Question about Sharp R-230 Microwave Oven
My microwave will not start when it press the start button. How can I fix this?
  • Sharp Master
  • 9,047 Answers
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix - see this file) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so with a one-year guarantee.
Posted on Jan 31, 2010
Why Kenmore microwave oven (model 80089700) start/enter button not working while all other buttons works fine?
Safety system locking out the start switch. Door not closed, mode and timer not set etc.
Apr 10, 2017 | Kenmore Microwave Ovens
Microwave doesn't work after press the start button
Blown fuse inside the oven. If you can do electrical work, repalce it. I wrapped mine in aluminum foil as a quick fix, as I understand the very high risk of fire and possible death from doing so.
Nov 21, 2013 | Sharp R-408J Microwave Oven
How do I fix the programmed buttons 1 - 5, they stopped working? We can only use the 6 and above numbers.
You must dismantle the circuit board and check if some grease vapours between touch buttons and the the circuit film. Clean with some wet soft cloth.
Nov 13, 2017 | Whirlpool MH3184XP Microwave Oven
Setting the clock
hello,
simple to fix up your self please follow this instruction below
  1. Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
  2. Step 2 Set the clock by pressing the "Clock" button.
  3. Step 3 Turning the dial on the sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
  4. Step 4 Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the sensor microwave oven.
  5. Step 5 When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
  6. Step 6 Press the "Start" button to allow the clock to begin on the sensor microwave oven.
thank you for using fixya.
Jul 31, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave timer counts down super fast
try unplugging it for about 15 minutes. if that doesnt work, you might as well get a new one. i fix everything myself for just the cost of parts and i have found that what parts cost for a microwaves, its cheaper just to buy a new one.
Oct 17, 2009 | Sharp R-540DK Microwave Oven
''Press Clock'' but can't press buttons, then beeps with F4 error
F4
Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor
Sep 07, 2009 | GE Microwave Ovens
Start button
I have a related problem, my Siemens microwave/oven as soon as I press the start button brings down the fuse. I put up the fuse again, the clock is working, the light inside as well, but as soon as I set the microwave on and press the start button, it brings the fuse down again. Is this a problem with the siemens microwave or with my electrical installation?
Jan 09, 2008 | Microwave Ovens
Sharp R-230 Microwave Oven Logo
118 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
