Question about Kenmore 73952 Gas Dryer
60 series gas dryer runs but wont heat up. replaced igniter & 1 other electrical plugin close to it.
  • 1,531 Answers
You need to check all the thermal fuses for continuity if one of them does not have any continuity then it needs to be replaced as well.if one is bad the unit will not heat the ignitor.there should be four of them the main one to check should be located on the vent housing that your flames are blown through
Posted on Jan 30, 2010
Maytag DG410 gas dryer-no flame, no heat. I replaced the ignitor - that apparently isn't the problem. Other ideas?
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag PYG4500A Gas Dryer
I have an Amana Designer Series Gas Dryer. It worked fine for more than 10 years. Suddenly, yesterday it still ran, but there was no heat. I opened the bottom panel while it was running, and...
Sep 22, 2011 | Amana ALG331RAW Gas Dryer
Dryer wont heat. cleaned exhaust duct still problem exsists. Model 60 series kenmore gas
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 09, 2011 | Kenmore 600 6965 Electric Dryer
Hello my 70 series kenemore is not getting warm and the timer is not completing the cycle to turn the dryer off it just keeps running for hours
I would need a model number to better narrow the problem down for you.
If this is a gas dryer
Remove the lower panel. With the lower toe panel removed, start the dryer & watch the igniter. If the igniter glows & cuts off without lighting the gas this would usually indicate the gas valve coils are weak & will need to be replaced. For this type of repair be sure to disconnect the electrical power & turn off the gas to the dryer. If the timer is set in the auto dry cycle, it will not advance if the dryer is not heating. Once you repair the dryer, the timer should start advancing. It is possible that your old timer is good. If you need further assistance please resubmit your question.
If this is a electric dryer
The timer not advancing from 50 minutes in time dryer & the unit not heating are not related unless 1 leg of the 240 volt supply is lost. Diagnosing a problem like this will require using a volt/ohm meter. With the timer set to time dry you should be getting 240volts to the timer motor & 240volts to the heating element. In the wiring diagram provided L1 comes from the timer on R & goes through the thermal cutoff, oper thermostat & the hi-limit to provide 120volts to 1 leg of the heating element. The L2 leg goes through the motor switch to the other side of the heating element. This is how the element gets 240volts. The timer motor gets its voltage on BK from L1 & OR from L2; this is what advances the timer.
Jan 12, 2011 | Kenmore 700 7973 Dryer
Kenmore 60 series gas dryer runs but no heat - there is gas and electricity to machine.
see if igniter is glowing during start up, if it isnt there's your problem
Oct 28, 2010 | Dryers
Kenmore 80 series dryer does not hest
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Gas Dryer---
2. Check for the continuity of the heating element in your gas dryer using a multimeter. Replace the element if continuity is not there.
3. Inspect the thermal fuse if it is burnt out, it is attached to the exhaust duct on the back panel of the gas dryer. Replace if necessary.
4. Check the igniter by first disconnecting it, and then place the probes onto the two contacts of the igniter. The meter should read under 100 Ohms of resistance, if it is above 100 then replace the igniter.
5. Check the continuity on the flame sensor. The sensors are usually located close by the igniter so are easily visible.
Hope this helps...
Daniel
Sep 25, 2010 | Kenmore Dryers
No heat
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 24, 2010 | Maytag MDE2400A Electric Dryer
DRYER WONT START,IT HUMS, MODEL #LNC8760A71
Hi
If the dryer is not turning on or is not drying the clothes then you would need to check for the following things—
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 13, 2010 | Dryers
Dryer will only blow cold air
always use caution around electrical appliances
electric dryer-runs but will not heat
1.loose wiring--check terminals & wiring
2.defective thermostat--replace
3.defective centrifugal switch in motor--replace switch--check linkage in motor
4.defective timer--replace
5.open heater element--replace
gas dryer
1.faulty ignition or reset valve or thermocouple
2.thermostat
Jul 31, 2010 | Samsung Dryers
Kenmore 70 series dryer wont heat up and wont stop running
For a gas dryer, check the following
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
For a electric dryer, check the following
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Jun 01, 2009 | Kenmore 63942 Dryer
Kenmore 73952 Gas Dryer Logo
15 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
