Question about Quinny Freestyle 3 XL Stroller
The bolt on side of handle bar has come off and lost. Would like to replace for baby #2.
Try contacting Dorel. They sent me a new screw out for mine free of charge.
Posted on Feb 21, 2010
  • 2,926 Answers
Take the bolt out from the other side and bring it to a hardware store and have them match it up if possible.
Posted on Jan 30, 2010
Tightening of handle bars on a bike. Never had a bike before and just got one off ebay and have had to bulid it. But the handle bars (the downward shaft part) keeps moving.
should be a counter sunk allan bolt on the back side of the handle bar facing downwards . set the handle bar as to were they fell comfortable and turn the bolt clock wise until tight.
Sep 10, 2009 | Cycling
Tricycle loose handle bars.
You need to install a shim so the bolt has more to clamp on. To do this, loosen the bolt you have been tightening enough that you can pull the handlebars out, then about 3 or 4 more turns. Get an empty soda can and with a pair of scissors, stab into the side of the can near the bottom and cut off the bottom end. Then cut about 2 inches up and cut around the can so you have a roughly 2 by 5 inch strip of aluminum. This is your shim (you may have to trim some length if it doesn't fit). Wrap it around the bottom part of the handlebars where it will go back into the part where the bolt is. Make sure you wrap it tight or it will be hard to put in. Slide the handle bar with the shim on it back into the other tube and tighten the bolt. The end.
Jul 13, 2009 | Huffy Cycling
How to fold
I believe that near the handle bars there is plastic tubing on the side metal bars. You pull these plasticy bits up (one has a metal lever under it to release) and they shoud then slide along the metal bar and splits the side bars into 2 halves which then fold down - easy peasy......
May 21, 2009 | Zooper Kroozer 3WD Air Jogger
How to fold zooper kroozer jogging stroller
I believe that near the handle bar on either side there is plastic tubing over the metal section. You pull the plasticy bit up towards the handle bar - one has a metal lever under which you release (lhs I think) this then splits the side bars into 2 parts and in theory it drops down neatly
May 20, 2009 | Zooper Kroozer 3WD Air Jogger
Cracked Foam Rubber Handle Bars
You can get some sticky back velcro and only use one side and tape it on there,i did this to my bob duallie,you can get black velcro like this at target or wall mart.
May 11, 2009 | Valco Runabout Deluxe Jogger
Bugaboo cameleon handle bar
HIYA.... YOUR BEST BET IS... TAKE THE HANDLE BAR BACK OFF AGAIN. TAKE THE SPRING OUT OF THE SIDE THAT WORKS FINE AND TAKE IT TO YOUR LOCAL DIY STORE AND GET A REPLACEMENT, IF YOU CANT FIND IT ASK SOMEONE IM SURE SOMEONE WILL BE ABLE TO SEND YOU IN THE RIGHT DIRECTION... PROVIDING ITS JUST THE SPRING, IF YOU BUY ANOTHER TO REPLACE THE BROKEN/LOST 1
THIS SHOULD SOLVE THE PROBLEM :)
Dec 08, 2008 | Bugaboo Frog Stroller
Replace handle bars
Mine had wiring inside the bars as well. Basically I removed the controls from the bars, and removed the 2 bolts holding the handle bars on. I removed the RIGHT side gas tank after draining it. I intended on cutting the wires to the connectors, pulling the wires out of the old handle bars, and pulling them back through the new bars. Note: Mark the black wires very carefully, since there were 5 black wires in the two connectors and they are all unique wires. The colored wires were easy, just match them back up. Several tricks I found on line. Use a string and a bolt to fish a pull line down through the new bars then pull the wire bundle through. This worked great on both left and right wire bundles. I then bolted the new handle bars in place and remounted the controls. I then replaced the shrink tubing up the bundles that hid the actual wires as they came out of the handle bars down to where I cut the connector wires, behind the right side tank. Next I stripped and tinned all the wires I cut (twist and get a little solder to stick on the wires) and stuck little pieces of shrink tubing up or down the wire so after I resoldered the wire I could shrink the insulation back over the splice. I picked up the shrink tubing and some extra wire a home depot. I had a soldering iron, and heat gun so away I went connecting the dots again. Litte tedious but hey. It saved me somewhere between $500 -$700 bucks which is what the harley shop quoted before I started. I tested each function, then reinstalled the gas tank and tightened up all the stuff. Below is the pin out in case you do loose a wire marker, like I did. Good Luck.
Nov 20, 2008 | 2008 Harley Davidson FLTR Road Glide
Replace handle bars
Nov 10, 2008 | Harley Davidson FLTR Road Glide...
Quinny Freestyle 3 XL Stroller Logo
139 people viewed this question
Top Quinny Baby Gear Experts
Jennifer Rock
Jennifer Rock
Oloyede Monsuru
ray gallant
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
