Question about Kenmore Elite HE5t Washer
HF error code
My Kenmore Ellite washer gave an HF error code during prewash
  • 15,935 Answers
FH error indicates that either you have no water coming into the washer, or very little water. Since you can see it filling, the error indicates low flow. A flow meter
in the unit detects if 10.5 gallons fills the tub within 8 minutes; yours must not be. This will turn off the inlet valves and the error code will be displayed. Check the following:
- Make sure you don't have a siphoning problem. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
*The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
*The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
*DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
*DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
*The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
- Verify Drain Pump operation. Unplug the washer and take the lower panel under the door off by removing the three screws under the bottom edge. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Open the pump access and remove, once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
- Verify Flow meter operation and that the Pressure Switch hoses are intact and connected properly. Remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached. There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required in determining if the components are good or bad.
"F/H" indicates that either you have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Flowmeter and Pressure Switch - remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
Kenmore Elite hf error
May I have the complete model number, so we can get started?
Feb 03, 2014 | Kenmore Washing Machines
Kenmore he4t code hf
hf error stands for hot water not being detected, make sure both hot and cold water are open and not reversed. if unit overfilled and flooded garage, the is if with you pressure switch or pressure hose. remove to lid of machine and you will find pressure switch and hose to the right side, inspect hose for any pin holes, if ok, order pressure switch
Apr 03, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Error code HF
Washer displaying code message and tone sounds S "HF" 0Nater Inlet Problem--no water or insufficient water supply) Select PAUSE/CANCEL twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Are water faucets completely turned on? Are screens at inlet hose connection to washer clogged? Are water inlet hoses kinked? Are water inlet hoses frozen? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service. "F02" (Drain Problem) Select PAUSE/CANCEL twice to cancel the cycle, Unplug washer or disconnect power. Cl_eck the following: Is the drain hose kinked? ts the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96 in. (2.4 m) above the floor? = "SUD" (Suds Routine) When excessive suds are detected, a suds routine
Sep 23, 2010 | Kenmore Elite 45986 Front Load Washer
Whirlpool calypso clothes washer stuck on the "FL" for overfill code - will not reset after hitting stop/cancel or after unpluging - one year ago the customer service for whirlpool gave us the...
Try pressing the following key pad buttons within 5 seconds - PREWASH OPTIONS - WASH TIME, PREWASH OPTIONS - WASH TIME, in this sequence and allow the washer to run. The LED display will start counting down as the washer begins a sequence of short diagnostics tests. If no error is present, the washer will return to standby. If the error persists, you may have a blockage in your drain pump. Please run the test and let me know the results. Total test time is about 1 minute 40 seconds. I hope this helps you.
Jul 24, 2008 | Whirlpool Washing Machines
Kenmore Ellite Oasis - model #27042603
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Jun 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite washing machine
This code means its not getting a sufficient water supply. I was doing a cold wash and noticed it was sucking down some hot water, so shut off the hot. MISTAKE, after a little bit the HF code came up. Apprently it likes to decide for itself just how cold is cold. Darned Computers.
To make a short story long, when I shut off the hot, it apparently shredded the washer and sent the remnants down to the little filter thingy at the washer itself, whereupon they reassembled themselves into a clog, once again giving me the HF code.
(Check your user manual Troubleshooting section. I think it says to press Pause/Cancel twice)
Mar 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite front load washer
look for an error code on those washer it will be and f-02 something like that or HF FH it will have an f keep an eye out for that
Mar 19, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE5t Washer Logo
147 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
