Question about Frigidaire Refrigerators
I have model FRS26R4AB6 Serial # LA25102578 and was manufactured 12/2002. I ordered part # 241734301 Triple Water Inlet Valve which is the correct part for what I am needing to replace. However, the part I received appears to have a push-on water lines and mine has screw-on water lines. Am I missing something?
  • lisa_cain Jan 30, 2010
    ok will look at that.
  • 4,070 Answers
The new one is a push on connection. You cut the end of your existing tube off smooth. Then depress the blue ring and insert the tube all the way in and release the ring. Do this on all the connections. To remove the line depress the ring and pull the tube out.
Posted on Jan 31, 2010
  • 1,531 Answers
No you are not missing anything that is the new valve that has been change all you have to do is cut the tube where the screws are and just insert the hoses in the new water valve.you do not have to vut muchoff just above the little molded spot on the hose
Posted on Jan 30, 2010
Water continues to flow into my whirlpool top loader serial #2dwtw4740yq0
Your inlet water valve likely needs replaced. The water supply hoses behind the machine attach to the the water valve on the machine. You will need full model number usually found around inner door to find correct valve.
Jan 11, 2013 | Washing Machines
Ice maker is overflowing
If water continues to flow slowly after filling the water control valve for your model will need to be replaced=> 241734301 Water Inlet Valve
If ice maker simply over fills and then the water turns itself off then this points to a problem with the ice maker=> 5303918344 Ice Maker Assembly
I will be here to answer any questions you may have, Thanks Sea Breeze
Jul 12, 2012 | Kenmore Refrigerators
Ice maker not working
Try filling with tap water and allow water to freeze. Once the water freezes and ice dumps into ice bin and water does not refill this will point to the dual water control valve. On the Model FRS6R5ESB0 that part is a Triple Water Control Click Here=> 241734301 Water Inlet Valve I will be here should you have questions but for now please try the tap water fill test and let me know how that turns out, Thanks, Sea Breeze
Mar 20, 2012 | Frigidaire FRS6R5ESB
Where's the "saddle valve" in my Model
The saddle valve is the part you hook up under your refrigerator water supply to a water line under kitchen sink and cold water side of the copper pipes. The saddel valve looks like the parts below in photo. And some call the dual water control valve a saddle valve. If you are having trouble withe the water control valve your model takes a part number=> 241734301 Tripple Water Inlet Valve
If you have any questions once I post this solution I will be here to answer more if needed, Thanks Sea Breeze
If helpful please rate this solution.
Oct 19, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
I have a Frigidaire Model# FRS26H5ASB9. The ice maker is a GSI-26. The ice maker water line freezes up and then the ice maker does not work. It goes thru the cycle and it sounds like it is filling but no...
The most likely reason for this happening is a defective Click Here=> 241734301 Triple Water Control Valve These valves are located on rear of refrigerator and near floor where the water supply enters your Refrigerator. CLICK HERE=> FRS26H5ASB9 USE AND CARE GUIDE
The valve location is listed on page 5 of the Use and Care Guide, If you do not have Adobe Reader Click Here=> Adobe Reader X (10.1.0) This problem is typical as a leaky faucet that drips even when the water valve is turned off. I will be here to answer any questions you may have, Thanks Sea Breeze
If helpful please rate this solution, Thank You
Jul 16, 2011 | Frigidaire FRS26H5AS Side by Side...
Plhs39ee water is dripping from the water dispenser
The most likely reason for this happening is a defective Click Here=> 241734301 Triple Water Control Valve These valves are located on rear of refrigerator and near floor where the water supply enters your Refrigerator. Additional answers are found here=> PLHS39EESS0_User_Manual on page 5 of your models PDF. If you do not have Adobe Reader Click Here=> Adobe Reader X (10.1.0) This problem is typical as a leaky faucet that drips even when the water valve is turned off. I will be here to answer any questions you may have, Thanks Sea Breeze
Jul 15, 2011 | Frigidaire Refrigerators
Not making ice
There are a few simple test you can do that will answer what the problem is. First look inside of your ice maker and see if there are cubes remaining and if yes just check the switch to be in the on position. Look and see that the ice bin full feeler arm works freely. If the ice make still has cubes the problem is most likely the ice maker. If the ice slots are empty the most likely reason is your triple water control valve=> 241734301-2 Triple Water Control Valve You can test that by filling the ice maker with tap water and if after the water freezes the ice maker drops the ice into ice bin and then does not refill with water replace the water valve. If have any question please feel free to ask, Thanks Sea Breeze
Click Here=> FRS3R5EMB_Ice_Maker_Components
Click Here=> FRS3R5EMB_User_Manual.
Ice Maker=> 5304458371 Ice Maker
May 07, 2011 | Frigidaire FRS3R5EMB Side by Side...
Miele W916 front-loading washing machine filling very slowly
Hi
There are two variant of this model one with normal fill hose and triple valve and one with waterproof system and triple valve. If you have change water proof hose (one with grey box on end) then it only leaves the triple valve.if waterproof hose is fitted be sure to order 110volt triple valve
Mar 05, 2010 | Miele Novotronic W1918A Front Load Washer
Model frs23lh5ds9 repairing water valve when solenoid energizes to fill ice maker water is also dispensed at door
Your model has a triple water control valve. That is part number 241734301
That is the possible reason something has cause them to send water to both places. Does your model also have a water filter below or inside the refrigerator? I will need to find a set of better photos/wiring diagrams to understand why this is happening. I will try my best but I will need to go to Frigidaire to look over the refrigerator you have, I just am trying to picture the water lines and I admit this is one strange case.Let me know, Sea Breeze
Nov 20, 2009 | Frigidaire Refrigerators
Refrigerators Logo
43 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
