Question about Toto Promenade, 1.6 GPF, Elongated Two-Piece Toilet, Cotton - CST424SFG
We have Toto 1.6 L fully enclosed toilet with a loose toilet seat. How do you get access to the bolts to tighten or replace them?
4 Suggested Answers
  • 54 Answers
SOURCE: loose Toto toilet seat
Lift up plastic caps located on ends of hindge behind seat. use flat screw driver and hold the nut under the outside toilet rim with your fingers or a pair of pliers. Do not over tighten or might crack the bowl.
Posted on Sep 14, 2009
Nomodo4u
  • 863 Answers
SOURCE: need to replace toilet seat but cant get at bottom
Use deep sockets and not a wrench. Place flat head screwdriver on the top screw for resistance, while tightening or loosening the bolt at bottom with the deep socket and wrench.
Posted on Oct 10, 2010
  • 17 Answers
SOURCE: I have a Toto toilet and am trying to replace the
hi there
this type of seat has rubber gromits that squeeze up when you tighten the screw.if it wont tighten up the gromit may have failed and would need to be replaced.
good luck
Posted on Dec 18, 2010
New toto promenade toilet tank lean forward and plumber put putty tape where it has contact with tile and bottom of toilet base.. Also alot of play in elongated toilet seat? please help
Tighten seat nuts, they are underneath, you will have pop open the tabs covering seat screw to hold it. If the toilet was level before tile saws installed call tilers back. The closet bolts may have come loose or closet flange is broken.
Feb 27, 2018 | Toto Home
I have a Toto toilet and am trying to replace the old seat. BUT the bottom is a solid piece and makes it impossible to access the seat bolt for tightening. I began loosening the seat bolts. now I have a...
hi there
good luck
Dec 18, 2010 | Toto Carrollton Toilet Tank - ST774S-01 -...
Need to replace toilet seat but cant get at bottom of bolts to tighten nuts as it is enclosed
Oct 10, 2010 | Toto Home
Toilet seat cover became loose on one side
I have a Toto Dorian 1.6 Gpf where the right side of the cover separated from the seat frame. I fixed it by removing the seat from the toilet base and driving the stainless steel shaft back into the cover hibge holes.
To remove the toilet seat, use a large phillips head screw drive and unscrew the two long screws that hole the seat to the base.
Then you will see the two steel rods about 1/4 inch in diameter that have worked there way out of the seat hinge. Use a hammer and a screw driver to drive these two hinge pins back out into the toilet seat cover hinge holes.
Replace the toilet seat and screw in the two seat screws being careful to not over tighten them. The seat should now work correctly.
Apr 02, 2010 | Toto Promenade, 1.6 GPF, Elongated...
Loose toilet seat
If the screws don't tighten the either the screw threads are stripped or the attachment nut is stripped. Take the screw and nut to any hmoe repair center and get new ones. remember don't over-tighten then screws as this will crack the unit.
Feb 11, 2010 | Toto Drake ADA Compliant Toilet with...
Loose Toto toilet seat
Sep 06, 2009 | Home
Toto Promenade, 1.6 GPF, Elongated Two-Piece Toilet, Cotton - CST424SFG Logo
251 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
