Question about Air Tools & Compressors
Blows air out of trigger - Air Tools & Compressors
  • 2,176 Answers
I assume this is a Bostitch tool and if so there is a broken o ring on the trigger valve assembly that needs fixed. Go to Bostitch.com with your model number and you can buy it online. If other than Bostitch give me the model number and brand and I will try and find a breakdown.
Posted on Jan 31, 2010
Hitachi 45ab blowing air out of trigger
If air leaks thru trigger as soon as you connect airline, replace the vinyl ball under the trigger stem. If air leaks when you depress the trigger, replace the small oring on the trigger stem. If air leaks slightly from plunger in front of the trigger valve, problem is inside of the gun. Remove the head and pull the large circular plate. Replace the large outer oring. Good luck
Feb 10, 2014 | Hitachi NV45AB2 Roofing Coil Nailer
Air blowes out the trigger when squezzed
the seal inside is ether out of place or cracked gun are cheap buy a new one
Jan 22, 2014 | Hitachi Nt50ae2 18 Gauge 34" To 2" Brad...
Stanley n60 trigger blow by
Sounds like o-rings. Have you tried replacing the o-rings?
Feb 14, 2013 | Stanley Bostitch Coil Framing Nailer
Model 734 1/2 in impact.wont blow air ,wont rotate,no tension on trigger.feel like problem may somehow be in trigger housing....
Yes, if you take it apart you'll find that the trigger isn't allowing air to pass through to the veins of the impact wrench. It's a relatively simple mechanism, where maybe something is broken inside.
If it were blowing air but the veins were stuck, I would say, lubricate it. But, if no air goes through it at all, then the trigger housing houses the problem part.
Have you tried to disassemble the air wrench?
Jan 21, 2011 | Chicago Pneumatic 1/2" Air Impact Wrench
Blowing air through trigger area. Need rebuild kit? Longer version...started blowing air out of small hole in left side of casing. Leaked oil out of there as well but still worked fine. This has been...
If the trigger still works to fire the single shot, then the o-ring kit should be sufficient. If the trigger area continues to leak air, then the trigger should be replaced as well. Keep the gun well lubricated as well.
Dan
Oct 02, 2010 | Duo Fast Duofast Cn350 Cn350b Sh Nailer O...
Looking for the packing that goes around the trigger stem to keep air from blowing out the bottom of the trigger.
I have used water valve stem packing inthe past with success. Get it at your ace Hardware store.
Nov 30, 2009 | Chicago Pneumatic CP7750 1/2" Air Impact...
My framing Bostitch air gun , model N95RHN blows
prolly clogged, buy a rebuild kit and use it making sure all parts are totally clean before reassembly. in the future be sure to drain your compressor at least daily after use (more on wet or humid days) to avoid this
Nov 14, 2009 | Stanley Bostitch Coil Framing Nailer
Air blows thru the trigger on both my finish nailer and staple gu
there is an o ring in the trigger valve referred to as a Purple o ring that is probably split. If you can find a air tool center that has them you will save a lot of money versus replacing the trigger valve. Let me know what you are going to do and I will help you with the removal of the valve.
Sep 30, 2009 | Stanley Bostitch Coil Framing Nailer
Just blows air when trigger is pulled.
Dave The rotor is too tight on the plate. Tap shaft with fiber mallet to open the clearance
Apr 07, 2009 | Impact Ingersoll-Rand 1 Inch Heavy Duty...
Air Tools & Compressors Logo
119 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
