Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
Webcam problems Hello, the built in web cam is very tempremental, it works some times and other times I have to reboot the laptop up again in order for it to work. It is located in quick player I select the webcam and a blue circle spins around in the middle of the screen, when it works a blue light comes on next to the camara lens. but when it doesn't the blue circle stops spinning and a box appears in the centre of the screen with the quick player logo on it. I'm lost from here. any Suggestions? thanx channa.
  • sergiodeysi Feb 18, 2008
    hola tengo una hp pavilion dv 6000 y cuando quiero abrir la camara hay veces que se abre y otras veces no funciona solo aparece un recuadro negro con un simbolo de espera pero al reiniciarla otra vez funciona. cual es la solucion?
  • 72 Answers
Try installing an updated driver for your webcam and updated driver for the video card for your laptop. go to driverguide.com and register then search for drivers. or you can go to the manufacturers website of your laptop and search for the software drivers.
Posted on Feb 18, 2008
Can't activate webcam in livejasmin
Built in web cam? Does the web cam work with the software e.g. - Microsoft life cam? If does not work at all could be out, get an external USB web cam. Could be a driver, could be the site or site settings.
I hope this helps.
Jan 22, 2013 | Acer Aspire One PC Notebook
Why doesn'tmy built in web cam not work
Possible that the drivers to the webcam was removed/ has errors or that the web cam hardware has failed.
Now you can try and reinstall the drivers once again, you can also open control panel>device manager and check on the web cam driver or reinstall.
If not the web cam can be faulty or there can be problems in the wiring to the webcam or a fault in the motherboard.
Aug 19, 2011 | Computers & Internet
My built in webcam is not working on Skype or any other messenger. The light doesn't even light up indicating that cam is working. It worked once after the computer has been upgraded from Vista to Windows...
My built in webcam is not working on Skype or any other messenger. The light doesn't even light up indicating that camMy built in webcam is not working on Skype or any other messenger. The light doesn't even light up indicating that cam is working. It worked once after the computer has been upgraded from Vista to Windows 7 but then after problem was reported from a viewer on skype saying that the image coming from the cam is pixelated the computer was rebooted and cam is not working since. ...
Solve this problem
Jun 24, 2010 | HP G60-230US Notebook
Toshiba built in camera not working properly
I found an article that suggests some more ideas to solve webcam problems. Maybe one of them will help in your situation.
Jan 05, 2010 | Computers & Internet
Built in webcam not detected..
Please do not worry so much as this just requires you to run system restore to factory setting. It was tampered with errornously.
Rate this.
Mar 20, 2009 | Computers & Internet
Webcam problem
see if it is a driver problem or hardware problem first. first try and see if u uninstall the driver and reboot does the system detect it again?
if not goto nearest vaio service center and get it fixed for free if u hav warranty . i did
Feb 18, 2009 | Sony VAIO VGN-CR220E/P Notebook
Cant turn my built in webcam on??
This is known Webcam issue in DV6000 notebooks. To resolve or narrow down the issue, we have to check few things.
First open Device Manager.
Please follow these steps to open Device Manager:
1. Right Click on 'My Computer' icon on Desktop and choose Properties.
2. The System properties Window opens.
3. Click Hardware tab and then click the Device Manager button.
Expand + Imagining Devices and check if the HP Webcam is listed under it.
If Webcam is not listed there, then you have to contact HP to get the BIOS update.
If it is listed there, right click on it and select Disable. Again right click on it and select Enable.
Now open any applications like Quickplay and check if Webcam is working or not.
Please reply me if that won't resolve the issue, I can provide more work arounds
Aug 09, 2008 | HP Pavilion dv6000z Notebook
Aspire 5720 cam not working
In saying this I may sound more like a little devil instead of the angel you're looking for. Go get an external web cam. This will be much easier than the headache you will have with the Acer built in. There are more problems with Acer's built in web cam than any other device on the market, and it's nor just limited to one or two models, it's every model. They actually released their Aspire 5000 series to the public, Vista only, before they had Vista compatible web cam drivers. The problem isn't with the cam itself, it's with the drivers and software that it needs in order to work properly. The software/drivers glitch and conflict with other components in the system. Every driver, software application, update, patch and fix are temporary and therefore worthless. Every time you get it back up and running, eventually it will (out of the blue) crash again, and what worked before to fix it may not work the next time. It's extremely frustrating, I know. Ive tried everything to get these up and working properly for my customers, and I've found that currently, until they come up with better drivers, the only true fix is an external. I'm sorry, I know this isn't what you want to hear, but unfortunately there is no ctrl+shift+miricle key cure at this time.
Jul 17, 2008 | Acer Aspire 5610-4648 Notebook
HP Pavilion dv6000 Webcam problem
Download Quick play if you can i havent tride this before so i dont know if it will work hope this helps. =]
Feb 10, 2008 | HP Pavilion dv6000z Notebook
My msi laptop wont detect my webcam
Hi lilcharlie..
Reinstall your driver by using this driverupdate us tool. It will takes 2 mins... after updating, go to webcamtoy.com/ and make a quick test
I hope I have helped you...
Jan 10, 2008 | Computers & Internet
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
