My washer won't spin. Do I need to buy a new one
When my washer gets to the spin cycle, within a few seconds stops. It almost feels like it spins too fast or hard and trips a switch; I feel a loud click right before it stops.
  • 129 Answers
OUT OF BALANCE SWITCH
Posted on Jan 31, 2010
Kenmore washer stops spinning a few seconds in to the cycle.
Sounds like the brushes are struggling to get enough power to the motor to spin. Renew motor brushes
Apr 21, 2012 | Kenmore Washing Machines
Why is my frigidaire washer not spinning?
  1. Stopped Mid-cycle
    • If your Frigidaire washing machine started spinning, but then stopped, verify that the power cord is still connected to the outlet. See if the outlet blew by plugging in a different appliance into the outlet. See if you blew a fuse. A blown fuse usually is either black or has broken wires. Replace the fuse. If you have a circuit breaker instead of a fuse box, reset the circuit breaker if it's been tripped. Check the lid switch, which is located inside the main housing of the washing machine, near the door frame. If the switch is burned out, order a new part from a Frigidaire parts dealer.
    Pump
    • The pump's sole responsibility is to remove water during the spin cycle. If the pump isn't working properly, see if it's clogged with debris or clothing. Use needle-nose pliers to remove these items. Check the pump pulley, which is connected to the pump. This component must move freely for the pump to work. If it won't turn, purchase a new pump pulley since you can't usually fix this component.
    Lid
    • Check the door latch assembly if the door isn't closing correctly. If any of these components are broken, order a new part from a Frigidaire parts dealer. If you do not, the washer won't start spinning since it believes the door isn't closed. Your Frigidaire washing machine won't start the spin cycle until the lid or door is closed. Always close the lid, and remove any items preventing the lid from fully closing. Always close the dispenser drawer.
    Additional Concerns
    • Never over- or under-load your washing machine. Your Frigidaire washer may not enter the spin cycle if the load is too large, since this can damage the washing machine. Remove a few pieces of clothing. If the load is too small, add a few similar items to the washing machine. Check the internal belt, drive motor and motor coupling. If any of these components are broken or very worn, they may not work properly, preventing the washer from entering the spin cycle. Order replacement parts from a parts dealer. Check the tub and basket bearings, and get new ones if the current ones have broken components or are defective.
Sep 27, 2011 | Washing Machines
My FWSB5700DS0 top load washer can't get up to speed in the spin cycle. It spins up for a 5-7 seconds and before reaching full speed, it stops spinning, and the pump stops pumping. Then after a 10-15 ...
It sounds like the motor is going out. The motor will shut down when it gets to hot and once it cools it will try to work again. Motors are around $150.00 on the average. You can look at the motor and get the part number off of it and then look on eBay and find one a little cheaper.
Nov 20, 2010 | Frigidaire FWSB5700DS Top Load Washer
Maytag washer (model PAVT244AWW). Won't spin. Don't know how old it is or its history, as it came with a home we purchased in October. Several times it's "walked" during the spin cycle. About 6 weeks...
Its the clutch ,And it sounds like it time for a new washer,the clutch is expensive and washer are cheap try a second hand store that sale scratched or almost new machines
Jul 05, 2010 | Maytag PAV2300 Top Load Washer
My MLE2000 washer will start to spin and then
more likely an itntermitent lid switch problem as the washer strats it's spin cycle the motion is causuning the lid switch to open making the washer think some one has opened the lid and it shuts down to be safe check the switch make sure it hasn't come loose and check the actuator on the lid sometimes a plastic piece near the front of the lid that goes into sort of a key hole Good Luck
Oct 16, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Washing machine does not drain during rinse cycle?
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
May 17, 2009 | Whirlpool LSQ9600L Top Load Washer
Kenmore 80 series washer clothes are still dripping wet
May 16, 2009 | Kenmore 24032\24036 Top Load Washer
G.E. spacemaker washer will not spin
possible faulty motor. Regards Advisor
Aug 22, 2007 | GE WSKS2060WWH Top Load Washer
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
