Question about Panasonic Video Cameras
Why does the camcorder say check tape when I press record.
  • 668 Answers
It indicates that tape is not placed properly or the tape is damaged and it is not being detected by the camcorder , Try with another new tape and check whether it is being detected properly.
Hope this helps .
If you still have any queries repost with proper details like model number of your camcorder ,so that we can guide you in right direction.
Posted on Jan 30, 2010
Camcorder won't record
Check the tape and make sure the record tab is still on the tape and has not been removed. If the record tab has been removed then use a new tape for recording as the unit will not record. This tap is usually on the lower left end of the back of the tape. When the tap is present it closes a record mode switch letting the system know the tape is able to bv recorded on..
Dec 27, 2009 | RCA CC6363 Camcorder
No video displayed?
Throw a new tape in, record then playback right away, then you'll know for sure if it's the camcorder or tapes for erased.
Dec 15, 2017 | Samsung SC-L700 Hi-8 Analog Camcorder
Connecting zr85 to vcr to record vhs tape to dv or sd card
I also have a Canon ZR-- left of the lens and the built-in microphones, there is a small panel that opens to reveal several ports. The middle yellow one is the AV In/Out. You can plug in the cable that came with your camera. One end looks like a microphone plug, the other has 3 RCA type plugs- red, white and yellow. These get plugged into your VCR's OUT plugs on the back of the VCR. Place a tape in the camcorder, open the LCD panel and push the REC PAUSE button. On the VCR, press the Play button. When the tape reaches the point you want to begin recording, press the camcorder's Play/Pause button. When you want to stop recording, press the Stop button on the camcorder.
This is also detailed on page 82 of your manual, manuals are available online at Canon.com. Your specific manual is at: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=174&modelid=9739#DownloadDetailAct
Hope this helps.
Nov 20, 2007 | Canon ZR85 Mini DV Digital Camcorder
How to Record From a TV Using PV-GS13?
connect a lead via your tv video out audio out jacks. Select tha appropriate channel (You may have to go through the av channel on you tv and tune in the channel you want to record) or, video or dvd player audio out video out jacks. connect other end to your camcorder. Select on the camcorder menu video in audio in. Turn on tv. If connected to video or dvd player, press play. Press record on your camera. When finished recording press stop. Presuming the camcorder is tape, you can buy a tape adaptor to play or record your mini tapes in a standard video recorder, then take them out of the adaptor and play them back on your camcorder. You can also do all this via a computer. Also if the camcorder is disk or hard drive it can be used the same way as a regular dvd recorder to record tv programmes once connected to you t.v. Let me know how you go 26 red
May 08, 2007 | Panasonic PV-GS31 Mini DV Digital...
Record button doesn't function
You may want to check the record lockout safety switch located on the tape. This button can get moved by accident and the camera will refuse to record on that tape. Also, be sure the camera is in "video" mode, not "photo" mode. Some of Canons camcorders have a digital still camera mode which stops the camcorder from functioning because the photos are being recorded to a memory card and not your tape, please check this swithc as well. Good luck. Joe Weibel customelectronics.org
Feb 26, 2007 | Canon Elura 65 Mini DV Digital Camcorder
LCD won't project
You may have a problem with the image sensor device (CCD). From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling from and to addresses within the United States and US Territories for service to correct this issue. To see if you have this problem: Power On your camcorder (make sure the battery is fully charged). Check the LCD screen and verify that the display icons are turned on. If you cannot see the icons, press the Display button until the icons are visible. Put a tape in the camcorder. With the lens cap off, record some video. NOTE: Be sure to speak during the recording so the video will contain your voice. Rewind this section of the tape (using tape counter to verify start of your recording). Play back the recorded video and use the LCD screen on the camcorder to view it. You should hear the audio you recorded and the Display icons/text will still appear. If your camcorder is affected by this CCD issue, the picture will either be extremely distorted, or there will be no visible picture (just a blank LCD screen with the display icons still visible).
