Question about Hannspree 19" Widescreen LCD Flat Panel Monitor
Ive moved my pc from one part of the room to the other and it keeps saying "vidio cable not connected" I did not have one and plugged all cables exactly how they were. This did happen when I first assembled it and I think I needed to install a disk. I cannot find the disk. I cannot get the monitor to connect to the hard drive.
  • kayhyslop Jan 30, 2010
    I moved to harddrive very carefully. I cannot get the monitor to come at all. which means I cannot access the computer desktop. I am sending this on my mums lap top
  • 218 Answers
While moving you may have slightly dislodged the Video card. (I am assuming you have connected the VGA cable properly.) If it a desktop, with a VGA card (not integrated on the mother board) this may be the cause. Switch off the computer open the side panels. push down the VGA card. If the screw is holding it is loose, tighten it. Reboot. Most probably it will work. Otherwise, go to control panel and use add hardware. Once it comes to the driver CD part, select the the option to choose the best driver. Most chances are that it will find the earlier driver that is on your computer. If this fails, google the name of the VGA card + driver . Download the drive and Install it.
Posted on Jan 30, 2010
How do i stop my t.v. from turning off when i,m watching vidio.
are you using HDMI cables? Check the connection and replace the cable if needed.
May 24, 2014 | Televison & Video
How do i connect my pc to my tv
Depending on the tv and the computer, their is usually an "s-cable" port in both. It's a round plug in with 4 metal prongs and 1 square plastic prong on the plug, and 5 holes in the plug in on the computer. Available anywhere vidio stuff is sold; walmart or even your local video store.
If your componants are newer then a standard usb cable (computer connector) will work.
Dec 30, 2010 | Samsung Televison & Video
"Cannot display this video mode"
first thing check all power cables and monitor cables are plugged in properly , also you might check the monitor cable , inside the medal housing to see if any pins were broke off while moving. this would be an easy fix , just buy a new cable. if not check to see if you have a video card and that it is not moving around and properly seated to motherboard. if not most pc's are onboard video which would be entirely different issue. most of the time when moving pc's its usually a simple fix.
Apr 04, 2010 | Dell E153FP 15" LCD Monitor
Monitor not coming on
make sure the blue (VGA) video cable are firmly connected on both ends - finger tighten the thumb screws. You should be all set.
Jan 30, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
Dell Latitude D600 PC Notebook
your s-vidio out on the laptop only transfers vidio, you need to use a headphone to rca jack cable pluged into your headphone port on laptop and plug rca into back of tv or vcr or s-vid converter box
May 31, 2009 | Dell Latitude D600 Notebook
Router won't log into it's IP address online
It appears to me that you have everything plugged into the desktop PC. This is not the way that it should be done. Plug the cable modem into the wireless router via the Internet/WAN port. Plug your desktop PC into one of the ports numbered 1-4. Now connect to the router via the wireless connection for the router and you should be able to now connect to the internet with your laptop.
If it still does not work, power down everything in this order: Laptop, Desktop, Router, Cable Modem. Bring everthing up in the reverse order (Cable Modem, Router, Desktop, Laptop) waiting for each device to stablize before moving to the next.
Once you get everything working, turn on your wireless security (WPA not WEP) asap to keep your computers and surfing safe, and to keep intruders off your network.
Jul 20, 2008 | NetGear RangeMax WPN824 Router
JBL encounter
HI! Red14 happy holidays
Well, may be a lot things, from bad cable, welding inside , or bad resistor is burn. but check the cable, and if you can open the panel on inside speakers, try to figure out if the cable is not loose, or bad.
Nov 27, 2007 | JBL Encounter 2.1 Computer Speakers
Hannspree 19" Widescreen LCD Flat Panel Monitor Logo
53 people viewed this question
Top Hannspree Computers & Internet Experts
justwinwin
Computer Links
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
