Question about LG Televison & Video
My tv has the captioning stuck on and the menu item for captioning reads as if it is off
  • 2 more comments
  • rddurecka Jan 30, 2010
    I have tried this in the past and it did not work
    I have a cable box hooked up to it along with a a panasonic surround system.
    The TV is a LG - model number 42LG50
    The caption button continues to be greyed out on the menu of my TV. It reads as if captioning is off. My current setup includes a panasonic surround sound system, cable, and a 42LG50 model HDTV.
  • 1,596 Answers
I have seen this With a Number of Telivisions , Most Corrections are in the Menue that you Speak of. You Should Try INPLUGING Unit OVER-NIGHT so as to Reset it, Sorta FOOLING the TV Settings Menu this has Worked for me in the Past.
Posted on Jan 30, 2010
  • 201 Answers
might need more info to solve such as brand and model #. do you have cable or sat. box hooked up to it? some boxes have a separate closed caption feature which will run on your screen whether you select on your tv or not.
  • 3,230 Answers
Well first of all you can try to reset your TV, just remove the power cable from the main board and left it for 4 hours and check again..... if further you have the same problem then there must be some problem in the control board of your TV may be the control board shorted or have some carbon on the points... you need a multimeter to check the control board... please post comments for more help or information...........
Good Luck!!
Thanks
How to turn closed caption off
Go to the MENU and look for audio settings. There should be a menu item for closed captioning, and select Captions OFF. Then exit MENU.
Oct 07, 2014 | Sanyo 31" Tv Flat Screen W Larger Back...
How to turn off subtitles on a hitachi tv
This may depend on the signal source of the TV. If you are watching OTA TV (or your TV is interpreting the CC from the cable or satellite signal), then use the CC button on the remote. Alternatively, depending on your exact model Hitachi TV, try using the menu to find a Tools or Options sub-menu and then turn off the CC from there. This could be under a different menu item. If you add a comment with your model number, I'll be glad to give the exact menu steps.
If you have a set-top box (cable, satellite, digital-to-analog converter box, DVD recorder), the captions may be turned on at this source. Then you will need to disable the captions from that box. With a converter box, press the CC button on the converter's remote or enter the menus for that box.
With a Dish TV set-top box, press Menu on the Dish remote, go to Properties (item 9). Click Select and then go down to Closed Caption (item 6), and press Select again. The first item in this sub-menu lets you turn on and off the captions. Press the left button and then up or down arrow followed by Select to change the setting. For other sources, check the instructions for that device or add a comment with the specific source for a solution for that device.
I hope this helps.
(the Dish CC procedure is for the box I have to deal with; I can't guarantee that updates/model changes have not changed the procedure.)
Jul 15, 2012 | Televison & Video
I haven't been able to put closed captioning on tv. I don't understand how and what code to use to get the closed captioning to work.
Enable Caption Using the Original Remote
  1. Press the [CCD] button to change the CCD mode.
  2. Using this button will set the Closed Caption mode when viewing a DTV or TV channel.
Enable Caption Using the TV Menu
  1. Open the Menu screen, select the third icon, in the middle, this is the Setup Menu.
  2. In the Setup Menu, choose the Caption option.
  3. Caption: There are three items in it - Analog Closed Caption, Digital Closed Caption and Digital Caption Style
  • Analog Closed Caption: CC1, CC2, CC3, CC4, TEXT1,TEXT2, TEXT3, TEXT4.
  • Digital Closed Caption: Service1, Service2, Service3, Service4, Service5, Service6.
  • Digital Caption Style: There are two Caption Styles. One is the automatic function set as the broadcaster, while the other is the custom style where you can adjust the font size, color, opacity, background color etc., accordingly.
Mar 10, 2011 | Element ELC-HS321 32 in. LCD TV
My tv is stuck in a closed caption screen
CLOSED CAPTION SELECTION SLEEP 10 To cancel the sleep timer: Press the SLEEP button repeated-ly until "SLEEP 0" is displayed. You may view specially labeled (cc) TV pro-grams, movies, news, prerecorded tapes, etc.with either a dialogue caption or text displayadded to the program.1) Press the MENU button so that the menudisplay appears on the TV screen.2) Press the CH(annel) ▲ or ▼ button to pointto "CAPTION".3) Press the VOL(ume) ▲ or ▼ button to selectthe mode you wish.4) When done, press the MENU button to exit the menu
Then turn OFF.
I also include your user manual below. It's easier to read in there.
www.symphonic.us/pdf/om/ST413C.pdf
Aug 21, 2010 | Symphonic ST413C 13" TV
My brand new Insignia tv has closed captioning that will not turn off. I followed the instructions in the manual but the menu item under settings can not be selected. Please helpw
You can use the TV buttons to get access to close caption by pressing menu. go to features make sure that cc when mute is on.
then use the mute button on your universal remote to toggle to cc1 or off.
May 21, 2010 | Televison & Video
Cannot turn CC off.
Features preferences
Caption service
This allows you to select the Closed Captions service levels of analog
broadcasting to be displayed.
Closed Captioning allows you to read the voice content of television
programs on the TV screen. Designed to help the hearing impaired, this
feature uses on-screen ‘text boxes’ to show dialogue and conversations
while the TV program is in progress. Captions will appear on the screen
during captioned broadcasts.
& Select Captions service.
é Press the cursor right.
“ Select the desired Caption service:
• CC 1, 2, 3 or 4
Dialogue (and descriptions) for the action on the captioned TV program
shows on screen.
Usually CC 1 is the most used. CC 2 may be used for alternate languages
if they are being transmitted.
• T 1, 2, 3 or 4
Often used for channel guide, schedules, bulletin board information for
Closed Captions programs, news, weather informations or stock market
reports.
Not all Caption services are necessarily being used by a TV channel during
the transmission of a Closed Caption program.
Features menu
& Select Features in the TV Settings menu.
é Press the cursor right to enter the Features menu.
“ Select the menu items with the cursor up/down and adjust the settings
with the cursor left/right.
Closed captions
This displays the transmitted CC- or CS-text on the screen according to
your chosen CC or CS service in the Setup, Features preferences menu,
This text can either be permanently displayed (assuming that the
service is available in the broadcast) or only when mute is active.
& Press the cursor right after having selected Closed captions.
é Select On, Off or On during mute.
Oct 28, 2009 | Televison & Video
How do I get Closed Cptioning off my TV?
you have to go into the menu of unit find closed caption or CC.select item then turn it to the off position(you can read it on your screen)
Sep 24, 2009 | Astar LTV-42ASB 42 in. LCD Television
I do not know how to turn off the closed captioning on my son's orion tv set. I do not know the model type. I do know that closed captioning options are not on the menu.
If you have the original remote look for a button labeled "CC" or "Caption/Text" press this button till the screen says caption off.
Jul 06, 2009 | Televison & Video
How to turn off captioned?
Get into the menus, and pick the setup menu. The one at the bottom of the list. The first item is captioning. Use the +/- to change the value to OFF. Then use the menu button to exit, or wait for it to time out.
tom
Jan 31, 2009 | Proscan PS27123 TV
Televison & Video Logo
21 people viewed this question
Computer Repairing
Computer Repairing
