian english & us int'l. Double check on your floating language bar
Posted on Dec 30, 2009
  • 46 Answers
You have spyware on your machine.. if you have a scanner scan it.. if not there are several free spyware scanner/removers.. Good luck
Posted on Mar 07, 2008
This is the second laptop I've owned where I've run into this problem. The first was an HP, this is an ACER. When I called HP tech support, no one there had any idea what I was talking about. I'm convinced they use typewriters.
Solution (fixes problem immediately and forever. Works on ACER {windows7}, might work for HP):
~Click on the keyboard icon on the taskbar (near the system tray, lower right hand corner of your screen).
~Select "Show the Language Bar"
~The language bar shows up in the upper right hand corner of the screen.
~Click the little down arrow/triangle (options)
~Click "Settings"
~Select the "Advanced Key Settings" tab.
~From the list, my problem was "Between Input Languages" had a "Key Sequence"
~**Use whatever key sequence shows up to undo whatever it was that happened**
~If this solved the problem, select the action and click "Change Key Sequence"
~Click the option for "Not Assigned"
~Click "OK"
~Click "Apply"
Hopefully you will never have this problem again. Having default keyboard shortcuts for features that 99.99% of users never use is idiotic. Having no one at tech support who can figure out what went wrong is even worse.
Posted on Jul 21, 2012
Forward slash on panasonic toughbook
It sounds like you have a ToughBook with a NON-US Keyboard or keyboard layout. The physical "SLASH" key is the last key on the bottom row above the SPACEBAR row.
It is the key on the FAR right side just to the left of the right-side
SHIFT key. Make sure in the taskbar that the EN sign is shown
(on the bottom right side of the screen next to the date/time.
If it is shown FR or ES then your keyboard is in French or Spanish.
You can try to use the ALT+SHIFT key combination to toggle
the FR or ES back to EN (English). If not, then you must
ADD the English keyboard in the Control Panel under
Regional Settings (Clock, Language and Region in Windows 7).
Under Keyboards Click "keyboard" then Click "add" then
choose English (United States), Keyboard then US (only).
That is it. Make sure you select US as "Default" and then you
won't have to go thru all this ever again.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989.
Apr 28, 2014 | Panasonic TOUGHBOOK CF-18 Tablet PC
On acer laptop how to use the green keys?
On my acer aspire 5551 it works if you press the ALT Car Button on the right site and the green key
Jun 25, 2010 | Acer NSK8458AN Keyboard
How do I turn on my green keys on my Acer Aspire One?
Not able to find a colour picture of the keyboard - But I suspect you mean the numbers that are on the following keys u,i,o,j,k,l,m
To gain access to these numbers you need to put the number lock "num lock" key on - to do that use the <FN key> together with the <F11 key> That will now change the keyboard so that numbers are displayed instead of the letters
Support site for Acer http://www.acer.co.uk/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3734&sp=page15e&ctx2.c2att1=17&miu10ekcond13.attN2B2F2EEF=3734&CountryISOCtxParam=UK&ctx1g.c2att92=122&ctx1.att21k=1&CRC=2980211862
Select your exact model and then got the document tab, to downlaod the user manual
IF there are other keys that are green on the keyboard - let me know and i can research more
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 01, 2010 | Acer NSK8458AN Keyboard
Green function key locked on acer laptop
Hey, I've just been having this problem. Try pressing CTRL + SHIFT + FN all at the same time. I found out that I had to press them once to turn on the green keys, and then press them twice more to turn it off. I hope that works for you.
Feb 12, 2010 | Acer Aspire 4530-5889 Notebook PC
My Dell keyboard is typing french symbols,how do I change it back to english
if you have windows XP follow these steps :-right click on Taskbar-Toolsbar-here check the language bar(should apear in your case french) -right click on the Fr(that apear)-settings -here you will see French keyboard-click Add and select EN-english -than OK and your keyboard should type english letters/
Dec 09, 2009 | Dell 0Y3740 Keyboard
How to activate 'green keys' on an Acer from Canada
press the left ctrl and right shift keys to toggle between french and english keyboards
Dec 07, 2009 | Acer Aspire 5315 Notebook
I need to know the keyboard shortcuts to access international accents, punctuation, and pronunciation characters as in French, German, Spanish, Scandanavian languages etc. Is there a printout available?
Foreign Characters 5.75 This program was developed to allow bilingual or multilingual computer users quick and easy access to the accented characters, letters or symbols that are unique to each of the 14 Western Ero languages but not displayed on English keyboards.... Details - Download
Oct 23, 2009 | Logitech 967437-0403 Keyboard
Bilingual keyboard
There is a small green Fn button near the start button you will have to use this with shift to use the green keys if you are in multi lingual mode, if you only use the laptop for french you can also change the regional settings for the keyboard to Just French and then they will work just by using shift.
Hope this helps FixYa,
Chris
May 19, 2009 | Acer Aspire One PC Notebook
Computer is locked in the green symbols of the keyboard
TO SHUT OFF the green keys, you need to disable the multiligual or French keyboard layouts. For Windows 7:
Click CONTROL PANEL
click CLOCK, LANGUAGE, AND REGION
under REGION AND LANGUAGE
click CHANGE KEYBOARDS... etc.
click KEYBOARDS AND LANGUAGES
.......for example, by clicking on a keyboard name (ie. US or and UNITED KINGDOM for example) and then clicking PROPERTIES to the rtight, you can see the actual key layout.......
On the list of installed languages, click anything multiligual or French, and then click REMOVE found on the right-hand column
click APPLY
click OK
Then you've removed the French.
Otherwise you have to click the LEFT ALT key and then the LEFT SHIFT key to swich back and forth between the green keys and the white keys.
Jan 04, 2008 | Acer Aspire 5500 5570-2609 Laptop
Stuck in French
hold down the Code key(blue/green) and press Keyboard, You might have to do it once or twice, All brothers have international keyboards. good Luck! Don
Apr 30, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Acer NSK8458AN Keyboard Logo
37,085 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
