Question about Siemens SpeedStream Modem (4100) (SS4100)
Power problem Lately when I've tried to turn the modem on it takes forever for it to come on.
  • 83 Answers
On the back of your modem there is a little hole. Use a pen or a pointy thing to press the button for about 10 seconds then it should come on.
Posted on Feb 20, 2008
Laptop Can't Find New Cisco Linksys EA4500 N900 Router In Setup
Try this, your IPS Virgin, is a modem? remove AC from the ISP modem and remove battery(If it has one), remove AC power from the Linksys. Insert battery and plug in the virgin ISP modem, allow it to run the self test, may take a few mins. Plug in the Linksys, ( Is it secured with a SSID and security code?), wait for self test. turn on your computer boot normally. If that fails try this procedure: http://compnetworking.about.com/cs/windowsnetworkin1/ht/renewipaddrwxp.htm
Dec 02, 2012 | Linksys by Cisco Linksys Ea4500 Dualband...
Problem with a LG 37in lcd when i turn it on it takes forever for it to show up a picture on the screen the green light comes on and then i gotta wait
Have the power supply checked out. I've worked on your particular model with the same problem. Turned out to be bad capacitors in the power supply.
Oct 19, 2012 | LG 37LC7D 37 in. LCD HDTV
I've been practicing forever! How do I bowl a strike?
Bowlinga strike takes a lot of practice and quite a bit of luck too. I watched thisvideo on YouTube that gives a really detailed breakdown about bowling strikesand shows lots of examples. I hope it helps you.
Aug 01, 2012 | Sport & Outdoor - Others
Lately, I´ve been trying to
Do a soft reset on the phone by removing the battery. I know it sounds dumb but in many cases it works.
Dec 13, 2010 | Ericsson Cell Phones
Car Power Amp not truning on for 60 to 120 seconds in cold weaher
could be internal problem with the amp, but there is a possibility it is something else. Are there other amps in your car? Do they turn on quickly? If this is the only amp, try the following:
- disconnect turn-on lead from amp (blue wire?)
- turn on stereo (volume normal or low)
- use small piece of wire to connect 12V terminal to turn-on terminal.
you can just touch the wire to the terminals - paper clip will work, too.
- if the amp still takes forever to power up, then the problem is internal to the amp.
- if the amp powers up right away, the problem could be in the turn-on output from your head unit. You can resolve this by using a relay, or by using the ACC output from the ignition (red wire at radio wiring harness) to turn on the amp.
Jun 28, 2010 | Orion Car Audio & Video
Monitor won't turn on
in the output section of smps some condensors are faulty
Dec 12, 2009 | Computers & Internet
Wont connect. power light is red. wireless light is green. i have a 2701hg-b 2 wire. i ve tried diconnecting, resetting, but the gateway remains the same. what do i do?
I've got the same issue, 2 wire claims that whrn the power light is red, the modem is bad and must be replaced. I would try and power the modem from another circuit before replacing. I am replacing mine today
Jun 24, 2009 | AT&T High Speed DSL Modem
Slow identifying 2wire686
Are you trying to use wireless? If so, do you have poor signal? I would suggest browsing to your modems interface. Type gateway.2wire.net into your web browser. Click on the Homenetworking icon. Select wireless settings. Type in your system password. Increase the power of your wireless setting located towards the bottom of the page. You can even try changing the wireless channel. Save and then retry to connect. Make sure you are entering the network key correctly.
Jan 03, 2009 | 2wire 2700HG-B Router (2700HGB)
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Siemens SpeedStream Modem (4100) (SS4100) Logo
180 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