Mar 22, 2006 | Sony Handycam CCD-TRV318 Camcorder
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Recording sound on video.
Audio Dubbing may vary by model. Most Digital Camcorders are equipped with this feature. To verify that your model is, please view the User Manual. Audio Dubbing * The AUDIO DUBBING function only works in PLAYER Mode. * You can add sound to the original sound on a pre-recorded tape, recorded in SP mode with 12bit sound. * Use the internal and external microphones or other audio equipment. * The original sound will not be erased. Dubbing sound 1. Set the camcorder to PLAYER mode. * If you want to use an external microphone, connect the microphone to the external MIC input jack on the camcorder. * When you wish to dub using the External A/V input, connect the AUDIO/VIDEO cable to the camcorder by inserting the cable jack into the A/V in/out terminal at the left side of the camcorder. - Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. - Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. 2. Press the (PLAY/STILL) button and find the timeframe of the scene to be dubbed. 3. Press the (PLAY/STILL) button to pause the scene. 4. Press the A.DUB button on the Remote Control. * A.DUB will be displayed on the LCD. * The camcorder is in a ready-to-dub state for dubbing. 5. Press the (PLAY/STILL) button to start dubbing. * Press the (STOP) button to stop the dubbing. Notes: * You can not use the audio dubbing function while playing a write protected video tape. * When you wish to dub using the External A/V input, you must connect the AUDIO/VIDEO cable to the audio system from which you wish to record. * You cannot dub sound on a pre-recorded tape in LP or 16 bit mode. Dubbed audio Playback 1. Insert the dubbed tape and press MENU button. 2. Turn the MENU DIAL to highlight A/V. 3. Press the ENTER button to enter the sub-menu. 4. Use the MENU DIAL to select AUDIO SELECT from the submenu. 5. Press the ENTER button to enter the sub-menu. 6. Using the MENU DIAL, select the AUDIO playback channel. Press the ENTER button to confirm the audio playback channel. * SOUND1 : play the original sound. * SOUND2 : play the dubbed sound. * MIX(1+2) : play back SOUND1 and 2 equally mixed. 7. To exit, press the MENU button. 8. Press the (PLAY/STILL) button to playback the dubbed tape. Note: When you playback added sound (SOUND2 or MIX mode), you may experience loss of sound quality.
I can't start recording.
# You may not have turned on the camcorder to record properly. For camcorders that feature both Automatic and Manual recording, make sure you press in the LOCK button while setting the POWER switch to the desired setting, either "A" (Automatic) or "M" (Manual) record mode. # Automatic recording places the camcorder into Auto Shot™ mode, while Manual recording mode allows you to control many of the camcorder's special features, including accessing the menus and setting the clock. # For many other camcorders, make sure the CAMERA/OFF/VCR switch is set to CAMERA. Make sure the Erase Protection tab is in the position that allows recording. If not, slide the tab. Some tapes have removable tabs. If the tab has been removed, simply cover the hole with adhesive tape or use another tape.
Sep 06, 2005 | RCA CC-432 Camcorder
DV-PC recorder
DV-PC Recorder is a Windows XP only application that enables you to record images and sound on the tape in the camcorder and on the computer's hard disk by connecting a camcorder equipped with the DV CONTROL function to a computer using an IEEE1394 (DV) cable. DV-PC Recorder has the following features. 1. You can record movies simultaneously on your computer's hard disk and on the tape by pressing the start/stop button on the camcorder. 2. It enables long, continuous recordings, which you cannot achieve with the tape alone. (Approximately four and a half hour's worth of recording will fit on a 60GB hard disk.) 3. You can start editing the movies on the computer right after recording, as the images and sound are saved on the computer's hard disk. (Optional editing software is required to edit movies) 4. You can record movies on the tape in the camcorder and on the computer's hard disk by controlling the DV-PC Recorder from your computer.
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Video Cameras Logo
22 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
