Spectroniq TV reads input signal out of range when I connect my pc via vga
  • 10,594 Answers
Tv shows input signal out of range message when it receives high resolution video signal or high refresh rate signal (higher vertical frequency) that does not match with hardware in tv.
In simple words, your computer is providing higher resolution picture to tv that can not be processed in tv hardware/ circuits so tv shows above said error message.
So please check Display properptise of computer and reduce Display/ Screen Resolution and also check Screen Refresh Rate under monitor tab/ settings, should be 60 Hertz.
Hope this info will help you to solve tv problem.
Thanks.
Posted on Jan 30, 2010
Contect my laptop
When you have set the TV to VGA input power up your laptop. It should detect it.
Mar 09, 2015 | VIA Computers & Internet
Guys, Recently i got LG 22" LCD TV. It has VGA port and HDMI port. When i connected my CPU cable toLCD via VGA port it didn't show anything, :"( i checked input MENU on remote then it shows only 4...
HDMI [High Definition Multimedia Interface]. VGA [Video Graphics Array]. AV [Audio Video]. By these definitions itself talk to you about the inputs your TV have; and it do not support VGA. Output from PC is VGA. Without a VGA input with the TV, you can't connect the PC to TV. I think I'm clear. http://electronicshelponline.blogspot.com/
Jul 09, 2014 | Televison & Video
The input signal out of range on screen persists in spite of all monitor and PC video settings being correct.
Have you tried uninstalling the graphics driver entirely and then rebooting? Could be a corrupted driver.
May 04, 2014 | Lenovo Computers & Internet
Having problem connecting inspiron 1150 laptop to tv via vga
Check the remote for the TV or the TV menu to see if there is a way to change from one source input to another. You may just not have the TV set to the VGA input. Also you have to make sure the video card on your PC is set to a resolution your TV will support.
Dec 04, 2012 | Computers & Internet
Protron tv says input signal out of range when connecting laptop via hdmi
The TV can't process the digital signal. It might be out of range.
Nov 26, 2012 | Protron PLTV3250 32 in. LCD Television
Link ASUS laptop to Sharp Aquos LCD TV
No, a DVI to VGA adapter will not work. (The TV is looking for the digital signal from a set top box. This is different from the analog signal on the VGA cable.) You need a converter. Your best bet would be a VGA to component video converter. (I am assuming that the Sharp TV has a component video input.) This page has some examples: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215.html?sorter=productname-en-asc . Note a VGA to component video cable will not work. The VGA to component cables are for projectors that read the RGB signal. The component video signal is YPbPr.
Connect the VGA cable to the converter and the component video cable to the TV and the converter with the computer and TV off. Turn on the TV first and set it to the component video input and then turn on the computer. Then (assuming the VGA port is enabled - adjust in the BIOS if needed) set the computer's video output to the VGA port. (On my Windows 7 laptop, this can be done by right-clicking on the desktop. Choose Graphics Properties and set the display to the external monitor or both. Click Apply and then confirm the change (on the external monitor if using the single monitor). (VGA to Composite video converters also exist if you do not have an available component video input on your TV.)
If your computer is fairly new, you may have an HDMI port. Your TV may be able to read the signal with a DVI to HDMI cable. (It depends on the TV. Not all of them will read the computer's signal on the DVI port. Check the documentation for your model. TVs without a VGA port are less likely to support this feature.)
I hope this helps.
Nov 28, 2011 | Televison & Video
We are trying to set up a dual monitor system so that we cn watch movies via the pc [not laptop] we have plugged in all the cables but still zilch
if you want to set up a dual tv monitor system using via pc as a source you will need a VGA splitter usually 2 or more output. now how are you going to connect the 2 monitor and PC to the VGA splitter. first make sure your tv monitor is supported by service input for PC unit. then prepare the accessories needed. the VGA splitter and VGA cable. vinceisaac_30.jpg vinceisaac_31.jpg sample image for VGA splitter VGA cable or connector how are you going to hook up the splitter and VGA cable to the tv monitor and PC
  • you need 3 vga connector and 1 splitter to connect a dual monitor system.
  • connect one end of the vga connector to the pc unit and the other end to the input port of splitter.
  • now the 2 remaining vga connector connect to the output of splitter either of the port, then the 2 end wire you must connect to the input port ( pc service port ) of the 2 tv monitor. make sure you set up the right input either with the remote or at the tv unit to recognized the pc source.
  • you almost done the connections now at this point plug the tv monitors, plug the dc adapter supply of the vga splitter and lastly turn on the pc unit to view movies. i hope it will help you just ask me if you have further questions thanks for choosing the fixya.
Jun 05, 2011 | Televison & Video
Hi when I try to connect my laptop to the TV it say input signal out of range. Thanks
You need to set the laptop video resolution to the TV native resolution. Your laptop is putting the video signal that higher than the TV can display. You can down the manual here and read all about it: http://www.retrevo.com/support/SpectronIQ-PLTV-3250-TVs-manual/id/926dj283/t/2/
Dec 15, 2009 | Protron PLTV3250 32 in. LCD Television
Connect my Dell Vostro 1400 laptop to my HDTV via VGA
You have to tell your laptop to use both displays normally it would be the FN + F5 or F6 keys
Sep 15, 2009 | Dell Vostro 1000 Notebook
I am trying to connect my acer PC to a tv but get
The inputs on a TV are normally via the ariel and go into a pre-amp
To get a signal in you, would again, normally connect to the RGB or Video in which bypasses the pre-amp.
The VGA cable will be outputting a digital signal which a monitor will understand but a TV will not as it prime supply is via an analog signal
You may be able to get a connection if you process the signal through a freeview box which changes the signal from analog to digital
Jul 01, 2009 | Acer Aspire 5102WLMi Notebook
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
