Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
I removed U3 stuff from my Cruzer micro 2.0GB; now I get message
I removed U3 stuff from my Cruzer micro 2.0GB device some time ago, then reformatted it. Since doing that, whenever I plug the device into a port on any of my machines, I get "This USB device can perform faster if you connect it to a Hi-Speed USB port. For a list of available ports, click here." How can I stop that message from coming up?
...HK
I would like to point out that this must be something the u3uninstall utility did to the usb stick. Mine was working at full speed while I had the U3 stuff on there, and stopped working at full speed in both windows 7 and ubuntu 10.04 after I used the tool. Sorry this isn't a solution, but it's additional info. It's strange it makes it seem like the problem is your OS or drivers and not the usb stick itself, or what the u3uninstall utility did to it.
Posted on May 08, 2010
    Guru:
  • 206 Answers
That all depends on the type of computer you have and if the ports on those computers have USB 2.0 which is classified as the "Hi Speed" USB type for Universal Serial Bus classifications.
The only time you should be getting this type of message is if you are plugging your SanDisk 2G Cruzer Micro flash drive into a USB 1.1 port.
Now considering you have several machines and are using a 2G Flash drive, I am sure you have USB 2.0 ports on your computers.
I would recommend you check your USB ports in Device Manager to make sure they have the latest drivers installed.
Also, if your computers are PCs running a Windows OS like XP, Vista or Win 7. make sure the OS has the latest service pack installed.
Finally, I would also recommend you run the chkdsk command-line utility, to repair the Win OS you are using, as this issue in some cases, has been known to be a software issue with Windows XP for example in regards to the USB device error message you are seeing.
For properly using chkdsk, here is the link from
Microsoft:
How to use chkdsk in Windows
This is also another link I want to provide you, for
updating your USB Drivers using DriveFinder.
Auto Update Your USB Drivers
All the best!
Regards,
-Mactechtrainer
Posted on Jan 30, 2010
Want to remove U3 software and completely wipe SanDisk Cruzer Micro flash drive.
Try using a tool like Rufus http://rufus.akeo.ie/ to format the drive to its full capacity. There are links on the page to other usb utils.
Feb 07, 2012 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive My Drive is Empty How Do I Get U3Smart The Drive To Factory Settings. My Model is SDCZ6-4096A10 SN# BH0701l5B
According to Scandisk:
As of October 1st 2009, SanDisk started shipping the Cruzer Micro (SDCZ6-XXX) product line without the U3 software pre-installed on the device.
During the transition period, there may have been a small number of devices that were packaged in older packaging that states the device includes the U3 software. If you purchased one of these devices and would like to use the U3 software, please download and install it.
http://kb.sandisk.com/app/answers/detail/a_id/4425/kw/SanDisk%20Cruzer%20Micro%20USB%20reset%20factory%20settings/r_id/101834
Jan 14, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Not working
Oct 14, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisc cruzer micro won't format
Is this one of the cruzers with the slidey USB connector, and what's called "U3"on it that loads automatically?
If so, you should not need to format it as such, but if there is a lot of the U3 software on it, that can bog up the drive with unnecessary data. You can also remove the U3 software altogether, however, this is a permanent solution - make sure you will not ever want this functionality from your drive first before you remove the U3 software.
Jan 01, 2009 | SanDisk Cruzer Micro MP3 Player
Micro cruser 8GB
The SanDisk cruser came with the nasty U3 launchpad software, try removing it and then reformatting the stick.
This site will tell you how and it has a download for the removal tool:
http://www.u3.com/uninstall/
Jul 24, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk flash drive
Strange... Vista does seem to have a problem with everything Sandisk...
Anyway, this should be all you need:
Launchpad Installer
Launchpad Uninstaller
Mar 19, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Data recovery
Because it formats the device, if the restore option didn't work then it sounds like bad news. I would recommend searching your pc for the images just in case the U3 uninstaller cached them somewhere during the process.
Feb 17, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk4Gb Cruzer
explain more. Is U3 launchpad on the USB disk?? explain details and I'll see what I can do for you...
Cynthia
Jan 30, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to format
1.run...cmd
2.Format F:/fs:Fat32 [ F should be change to flash drive name]
3.enter ....wait the results
Click Ads in my web for thank me at www.review1.net
Oct 29, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
226 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
