Question about Grundfos Tank Alert 1 Alarm
Tank alert xt with 2 seperate float switches how to hook up?
Yamaha XT 125 R Motorcycles carburetor leaks
Hi, Anonymous and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
https://yamahaclub.com/forums/topic/34408-xt-125r-petrol-leak
Carburetor Carb Leaking Gas How to Fix Repair it Motorcycle Honda DIY...
http://gigi600.altervista.org/immagini/xt125r/XT%20125%202005_service.pdf
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xt-owners-manuals
Jul 15, 2013 | Yamaha XT 125 R Motorcycles
Hi I have a yamaha xt 125 x and the bike is struggling to hit 45 mph I have devil exhaust but it happened wen I bought new wireing loom an put on the bike used to hit 80-85 mph any ideas what's wrong
1. Inlet system air leak.
2. Enrichener valve not seated or leaking.
3. Damaged or restricted fuel tank vent system.
4. Restricted fuel supply tract.
5. Dirty or damaged air cleaner element.
6. Plugged bowl vent or overflow.
7. Worn or damaged needle or needle jet.
8. Vacuum piston assembly malfunction.
9. Loose or plugged main jets or passages.
10. Improper float level.
11. Accelerator pumps inoperative.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
https://yamahaclub.com/forums/topic/7132-seriously-slow-xt125-probem
Symptoms of Lean or Rich carb settings on motorcycle
Yamaha xt 125 service manual
Jul 14, 2012 | 2005 Yamaha XT 125 X
XT 125 R carburetor diagram
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on blue links below. Good luck and have a wonderful day.
XT 125 carburetor diagram Google Search
Yamaha XT125 Carb Tips Mikuni 3D6
http://www.yamaha-motor.com/assets/service/manuals/2010/lit-11626-23-37_xt250_2010_1680.pdf
Jun 14, 2012 | Yamaha XT 125 R Motorcycles
Overflow pipe leaking on carburetor 125 xtz yamaha
Carburetor is leaking gas out of overflow tube need help
carb overflow hose petrol shooting out
YAMAHA XTZ 125K Owner Manual
Apr 19, 2012 | Yamaha XT125 Motorcycles
Wont switch tanks
Try cleaning your fuel lines, fuel pumps if seperated at the tank, and fuel filters. If you have ever run out of gas in either tank, sediment from the bottom could have clogged the lines. Pump float might be stuck on an inner cavity or drain line inside tank. It may be switching, but if the float is stuck on something inside the tank, it will say it is empty when it is full. Tell me if this helps. I have recently replaced the entire fuel sys in my vehicle.
Nov 16, 2010 | 1987 Ford F 350
I have a yamaha xt 125 r and every time i am flat out it dies
Hi, Broozer123 and the usual suspects are:
derestricting XT125
Carburator Theory and Tuning
Yamaha XT 125R 2005 Service Information
Jul 21, 2010 | 2005 Yamaha XT 125 R
Rough idle
You are correct there is no float it is a diaphram type carb.
My suggestion is to remove the fuel tank and carb. as they are hooked as one and come off as one
Note what bolts will have to come off to do this.
Remove air cleaner first Locate the 1/2 bolt near the middle of the tank remove it
now locate the 3/8 bolt in front of the tank to the left of the spark plug and remove it
carefully remove tank and carb. assembly pulling it toward you slowly and watch what is still hooked up like the governor linkage angle tank slightly to allow linkage to come through the throttle shaft hole of the carb.
Once its removed take it to a bench with a phillips screwdriver in hand
Look down at the carb.and notice how it is fastened to the tank and remove the phillips screws that secure it to the tank now seperate carb. from the tank may be stuck pry up on it with a screwdriver to remove it.
see the rubber gasket between the tank and carb.? REPLACE IT. comes as a kit which is called a diaphram and gasket carb. kit. Clean the rest of the carb. while it is off find your kit and reverse this procedure and this should take care of your issue. Known clean fresh fuel to go back once completed.
Jun 04, 2009 | Mtd 22" Yard Machine Push Mower
Fuel gage wont read past 1/2 mark when using fuel
it is the pontimeter in the fuel sender you can buy it seperate from the whole assembly and they had alot of problems with them please rate -jeff
Aug 21, 2008 | 1998 Chevrolet C1500
Grundfos Tank Alert 1 Alarm   Logo
198 people viewed this question
Top Grundfos Electrical Supplies Experts
Treefrog15
Treefrog15
Gil Shultz
Tom Chichester
Are you a Grundfos Electrical Supply Expert? Answer questions, earn points and help others
