Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Panasonic PT-47WX53 does not turn on
When I press the power button on my Panasonic PT-47WX53G tv, nothing comes up. Could someone please tell me the problem with my TV and a solution to fix it.
I appreciate your help.
Thanks.
  • 3 more comments
  • Carrie Scheidt Mar 24, 2008
    CAN'T TURN ON OR OFF GET 3 RED BLINKS EVERY FEW SECONDS WHEN I TRY TO TURN ON OR OFF SCREEN IS BLACK AND NO AUDIO I HAVE CHECKED OUT ELECTRICAL AND OTHERS!
  • oddjohnny Mar 25, 2008
    I also have the Panasonic 47" HDTV. It does not turn on and the red light blinks three times. The manual says it has to do with the convergence circuit. What exactly can the problem be and how can I fix it. I have plenty of mechanical and electronics/ computer experience. I an confident I can fix it with some guidance from an experienced person with this problem.
  • Anonymous Jun 23, 2008
    when i turn the power on you can hear it come on but then it turns right back off
  • jcpape911 Feb 04, 2009
    I have the same exact problem. Someone please help!
  • Corey Knoettgen
    Corey Knoettgen May 11, 2010
    Try pressing the power button on the tv set itself, just to make sure that you do not have a bad remote.
    If still no picture, do you get a blinking red light of any kind? Does the menu appear on the tv screen when you press the menu button on the tv set itself?
I am having a problem with my Panasonic Cinema Vision,HDTV PT-47WX53G 47 in. I was watching TV, and had to step away for a moment. When I returned to TV, I could hear it but I couldn't see anything but a black screen and in the middle of the screen running from top to bottom of screen I see what I would call colored lines in the shape of a tornado(spiral like lines) but running same size from top to bottom of screen. I hope whoever reads this understands what I'm trying to say.
Posted on Mar 13, 2011
I HAVE PANASONIC TV DO NOT TURN ON AND HAVE A RED LIGHT BLINKING
Posted on Jun 19, 2010
Http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jun 03, 2008
Yes, I did try to use the power button on the TV itself. That did not work too. Yes, there is blinking red light too. I searched through several sights and found out that it is an issue with the IC 4511. I could not find a place to buy the chip.
By the way, our local TV dealer asked for $400 to fix this issue. I had already spent $400 on a different repair on this TV, 6 months ago.
Any suggestion/advice would be very helpful. Thank you again for your response.
Posted on Mar 09, 2008
  • 8,596 Answers
Have not heard back. Need to clear my queue.
Posted on May 30, 2008
Pt-47wx53g tv won't click over n than the power button will blink 5 times
IC4511 has failed on the DG board replaing the DG board as a unit i the only way to fix the issue. The DG board isnt serviceable
Jun 01, 2012 | Panasonic PT-47WX53 47" Rear Projection...
My Panosonic TV Model# PT-47WX53g has sound but no picture
Part is C509 located on D board:
It is a .47 @ 200 volts and the location is marked top and bottom on the board.
Examine the attached photos (cap has been removed but you will see exactly where it is located).
Let me know if you have questions
Jan 17, 2012 | Panasonic PT-47WX53 47" Rear Projection...
I need a lamp for a Pt-47WX53G set with an AP825 chassis. Can someone give me the correct part number?
This is a rear projection TV set. Therefore it has three CRT's in it and not a lamp or bulb like you see in a DLP tv. If tv isn't turning on it is most likely a convergence or power supply issue.
If you think you need a CRT then the part number is on the side of the CRT at the top. These are not easy to replace and are quite dangerous to handle if you have no experience.
I would not recommend any novice to attempt a CRT replacement.
Feb 24, 2011 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic CinemaVision PT-47WX53G : half the screen is distorted
did you try to try to adjust the vertical and the horizontal of your tv?
Oct 05, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT 47WX53G does not turn on
If the indicator blinks three times its the error for the convergence ICs and resistors. You can get the right repair kit for your model at the following link which contains the Two ICs the 6 feed resistors and detailed step by step instructions with pictures.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
Jun 10, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Replace STK392-110 IC's ( both ) with PANASONIC part
# C5AA00000203.........DO NOT use generic IC's !
Terry.
Jul 22, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic pt-47wx53g
How many times is it blinking? That is probably blinking a code because its shutting down. Let me know how many blinks its blinking and I will be able to tell you whats wrong with your TV
Apr 12, 2008 | Panasonic PT-47WX53 47" Rear Projection...
How to reset defaults Panasonic HD PT-47WX53G TV/picture
First of all are you sure you were in the factory menu this step requires alot of known how!!!!!! By using your hand unit only customer controls can be reached unless you know factory menu setup. Which starts like this ,make sure antenna to cable then go to menu set sleep timer to 30 mins exit out now enter ch 124 then press v- down on tv you should now see on top CHK ,also these sets have double convergence patterens.if you were in factory set up for more information look in www.freelists.org techassist/09-2005 .let me know if you still need help.
Nov 14, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
421 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
