Question about Amana ARB2557CW / ARB2557CB / ARB2557CC Bottom Freezer Refrigerator
Our 5YEAR ARB2557CW was making a clicking sound for several days before it stopped cooling. Lost all ouf meat etc., Is itan expensive fix? Is it worth saving? Many thanks, Ann
  • 2 more comments
  • am_osullivan Jan 30, 2010
    How much do these Chips normaly cost and could my handyman husband do the job, or are special tools and a repairman needed.
    Also our ARB2557CW frosted up several times. Maybe the draw was fractionaly open at times but not always the case. What else caused this?
    Our 5YEAR ARB2557CW was making a clicking sound for several days before it stopped cooling. Lost all our meat etc., Is it an expensive fix? Is it worth saving?
    Comments:
    Jan 30, 2010 - How much do these Chips normaly cost and could my handyman husband do the job, or are special tools and a repairman needed.
    Jan 30, 2010 - Also our ARB2557CW frosted up several times. Maybe the draw was fractionaly open at times but not always the case. What else caused this?
  • 10,515 Answers
Read my Tip :-
http://www.fixya.com/support/r3886637-refrigerator_not_cooling_enough_or_not
Procedure to Inspect,Test and Replace Overload Relay is as mentioned below :-
http://www.acmehowto.com/howto/appliance/refrigerator/check/overload.php
The above one is a Generic Procedure.
Procedure to Clean Evaporator Coils
http://www.ehow.co.uk/video_4419298_clean-refrigerator-coils.html
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 31, 2010
    Genius:
  • 1,122 Answers
The clicking sound you hear is the compressor trying to start,you can get a 3in1 starter kit($9.99) from your local appliance part store,the package has very easy install instuctions,so don't a afraid it's easy-mike
Posted on Jan 30, 2010
  • 3,230 Answers
Well the components on the side of the compressor are called your relay, starter and capacitor. There are a few different styles but they pretty much do the same thing. They allow the electrical current to enter the compressor. If the compressor is going bad, say shorted windings in the motor, this will cause the compressor to draw to many amps of electricity. When the compressor draws too much current, the overload will overheat and "CLICK". When you hear that click, that is the sound of, your refrigerator isn't going to get cold anymore...... Relay is the main resign for this issue, this is a chip fix and your sure your refrigerator worth this repair...... Please post comments if you need more help or information.........
Good Luck!!
Thanks
WHERE A PLASTIC PIECE PULLS IN THE COMPRESSOR MAKES A CLICKING SOUND LIKE GOING OFF AND ON, SOME TIMES IT MAKES A SPARK INSIDE THE PLASTIC CONNECTOR....
The freezer control will normally make a ticking noise when starting and stopping the compressor. If it is clicking on and off in abnormally short intervals, you could have a component failure that needs a technician's attention.
The overload on the compressor will also make a clicking noise when it trips. If this overload is tripping, the refrigerator and freezer will normally not be cooling properly. This lack of cooling may take several days to appear.
Jan 18, 2011 | Maytag MZD2766GES Side by Side...
My fridge and freezer is not cooling down the fan runs and cool some then stops tks lance
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 04, 2010 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
Amana arb2557cw condenser coils freezing, fridge not cooling
There are a few things that it could be. Do you mean the evaparator coil? This would be the coil on the inside of the freezer, the condenser is outside the unit. If the evap. coil is freezing, you could have to much in your freezer blocking air flow. You could also have a evap. fan not running. Check the owner's manual for the location of the defrost timer, it could be bad. The thermostat needs to be checked and set so that it is at a reasonable level. One last thing to check would be the condensate drain. Make sure the drain is not plugged or the line is not plugged. Good luck.
Jul 31, 2009 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
Temp Alarm going off, when freezer seems to be cooling fine.
You need to check the temp in the freezer to make sure it's down to around 10 degrees. The alarm will go off much above that.
Jul 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer not freezing and refrigerator not cooling
sounds like a bad compressor, you cna check with the manufacture for possible warr( depending on date of purchase you may be covered, under 5year war)
Jan 20, 2009 | Frigidaire FRS26R4A Side by Side...
Freezer is only cool, everything melting
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jun 24, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kirland Refrigerator
It sounds like your compressor has failed. The hum is the compressor trying to start and the click following is the over current protector opening.
Jun 16, 2008 | Refrigerators
Amana ARB2557CW / ARB2557CB / ARB2557CC Bottom Freezer Refrigerator Logo
80 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
