Question about Hotpoint Dryers
How to remove the lint inside the dryer - Hotpoint Dryers
    Problem Solver:
  • 14 Answers
Take the back off and take a shop vac you can blow the lint out
Posted on Jan 31, 2010
How do I get into my whirlpool duet front loader dryer to clean the lint out
Hello. First, turn the power off to the dryer or remove the power cord from the AC outlet. Next, locate the 2 screws in-between the upper and lower front panels and at the bottom front of the dryer--there will be 2-3 screws, usually 1/4 inch hex head, and remove them--use a magnetic nut driver, it makes it a whole lot easier! (note:sometimes, to replace the panel, you have to push up on the bottom of the panel hard to get the screw holes to line up again.) Set the panel aside. Open the dryer door and remove the lint screen from the holder. Close the door. Next, notice the blower housing cover, pic 3, #45, lower left corner. There should be 3-4 screws holding the cover to the blower housing. Remove the screws and cover--use caution--most metal edges inside a dryer are unfinished and razor sharp--akin to putting your hand inside a box of razor blades(ask me how I know this, lol). Remove any lint build-up inside the cover with a vacuum. Again, using a vacuum, suck out any lint from inside the blower housing and fan as best you can. Take care to not damage the fan blades! Now, try to remove as much lint build-up as you can with the vacuum. Be especially careful when vacuuming around the mouth of the heater element. Do the best you can. At this point, re-assemble the dryer using the reverse of assembly. If there is still a lot of lint inside the cabinet and you can't reach it--STOP! In order to remove the remaining lint requires removal of the front bulkhead(large metal plate that supports the front of the drum), drum belt, and drum from the cabinet. This is INVOLVED and can be very difficult to re-assemble if you have never done it before. Call for service. I hope I helped you!
Oct 02, 2015 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Harmony Dryer
WOW.I would recommend not to use dryer until you have someone check this out .Please unplug and do not use .Its possible the ball of lint got caught somewhere in dryers mech and or drive parts ..If you get that removed ,while were there ,Its a good time to vacuum and clean the inside for other lint inside..Get that checked out quick as you need that dryer for winter.....take care
Dec 10, 2007 | GE Profile Harmony DPGT750EC Electric...
Ge sensor dryer stops after minutes
I suspicion you problem may be lint.
In the last 6 months, I have taken apart 5 various brands of dryer and found them filled with lint inside, often as much as 2 - 3 shoe boxes full.
This lint is only removed by dismantling the whole machine, as it is in the tubes for exhaust air between the hole in the rear and the blower fan inside.
Some dryer models are worse than others for collecting lint inside.
Be blessed..
Feb 22, 2014 | GE Dryers
How do you wire the dryer MDE300AYW
Instructions
    • 1 Remove the lint screen from the dryer. If you are unsure how to remove the lint trap, refer to your owner's manual, as removal directions vary among Maytag models.
    • 2 Use your fingers to remove large chunks of lint from the lint screen. You should remove the lint from the lint trap after every load.
    • 3 Run the lint screen under the faucet. Use hot water and thoroughly wet down both sides.
    • 4 Scrub both sides of the lint screen with a wet nylon scrub brush. Rinse the screen again under hot water to remove loosened buildup. Allow the lint screen to air-dry on a towel before putting it back inside of the dryer.
    • 5 Make a paste of powdered laundry soap and warm water into a small bowl. Use three parts powdered detergent to one part water. Stir with a spoon until a paste forms.
    • 6 Dip a soft rag into the paste. Wipe down the entire interior of the dirty Maytag dryer with the rag and paste. Apply more paste to the cloth as needed.
    • 7 Rinse the interior of the dryer with a damp rag to remove the paste.
    • 8 Dry a load of damp towels in the Maytag dryer. Run a complete dry cycle to remove any residue left inside.
    • 9 Wipe down the exterior of the dryer with a rag moistened with all-purpose household cleaner. You can also use the household cleaner to remove certain stains from the interior of the dryer. Make sure the cleaner you are using is noninflammable.
Jan 15, 2013 | Maytag Dryers
Dryer is taking too long to dry
Dryer needs to be cleaned. Unplug, take off back and vacuum all lint out of dryer, also take off vent and vacuum inside of vent area. Then clean dryer vent from inside of house to where it exits. Make sure all lint removed. Lint holds moisture and causes dryer not to be able to release steam caused by heating wet clothes, thus clothes don't dry.
Jun 09, 2010 | Kenmore 66972 Dryer
My electric dryer has heat but won't turn. How do I change the belt?
i'am guessing you have a top lint filter,remove it than remove the 2 screws,pull the top toward you and up,disconnect the door switch,remove the 2 inside screws,lift up and pull off,if this is not the top lint filter please let me know and i will tell you how to do the inside lint filter-mike
Feb 15, 2010 | Kenmore 62602 Electric Dryer
MY DRYER IS NOT RELEASING THE AIR OUTSIDE AND MY DRYER IS GETTING SUPPER HOT ON TOP
squished vent hose behind dryer, then clogged vent, then dirty lint filter, then lint built up inside dryer because of vent issue, after fixing vent issue, remove lint from inside blower area filter area etc.
Oct 25, 2009 | Whirlpool LER5636P Electric Dryer
Dryer has hot air but takes 2-3 hours to dry clothes. What can I do?
This is almost always due to lint build up in the vent pipe. pull the dryer out from the wall, disconnect the vent pipe. look inside the rear of the dryer and into the pipe. remove lint that is present. go out doors and examine the vent from that end. finally remove the lint catcher in the dryer and look in there. remove any lint you see.
Jun 22, 2009 | Dryers
I own a whirlpool gold dryer about 4 years old. I empty the lint catcher frequently. I noticed however, that sand has accumulated inside the dryer, I hear the sound when the dryer starts tumbling. How...
not as hard as it will sound here we go
remove the lint filter
remove the 2 phillips screws at the filter housing top you will see these screws after you have pulled out the lint filter
unplug the dryer
remove the back panel
on the left side is the lint filter housing it is held in place with 4 1/4 inch screws remove them
lift up on the filter housing and pull forward you will find the sand inside the filter housing use a vac to **** it out and reassemble the dryer, no more sand
Apr 26, 2008 | Dryers
Frigidaire dryer
Most appliance stores sell a brush tahts on a 3 foot handle to remove any excessive lint form the lint trap.
Sep 16, 2007 | Frigidaire GLEQ642A Electric Dryer
Dryers Logo
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
