I have a Maytag LAT9416AAe washing machine purchased in 1999. We had several problems with the belts and motor pully over the years and now it is leaking. We are told that it is probably the bearings that are gone and it would cost at least $500 to repair. We thought these machines are supposed to last upwards of 25 years. Will Maytag stand behind their products and correct this problem?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 119 Answers
No but you need the bearing and seal kit if this is a maytag i do this job 4 250$ you need another tech.
Posted on Jan 31, 2010
Squaky noise in spin cycle
check the belt under tub from motor, belt is around a pully under tub to pully on motor
Oct 16, 2010 | Maytag PAV2300 Top Load Washer
Tip
Washing Machine, Apliance help.
Washer works great during the wash and rinse cycle,the agitator works fine for those but the drum will not spin on the spin cycle. A couple of things go on when the washer goes from wash to spin, the motor pivots, tightens the belt and the drum spins up to speed. I had the same problem on my Maytag, I replaced the belt and the pullys and it has been washing and spinning great ever since, The belts can be accessed by removing the front panel, or disconnecting the machine and laying it down, if you see a lot of fine black dust,(rubber), the belt is probably worn out, change the pullys also at this time, it is cheap insurance that everything will go well. make sure that the motor pivots smoothly, if it does not, correct this issue first and run it. That may solve your problem, A great website that i use for parts and info is www.repairclinic.com. They have parts diagrams for tons of appliances, and stock parts, I have used them many times in the past.
on Jan 04, 2010 | Washing Machines
Agitator will not spin easily from pully below or
transmission out buy new washer cost to great to repair 15 year old washer
Feb 03, 2010 | Maytag LAT3600A Top Load Washer
Belt won't stay on the pulley
These belts are really sensitive. Try messing around with it. Making srue that the belt isnt coming off the big tub pully. You tub pully isnt loose is it. Make sure the bolt that hold the pully onto the tub is tight on. Make sure the pully isnt loose. Inspect it for any small craks where that boltt tightens up. If the pully check out ok. Check the small motor pully as well. Make sure that isnt loose or anything. Pull on it if if its loose then thats you problem.. Inspect both pullys good. I would assume belt is in good shape right? If both pullys check out ok, then i would try to get the belt on and just mess around with it, spin the pully and if you se the belt starting to slip off adjust it as you keep spinning the pully....hope this helps
Jul 31, 2009 | Maytag Neptune Washer
Drum isn't spinning but motor is
check inner tub fastens, if they check ok, replace the transmission. note: you will need special tools to change this, if you have them great, if not, you would be better off calling a&e factory service for the repair, 18009059505.
Jun 25, 2009 | Washing Machines
Belt slipping off of pully on maytag neptune mah5500bww
I loosed the moter and the belt is staying on. However, my belt is cutting the tub when the belt is moving off the pully.
Apr 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Machine will not agitate or spin. Have replaced broken drive belt but machine only washed one load and now the motor just hums
hello it sounds like you have a frozen motor have you tryed spinning the pully by hand to see if you can spin the motor ? if your able to spin the motor pully by hand and it still is'nt turning when powerd on then your have a bad motor
Apr 05, 2009 | Maytag Performa PAV3200
WASHER WON'T WASH
Check the pully Cam if thats good. You have a bad tranmission. This warr. for ten years
Jan 31, 2009 | Maytag PAV2300 Top Load Washer
Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Oct 09, 2008 | Maytag Performa PAV2200
Washing Machines Logo
234 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
