Question about Dell Dimension 2350 PC Desktop
No ip address
Put new hard drive in dell 2350 put cant get on internet
  • Craig Underhill
    Craig Underhill May 11, 2010
    Did you replace the main drive and reinstall Windows? If so, it sounds like your network card driver isn't installed.
    Check the following:
    1. Are any lights blinking on the back of your computer where the network cable plugs-in?
    2. If you go to the Device Manager*, and then look under Network Adapters, do you see a exclamation point or an X? That would indicate a problem with your card
    *to get to the device manager, right-click the "my computer" icon, then choose "properties". you will get a window with a bunch of tabs across the top. choose "hardware", then choose "device manager".
  • 407 Answers
You install your network card driver 1st.
then go to your network properties .....set as ip adress 192.168.0.1
then press tab.....then set as internet properly.
Posted on Feb 18, 2008
How do you access the IP address for a Dell Studio 1558
click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details
or type in your default gateway adress into your internet search should read something like 10.0.0.138 to get an inertnet connection
hope this helps you
Mar 21, 2012 | Dell Computers & Internet
I reinstalled windows xp on my dell dimension and now i am missing all drivers and cant connect to the internet
You will have to go to the Dell site and at least get the network driver and put on a jump drive but it will have to be an old jump drive because the 2350 may not recognize some of the newer jump drives that have security features (I know that is a pain!) What I do is download the whole lot and burn them on a CD. JC
Nov 17, 2009 | Dell Dimension 2350 PC Desktop
Cant connect the router to my xbox 360, it cant read the ip address
ring up dell it might cost you to tell them how to fix it over the phone but its worth it to be able to play
Oct 10, 2009 | Dell Wireless 2350 Router
Computer can't find the router
Configure your router first, by doing that you need a ethernet cable (cat 5 will do). Connect your computer to your router using ethernet cable and open internet explorer, type in the ip address of your router and press enter. After that, you will be ask for username and password, just key in your username and password (if you cant remember, reset your router and key in the default username and password of your router). Once your done, go to internet setup and you can configure everything there. Hope it helps you.
Jun 21, 2009 | Dell Wireless 2350 Router
Vista hook up with dell wireless 2350??
You really don't need the setup disc to setup a router of any kind. First you need to plug the computer into the router via ethernet cable. Jack into one of the numbered ports on the back of the router. Once Vista receives an IP address, click start then type cmd and press enter (this opens a command prompt). Type ipconfig and note your default gateway. This is the IP address you will need to type in to Internet Explorer. After sucessfuly doing that it's probably going to ask you for some login credentials. Check your user manual for the user name and password. After logging in, set your router up as needed.
May 23, 2009 | Dell Wireless 2350 Router
Cant connect to internet
That will be the default gateway address.
Compare the settings there, my money is on that fixing it. Otherwise it will be the DNS server Main and Secondary IP addresses.
Do you use DHCP or fixed IP's?
Apr 25, 2009 | Dell Inspiron 6400 Notebook
IP address Problem with Dell Studio 1525
Most probably its the problem with the autonet ip address where the computer picks a bad ip address. If your internet service provider has DHCP enabled you cannot put the manual IP address. If its a new problem try system restore, uninstalling and reinstalling networkdrivers. resetting winsock.(search google)
Mar 30, 2009 | Dell Inspiron 6000 Notebook
Ethernet Driver
Yes, you need to download Enthernet driver for you system and you can easily find on Dell's website.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_PNT_CEL_2350&os=WW1&osl=en&catid=&impid=
you can even search driver using serivice tag which you can find on your computer.
thank you
and do not forget to vote all answers.
Jan 11, 2009 | Dell Dimension 2350 PC Desktop
Setup problems with DELL 2350 router
sometimes windows messes the whole network up when using the set up wizard, you need to go to the properties of your wireless cards and check on the TCP/IP line that the radio button that says obtain ip address automaticaly is ticked. Go into the routers properties menu and check that DHCP is enabled and so allow the router to allocate ip addresses automatically, although you may need to do this via an rj45 cable and not wireless to begin with.
Jun 11, 2007 | Dell Wireless 2350 Router
Dell Dimension 2350 PC Desktop Logo
61 people viewed this question
Alun Cox
