Question about Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook
Dell i6000 - Pink Screen
Starting a week ago whenever my laptop's LCD would come back from any unpowered state it would have a pink/reddish hue that would gradually fade away to a natural tone.
One night, my screen simply lost power and went black. Rebooting yielded similar results -- it'd first turn pink then power off within seconds of booting.
Turning the brightness down as low as it can go prevents the LCD from shutting off, but everything is tinted a deep pink (and very dark as I have to keep the brightness low). Turning the brightness back up causes the pink to fade away, but the LCD shuts off shortly after.
This has been a great laptop, other than this. I routinely clean it's heatsinks, and it's never given me any trouble.
  • Anonymous May 13, 2008
    DELL INSPIRON 4150 XP, P4 2.00GHz, 512mb, 27GB, DVD+-RW PC NOTEBOOK_
    I have a wallpaper set on my desktop that is mostly white...when I turn the brightness all the way down via (fn + up/down key for brightness) the white will turn a light pinkish color (mostly at the bottom of the screen) ...when I turn the brightness all the way back up it goes away within 10 seconds...about a month ago the backlight in the screen completely failed allowing me to see just barely, to reboot the laptop with the backlight still malfunctioning, and perform a system restore...that seemed to bring the backlight back to working order and it hasn't happened since then, although I do still experience "pink screen" with the brightness level all the way down... what does this mean? That you for your time. --Regards
The red hue is usually an indication of the CCFL tube (backlight bulb) going bad. These can usually be bought for under $20 but disassembly of the LCD module to replace them can be quite a pain. Fortunately there are are quite a few places that you can send the panel to and have it repaired for around $100.
Posted on Feb 26, 2008
    Genius:
  • 3,587 Answers
You are losing video from the motherboard..could be the video chip, yet this sort of thing can happen with laptops.
Posted on Feb 18, 2008
Why does picture have a pink or reddish hue?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Feb 26, 2016 | JVC LT-42E488 Television
A few months ago, the LCD on my Dell Inspiron 1501 Laptop sarted appearing pink on start-up or when returning from the screen saver, then gradually brightening up to normal. About a week ago it stayed...
The symptoms you have described is definitly a faulty CCFL lamp.
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jun 27, 2011 | Dell InspironTM 1501 Notebook
LG E1940S Monitor displays with a pink hue. I am using with a T40 ThinkPad and XP
A pink hue is a sign the CCFL lamp is about to fail.
The CCFL lamp is a fluro like tube approx. 2mm in diameter that is located on the bottom edge of the LCD screen that supplies the back light to the screen.
Replacement CCFL lamp is available from this WEB site.
www.lcdparts.net.
Jun 04, 2011 | LG E1940S 19" LCD Monitor
Fuji Finepix V10 Red Pink Hue in pictures and on LCD
Sounds like the sensor ribbon has slightly come out of it's socket.
Just needs re seating
Jan 24, 2010 | Fuji FinePix V10 Digital Camera
Dull laptop screen back light
You may have a faulty CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
Dec 30, 2009 | Dell Latitude C610 Notebook
My monitor on my Dell laptop went completely black while I was on it. I have tried turning it off and back on, and the monitor is not working at all
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
www.ladparts.net
Nov 26, 2009 | Dell Computers & Internet
The screen of my XPS M 1330 notebook is dark. I can see my screen in the back ground and the computer works fine, I need a flash light to see the screen
You have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
www.ladparts.net
Nov 19, 2009 | Dell XPS M1330 Notebook
The laptop starts up with a pink hue
Make sure the LCD is completely attached to the system board. I've had them come partially out and cause this. If this doesn't help, your LCD and/or inverter could be going bad.
Dec 30, 2008 | Dell E176FP 17" LCD Monitor
Not a typical backlight issue
Hi!
You can check the brightness with AC in the BIOS and match it with running in battery or else, when you plug the ac adapter, the lcd goes dim, press and hold the FN buttong and tap the up arrow then reboot and try to see if it will still do it. But still the best way to do it is going to the BIOS by pressing F2 at the Dell logo startup.
Hope this helps!
Thanks,
Karlox™
Jul 30, 2008 | Dell Inspiron 1150 Notebook
Screen goes pink
First, plug a external monitor and toggle the screen to discard configuration or software problems. If the image displays correctly you have a problem either in the LCD screen or its connection cable.
Open the bezel and check for loose or damaged connection cable. Look specially next to the hinge, ON THE LEFT.
In case the problem is not the cable you might have to get a new LCD. You can have replacement parts and instructions here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ViewObjectID=56222
Jun 27, 2008 | Acer Aspire 5102WLMi Notebook
Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook Logo
2,240 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
