Question about HP Business Inkjet 1100d Printer
Printer won't print-have new ink
Haven't used the printer for a while and now it won't print. Have installed new ink cartridges.
  • 4,041 Answers
Hi
After leaving it for a long time and not use it the heads will have dried up and you will have to get at the heads to clean them, I have used little worm water on a cloth and just dabbing on the heads will clean them,
Pineworks
Posted on Jan 31, 2010
How do I make a test page for my printer to check color.
You need to clarify :
1. Your printer cannot print color even though it prints color well from a test page;
2. Your printer cannot print color in a test print page.
If it is the first one, then you have to set it properly in Window Print Configuration page of that printer;
If it is the second one, then you have to check whether you have installed the color ink cartridge properly in the printer. If the color ink cartridge is installed properly, try to replace another new color ink cartridge. Finally it is still not work, then you have to bring back to the repair center.
Jan 19, 2013 | Dell V715w All-in-One Wireless InkJet...
I installed new b&w & color cartridges and the
in your printer try to press on the restart button and hold it for about 8 to 10 seconds. by the way the ink cartridges that you installed are the genuine ink cartridges, if not then its gonna be normal that it won't detect as new.
Jul 11, 2011 | Dell Office Equipment & Supplies
Hi, I have re-filled the black toner cartridge, but the display says it is still empty. The red light is on and it won't print. Any suggestions please? Many thanks.
you need to use the menu on the printer and find the selection that says printer options-> ink cartridge-> new ink cartridge. what happened is you never told you printer that you were installing a new cartridge so it thinks that its still the old one. The printer actually never checks cartridge levels it just makes predictions based on how many pages you have printed.
Jun 30, 2011 | Samsung CLP 300 Laser Printer
I have changed the colour ink on my canon mp460 but it still say empty
CL41, this is the one you are using for your cartridge.
Did you change your cartridge with brand new one or refilled one??
If you did with refilled one, the ink level won't go back with full.
This is the method how printer measures the ink level.
1. Each cartridge has a serial number.
2. As soon as installation in printer, printer recognizes the cartridge by serial #.
3. And the printer starts to count the printing document.
4. After reaching certain print counting, the ink level will show "low ink"
So my answer is even if you refilled your cartridge, the ink level won't change,
since printer cannot weight the cartridge or.....some other technology to measure each color ink level.
Thanks.
Jun 15, 2011 | Canon PIXMA MP460 All-In-One InkJet...
How do i change my lexmark x4650 print cartrige?
Installing/Replacing your ink cartridges:
1. Open the printer, and then press down on the cartridge carrier levers. printmastert_52.jpg
2. Remove the used print cartridge or cartridges. 3. If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid. 4. If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid. 5. Close the printer.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
May 15, 2011 | Lexmark X4650 InkJet Printer
Just need to know how to put in black ink in the z1300
Follow these steps on how to install the cartridge: 1. Make sure the printer is on. 2. Lift the access cover. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. 3. Press down on the left cartridge carrier lever to raise the cartridge carrier lid. 4. Remove the used print cartridge(if you are replacing). Insert the new black cartridge in the left carrier. 5. Snap the lid closed.
3. Remove the used cartridge.
4. Load the new black cartridge. Close the cover.
Apr 29, 2011 | Lexmark Z1300 InkJet Photo Printer
How do I install the printer cartrige? I do not have the booklet...
  1. Turn on your printer.
  2. Open the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press the tabs on the cartridge lids, then lift the lids.
  1. Remove the old ink cartridges.
  1. Store the cartridges in an air-tight container or dispose of them properly.
  2. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
NOTE: You can use your printer with one cartridge (color or black) at a time. To extend the life of your color cartridge and improve printing speed, install both a color cartridge and a black cartridge at the same time.
  1. Insert the new ink cartridges. Make sure the color ink cartridge is secure in the left ink cartridge carrier and the black ink cartridge is secure in the right ink cartridge carrier.
  1. Snap each lid closed.
  1. Close the front cover. The front cover must be closed to start a print job.
  1. Open the Dell Printer Solution Center by clicking Start® Programs or All Programs® Dell Printers® Dell Photo Printer 720® Dell Printer Solution Center.
  2. Click the Maintenance tab.
  3. Click Install a new print cartridge.
  4. Click Next.
  5. Select the type of cartridge you installed.
NOTE: Specify whether the cartridge is a new cartridge or an old cartridge (one that has been used before). If an old cartridge is incorrectly identified as New Cartridge in the Dell Printer Solution Center, ink levels may be incorrect.
  1. Click Next.
Dec 17, 2010 | Dell Inkjet 720 Printer
Hp photosmart 8050 won`t print black even though it says it full
Hi there! If you haven`t used the printer in 2-3 months the black ink cartridge has gona dry.Wich means the printer is seeing full ink but the ink isn`t actually coming out from the ink head.Take a peace of clean cloth or cotton and clear the bottom part of the ink head(be verry carfully while cleaning it cuz you may dmg the head.If that doesn`t help just go and buy a new ink cartridge and it will solve your problem.
Nov 10, 2010 | HP Photosmart 8050 InkJet Printer
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
HP Business Inkjet 1100d Printer Logo
98 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
