Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Cant get computer to take security key number
  • 2,260 Answers
What is the Operating system on the laptop ?
Sometimes on Windows 7 it will not accept the network key?
You will need rto change the security type to WPA
Change the wireless channel to 6.
try to change the SSID also.
then try to connect to the new network and see if that works.
You will need to open the set up page of the router.
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
click here for more info about routers and network
Posted on Jan 30, 2010
Forgot my network security key, so cant work on other computers....except on the one it has been installed
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless ) on all your computers
Let me know if it works
Dec 22, 2010 | Belkin F5D7234-4 Router
Cant find my cd that came with it, can i still use it to connect another home computer
Hi i got your issue ......
Yes you can still install the other computer without the cd
Step 1: If it is a wired computer just connect it hardwired to the router
Step 2: If it is a wireless computer connect modem>>router >>computer
Step 3: Open the browser page and on the address bar type http://192.168.2.1
Step 4: Towards the left column below wireless click on channel and ssid
Step 5: Select the wireless channel as 11 and then click on apply changes
Step 6: Below channel and ssid click on security and select the security mode as 64 bit wep
Step 7: On key 1 type any 10 numbers and make note of those numbers that will be your security key
Step 8: Then click on apply changes
Step 9: Now towards the left column click on wifi protected setup below security if its asking for password just leave it blank and apply changes
Step 10: Then disable wifi protected set up
Step 11: Now try connecting wireless -hopefully this would work
If you have any issues contact 24/7 belkin technical support 1800-2235546
Thanks .....
With regards...
Priya
Oct 21, 2010 | Belkin (F5D7230-4) Router (587009)
I cant remember my belkin router password to enable me to connect to the internet with my laptop. What should i do?
The easy way to get password is to left click on Internet access bars near time on computer.When box appears showing wireless connections right click on your name connected to.In drop box choose properties then under security click show characters to reveal password.Hope this helps please rate
Oct 07, 2010 | Belkin (F5D5231-4) Router
Wireless card on packard bell laptop not working
I believe your problem is the network key, you changed it most likely. And you are now locked out of the network. The "key" in your computer must match the "key" in the access point (wireless router). WEP is a security protocol that runs on the wireless link. The 169 number tells me your wireless adapter can not create a link between it and the wireless router. So you are not connected. You'll need to get the "key" from the wireless router. Try entering 192.168.0.1 (that a guess on my part as to the number, generally this is the gateway address) as a web address on your desktop and look at the security settings in the wireless router.
Or else, restart the router and try to connect it again.. Anyone of this should work
Apr 20, 2010 | Computers & Internet
Cant connect netgear router wants security key i
Sometimes the security key is on a sticker underneath unit, if not reset router to factory defaults by holding in the reset button at rear with a pencil or something similar.
Mar 17, 2010 | NetGear WGR614 Wireless Router
Im reading the security key is below the serial number but that number dont work cant esthablish wireless connection
Click here for step by step instructions
Jan 29, 2010 | 2wire 2700HG-B Router (2700HGB)
Cant find security number
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here for step by step Instructions on how to find the network key
Dec 14, 2009 | Netopia 2247NWG-VGx Wireless Router...
I cant enter access code when panel is open
Hi, after you drop down panel door number locations chage look for small red numbers buy keys after you drop down door.
Dec 29, 2008 | GE Security Simon 3 Wireless Home Security...
HOW DO I FIND MY NETWORK KEY NUMBER ?
Unfortunately, you cant 'recover' your network password. You will need to reset the router and apply a new password. In order to do this, you need your laptop or computer near the router and an ethernet cord connecting the two. Simply follow these directions.
1.) on the back of the unit is a small pin hole with the word RESET above it. hold this down for about 30 seconds. this is a hard reset.
2.) connect your pc to one of the routers ports and open your browser (no worries if you cant get to perezhilton.com yet, it will only take a moment)
3.) in your browsers address bar, type "http://192.168.1.1". This is the URL to access the router.
4.) you will see a popup box which asks you to enter a username and password to login to your router. The default username and password will be either:
a.) username= [blank] ; password= admin
b.) username= admin; password = admin
5.) Once you re past the login screen, you can reconfigure the router.
6.) Go to the management tab and chance the admin password to something else so other people cant access your router.
7.) Your router should work after you apply these settings and restart your computer but i HIGHLY suggest enabling either WEP or WAP security.
Dec 01, 2008 | Linksys Wireless-G Broadband Router
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
99 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
