Question about HP Pavilion Media Center a1510n PC Desktop
HP Pavilion Media Center a1510 PC desktop, one long beep pause and one long beep keeps repeating, fans and lights working. Is it worth fixing?
  • HP Master
  • 5,263 Answers
One beep means a problem with your processor (CPU). You can try to reset it (there is(are) clip(s) on the side that hold it down to the socket). Unplug everything from your computer before opening. You may need to remove the heat sink on top of the CPU; get some thermal paste to put on the CPU before you replace it. Lift up the clip, make sure the CPU is correctly oriented (one corner is marked) and press it back down. Spread new thermal paste and replace the CPU cooler. Try rebooting the computer. If that doesn't work, you should try a new CPU - match to the socket on the motherboard. Unfortunately, if you use Windows, you will probably need to contact them to ensure that the OS key is valid.
I hope this helps.
(if your computer is really old or was cheap, replacing it with a new machine may be easier. Pull the old hard drive and either install it as a slave drive in the new machine or use a hard drive enclosure (IDE or SATA to USB or eSATA if that is on the new machine), a hard drive dock (SATA) or a IDE/SATA/USB dongle (that lets you connect a bare drive out in the open to the USB port) to get your data from the old computer.)
Posted on Jan 30, 2010
HP Pavilion Media Center TV m7680n beep codes at start
How many beep codes?
Beep codes depending on how many can detect defective video display card, defective memory etc.
Jul 07, 2014 | HP Pavilion Media Center TV m7680n PC PC...
HP Pavilion Media Center m8200n upon turning on it only beeps, and led light blinks twice contiuously, with no signal to monitor?
Power On LED Carl?
I ask that because most Power Supply's that HP uses, have an LED on the back also.
(HiPro, Delta, and Bestec)
The LED is now working as a diagnostic LED.
(Light Emitting Diode, so stating LED light, is redundant)
The beeps you hear are BIOS Beep Codes.
The computer's way of telling you something is wrong, and an area to look into for it.
As stated, it's a Code.
One example;
3 Short beeps,...pause, 3 Short beeps,...pause, etc.
With the Power On LED blinking 2 times, then a pause; indicates,
A) Computer is dirty inside. To include Power Supply
Computer is unplugged from power, Anti-Static Procedures are FOLLOWED; and a can or two of compressed air for computers, is used to clean it out.
I have a procedure to follow if you are interested.
B) Processor (CPU) fan is not seated correctly, and/or is Not functioning, or functioning properly.
Case open, and computer on; see if the Processor fan is;
1) Spinning
2) Looks to be spinning the proper speed.
No, I don't expect you to count the Revolutions per Minute, lol!
My reference is a general one. If the Processor fan looks to be turning slowly, you'll know it
3) Processor fan spins intermittently. Spin, slow down, stop....spin, etc.
C) Thermal Paste in-between Processor, and the finned Heatsink that sits on it, has dried up.
Lost it's thermal conductivity properties.
Top of Processor, and Bottom of Heatsink; MUST be THOROUGHLY cleaned, and fresh, new Thermal Paste applied.
I have a procedure for this too.
I can guide you step by step.
Post back in a Comment.
Regards,
joecoolvette
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=3548185
How to > Adding/Replacing Hardware > Opening the PC Case,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00583783&tmp_task=useCategory&cc=us&dlc=en&lc=en&product=3548185
http://www.hardwaresecrets.com/article/274
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3071621&CatId=503
Apr 03, 2013 | Computers & Internet
1 short beep 1 long beep
Unplug your monitor , key board, Mouse and open the Case of your system. New clean everything inside with a vacuum clear or some thing like that. Clean even the RAM. open the RAM from RAM bank and clean it with the help of pencil eraser. Now put back every thing in its own Place. Now your computer should boot up unless there is some Hardware Failure.
IF it boot you then I'll suggest you to go to HP site and download the Latest update for your Chipset Driver. If you are not sure about which Chipset is there in your board then you can Auto detect it in HP site. Hope Things will go well for you.
Good Luck.
Aug 16, 2012 | HP Pavilion a1600n (882780776265) PC...
My pc won't boot..I get very long beep, pause long
Try resetting the motherboard, by either removing the battery or changing jumpers on the motherboard. If this doesn't work, then motherboard is going bad.
Feb 19, 2010 | HP Pavilion a6600f Desktop PC
HP KT334AA Pavilion Media Center M8530F will not POST. No beeps or monitor activity. Fans spin and that's it. The system froze and I had to manually shut it down, now nothing. Monitor works on another...
hello, below are few trouble shooting steps you can try.
1: open up the tower case and reset BIOS by removing the battery from the motherboard and switching jumper position. try turning on computer.
2: remove RAM sticks from the PC power on PC see results for any change, if no chnage stick one stick back at a time(if you have more than one) and then try it again.
post your results back and we will look to further troubleshoot the issue.
I hope this helps
regards
Amar Sondhi
Dec 05, 2009 | HP KT334AA Pavilion Media Center M8530F...
My HP Media Center m7330n won't power up... The fan comes on but will not boot.. The LED power light blinks at 3 second intervals from blue to yellow/orange.. What is the diagnosis...
You have to check with your RAM sir, if you know to remove the side cover of your CPU(tower) there will be a green colored chip fixed in vertical position in the motherboard if remove it and then fix it properly means you will get the display in yur screen.i will show you the RAM picture2f70f69.jpg
Oct 29, 2009 | HP Pavilion Media Center TV m7330n...
I just purchased a slightly used HP m9340f Pavilion Media Center PC. It won't boot up... it just beeps. Nothing shows on the monitor.
The beeps normally are a code which tells you what problem has been detected and is keeping the computer from starting. You can find information about interpreting the beep codes and what to at HP's site here. The most common causes of beeps and no start is bad memory or video. I'd suggest making sure the memory modules are firmly seated in their sockets. It's possible that poor connections are keeping the memory from being properly detected.
Jul 29, 2009 | HP Pavilion Media Center m9340f Desktop PC
I got hp pavilion pc the problem is its not switching on there is a green light back of the pc it keep flashing what i ve to do My HP Pavillion will not come on and the green light at the back keeps...
if your network cable is plugged in it will flash green .....if it won't turn on pull the plug and wait 10 seconds or more then plug in again and see if it will start .....are the fans running and no signal to monitor?
Jan 06, 2009 | HP Media Center m1180n PC Desktop
HP Pavilion Media Center a1510n  PC Desktop Logo
232 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
