1998 Jeep Wrangler Logo
Posted on Jan 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2002 wrangler I6, no heat
2002 wrangler I6, had heat when I started on a 3 hour trip but the last hour it just blowed luke warm air. The coolant level is good, the temperature gauage reads normal. Is it the heater core??? if so why don't i see any antifreeze leaking on the passenger side? any help would be great!
Larry Chandler
Level 3:
President:
  • Jeep Master 1,149 Answers
  • Posted on Jan 30, 2010
Larry Chandler
Jeep Master
Level 3:
President:
Answers
1149
Questions
0
Helped
451023
Points
3903
Hi:
You most likely have a partially blocked heater core, and at least it isn't leaking on the floor.
You might have sucess in trying to flush your cooling system, but often you end up replacing the heater core to fix the problem. Other possibilities are blockage of the air inlet on your heating system by leaves or other debris, but not likely in this case if you still have good air flow, but just not hot air.
2answers
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Heat is not acting right
If you checked properly and coolant/rad isn't getting hot, coolant is up to proper level, then I'd replace thermostat.
Heater blow air its luke warm on the passenger side and some what cooler on the drive side just not blowing hot all the time?
check your coolant level first low coolant can cause bad heat and check heater core to see if its cloged. i ussaly push water threw each side with garden hose.
2008 land rover sc warm up car turn on heat blower working warm air at first then clod no heat
When is the last time you change the thermostat and coolant?
Recommended interval is 2 years.
Coolant is the heat carrier to heater core.
Top off the coolant level for now and re-test.
Replaced thermostat and flushed out heater core 3 times 3 times it was cloggged, flushed system twice got good radiator flow and ther very hot just heat like luke warm one line in to core hot one oming out...
If the heater core is not damaged or leaking ie: if you don't see coolant on the INSIDE of your windshield or coolant on the floor inside the car then chances are you may just need to BLEED the radiator.
remove radiator cap
Fill coolant resovoir to the cold line if the engine is cold from sitting overnight.
Start engine with cap off
Wait till engine gets hot
While waiting you will see a big gurgle of air bubbles come out and the coolant level will drop
Fill the radiator with more coolant to compensate.
When the fans come on and it stops gurgling air install the radiator cap
You are done
Watch the coolant level for the next few days and top off in the resovoir as needed to keep it filled.
Your heat should be very hot now providing you installed the correct oem thermostat correctly.
Hope this helps
6helpful
No interior heat in my 2000 daewoo nubira
3 possible issues here,
the first is that your thermostat is stuck open, when this happens the air will barely be warm, luke warm at best, replacing the thermostat will fix this problem
the second, is that you have low coolant levels, when your coolant levels are way low, your heater core doesn't get the proper amount of coolant (if any) and the system blows cold air instead of heated air.
The third and final possibility, is that your heater core has clogged up (usually happens when stop leak or some type of radiator sealant is used) when this happens you can feel warm air when accelerating (test this by gently reving the vehicle and holding the rpm's when it is in park and holding your hands over the defrost vent to check for heat.
If you can tell me what symptom your vehicle is having I can help with instruction on how to fix it thanks [email protected]
2002 Wrangler Sport Blowing COLD air.
Have you recently changed / or added coolants? your Coolant system may need to bleed.
2004 Tahoe Heating Problems
Did you open the radiator cap and make sure the radiator is full of coolant? Sometimes the hose from the coolant reservoir to the radiator becomes plugged, and the radiator will become low on coolant even when the plastic reservoir is full. Low water levels will prevent the coolant system from getting hot water from the engine to the radiator or heater cores. This will cause the engine to run hotter while the heater appears to not be working.
Heater with an attitude on my 1995 Chevy Blazer
It sounds like you have low engine coolant levels or air trapped in the coolant.
Top Jeep Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jeep Expert? Answer questions, earn points and help others
