Question about Epson TM-T88III Thermal Printer
Invalid operation 425: the printer cannot be accessed. It may be locked by another application.
  • 1 more comment
  • joyceleedy Jan 31, 2010
    I've done what you suggested already. But it didn't work. I think there is a virus and the computer just died (won't boot)
    thank you!
  • joyceleedy Feb 02, 2010
    I actually got the computer rebooted again. Still getting the same error message
    when trying to print a receipt...even after changing the setting to "share OPOS printer with other applications."
    Hopefully you have some other tricks!
  • joyceleedy Feb 04, 2010
    Did both, still doesn't work...same error.
    Thanks!
    Brigadier General:
  • 4,090 Answers
When you're printing, is your Store Manager open? You might not have closed the POS application properly.
If Manager is open while you're printing, try closing your manager
then, launch your POS and create a transaction. See if the error is
still there
Posted on Feb 05, 2010
    President:
  • 3,278 Answers
Hello, Joyce.
If this is used by multiple users, be certain that others are logged out (and PCs shut off if necessary).
Also, from Epson Support: be certain to set to share the OPOS in SO Mgr config. This is under SO Mgr> File> Config> Options> POS Options> 'Share the OPOS printer with other applications'.
Hope this helps.
Posted on Jan 30, 2010
  • NinaE Jan 31, 2010
    Hi, Joyce.
    Here are some suggestions for a non-booting computer:
    Either you have a memory issue or operating system problem.
    First, disconnect all cables. Be certain to dispel static electricity by touching metal. Remove the cover. Try reseating (removing and reinserting) your memory (try one module at a time to test).
    If still a problem, boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
    If you can't access System Restore by Safe Mode, try Offline System Restore:
    1. Boot from the DVD
    2. Select the Language
    3. Click on "Repair your Computer" on the Install now screen
    4. Click next on the System Recovery Options screen
    5. Click on System Restore.
    6. Choose the date to which you want to restore
    If still a problem, the last choices are Factory Restore and reinstall. Accessing Factory Restore (restores to the factory settings and will wipe out anything that you have installed or saved on your PC), is dependent on your hardware manufacturer. Boot your system and press F10, F11, Alt+F10, or Ctrl+F11 to access Factory Restore. Follow the prompts.
    If still not resolved, you'll probably need to reinstall your operating system.
    Hope this helps.
  • NinaE Feb 03, 2010
    Hi, Joyce.
    I'd suggesting running anti-spyware and anti-malware. So, download, install and run these 2 free programs: http://www.spybot.com and http://www.malwarebytes.com
    Again, hope this helps.
49 4C02 - error
From looking online this message indicates the following: "A critical firmware error has occurred that caused the processor on the formatter to abort operation. This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some cases, electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables, poor connections, or homegrown applications."
The advice for resolving this issue is as follows:
1. Press CANCEL JOB to clear the print job from the printer memory.
2. Turn the printer off and then back on.
3. Try printing a job from a different software application. If the job prints, go back to
the first application and try printing a different file. If the message appears only with a certain software application or print job, contact the software vendor for assistance.
4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or PC.
5. Turn the printer off.
6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
7. Remove all EIO devices from the printer.
8. Turn the printer on.
9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each
device.
10. Replace a DIMM or EIO device if you determine that it causes the error.
11. Remember to reconnect all cables that connect the printer to the network or computer.
12. If the error persists, replace the firmware DIMM.
13. Replace the formatter and calibrate the printer. See Calibrate now.
Hope this helps.
Nov 20, 2012 | HP LaserJet 4345mfp Printer
Error 49.ff04 for hp cp 3525x
Normally caused by firmware.
This error can be caused by corrupted print
jobs, software applications issues, nonproduct
specific printer drivers, poor-quality
USB or network cables, bad network
connections or incorrect configurations,
invalid firmware operations, or unsupported
accessories.
Power cycle the printer. Try printing from a different application. If the error doesn't come back, it could have been caused by the other application. If it does return and you are sure that your cables(USB or network) are good, you will probably have to upgrade the firmware.
Jun 28, 2011 | HP LaserJet P4015N Printer
What causes an error 49,2F9D on a HP LaserJet P3005N Printer
Hello thanks for using FixYa
This is a critical firmware error that occur which cause the processor on the formatter to abort operation.This type of error can be because of invalid print commands,corrupt data,or invalid operations. Sometimes electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables or poor connections,
To solve this try this solution step by step
  • Turn the printer off and then back on.
  • Try printing a job from a different software application. If the job prints, go back to
  • the first application and try printing a different file. If the message appears only with a certain software application or print job, contact the software vendor for assistance.
  • f the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or PC.
  • Turn the printer off.
  • Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
  • Remove all EIO devices from the printer.
  • Turn the printer on.
  • If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each
  • device.
  • Replace a DIMM or EIO device if you determine that it causes the error.
  • Remember to reconnect all cables that connect the printer to the network or computer.
  • If the error persists, final option is replace the firmware
    I hope this solution will helpful 4 u
    Please don't forget to click on Four thumbs which are given below if it is helpful
    THANKS & Keep Using fixya
Feb 16, 2011 | HP LaserJet P3005 Printer
Xerox 425dc service code
Hi.
The 425 dc error code refers to the department code assigned to the printer.
425 means that you have entered an invalid department code.
to fix this, you need to turn off the department codes
To do this, press the menu button so that it says machine defaults
then use the arrow down scroll button until you get department codes, then press enter
Scroll down to select off, and then press enter again.
Now press the features button to return the printer to a ready state.
You should now be able to print on the copier again.
I hope this helps you out.
Feb 08, 2011 | Xerox WorkCentre Pro 416Pi All-In-One...
49, 4c02 error in hp 4250
This is what the result for that error code is:-
ERROR 49.XXXX
A critical firmware error has occurred that caused the processor on the formatter to abort the operation. This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some instances, electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables, poor connections, or specific software programs. Remove all EIO devices and firmware DIMM if installed. Restart printer. If error is gone replace each EIO device until error appears. Replace device which triggers error. May also be formatter.
Firmware updates are available for some machines at http://hp.com and clicking on the drivers and software tab. Also try printing from a different application. If that works go back to the first application and try printing a different file to determine if the problem is file related. You may need to reseat the memory DIMM's or replace the firmware DIMM or formatter board.
Feb 08, 2011 | HP LaserJet 4250dtn Printer
ERROR 49 DE LASERJET 1522 MNF
  • device.
Jan 25, 2011 | HP LaserJet M1522nf Multifunction Printer...
Error core: 49. 4 C02 service error?
  • device.
Jan 19, 2011 | HP LaserJet 4250dtn Printer
4C02 Service error?
49.XXXX PRINTER ERROR
To continue turn off then on
No error message will be in event log.
A critical firmware error has occurred that caused the processor on the formatter to abort operation. This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some cases, electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables, poor connections, or homegrown applications. On rare
occasions, the formatter is at fault, which is usually indicated by a 79 Service Error.
device.
Jan 07, 2011 | HP LaserJet 4350dtn Printer
I have a epson tm t8iiip printer when trying to
Store OPs require OPOS software be installed and the printer and drawer setup within it.
Jan 23, 2010 | Epson TM-T88III (C420863)
HP 4350 ERROR MESSAGE: 49.2F90
he printing operation has been aborted.
The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications.
Action :
1> Press Cancel Job to clear the print job from the printer memory.
2> Turn the printer off and then on to clear the error message.
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job,.
Mar 15, 2008 | HP LaserJet 4350 Printer
Epson TM-T88III Thermal Printer Logo
1,302 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
