Question about Microsoft Xbox 360 Console
My xbox 360 is not showing a picture all i get is the audio function
Is it on the right channel is it got the right lead on it is it plugged in properly?
Posted on Feb 02, 2010
  • 44 Answers
SOURCE: my xbox 360 is not displaying any picture just sound
its overheating but will give u red light eventually try googling X-Clamp fix i fixed many with same problem
Posted on May 14, 2008
busgeek79
  • 36 Answers
SOURCE: audio but no video when i turn xbox 360 on
hi MC, power off unit unplug av cable from back of xbox.. then power up unit.. after a couple minutes the xbox will shut down.. plug the av cable back in and power up.. Good Luck
Posted on Jun 30, 2008
  • 4 Answers
SOURCE: xbox
the most common solution for this is the towel method wich will heat the soder back up and fix it the is a hit or miss but unless you want to take your xbox apart then this is what you get just as long as you have no warrent if you do use that there are several youtube method for doing this and seems to only be smi permenant but you can always send it in or taxe it apart and replace the xs in the system
Posted on Oct 13, 2008
SOURCE: my xbox 360 will use sound but wont show picture?
my xbox360 will do everything it has to but will not show picture but another thing is that the three red lights dont come up either. what can i do to fix it?
Posted on Jan 07, 2009
  • 31 Answers
SOURCE: No picture on TV when Xbox 360 is turned on
For the most part, an XBOX will display a picture on the TV regardless of what the settings are. If there is no picture, it is most likely the cable or the XBOX output terminals themselves.
Since you have said that your friend's AV cable didn't work either, even though it did on his, we must assume that the problem is with the XBOX.
 If the warranty is still on the console, call Microsoft and send it in. If it isn't either call Microsoft and see that they can do, or find an online repair shop that can help you.
If you need furthur assistance, feel free to ask. If this response helped you, please rate it!
Thanks!
Posted on Apr 13, 2009
My xbox 360...shows the picture of the game n stuff but no sound of the game...wats the problem..what can i do to solve da ??
Ensure that the audio/visual plug in the back of the 360 is in all the way, and that the red and white cables are plugged in all the way. If this doesn't work, try plugging it in to a different television. If problem persists try another audio/visual cable. I suggest borrowing one first so you do not waste money if that isn't the problem.
Feb 04, 2011 | Microsoft Xbox 360 Console
Tip
Keep video files with 5.1 surround sound for Xbox 360
Have you purchased a 5.1 Surround Sound Speaker system for the Xbox 360 to enjoy your games and movies in the center of action? Currently I have considered doing it. I have loads of HD videos, which are with the extensions of .mkv, .m2ts and whatever. Most of them have embedded 5.1 channels, but the thing is that because of format issues, my console is unable to directly play these files, so I have to do format conversion before watching them. In regard to conversion, my only requirement is keeping 5.1 channels of the source file, fortunately, with Pavtube Video Converter, I did it! Very excited! Share it here.
What you will need is only Pavtube Video Converter. You can free download it here. The detailed steps are as below:
1. Click "Add" button to load video files into this program
2. Click the pull down menu of "Format" to select output format for Xbox 360
Follow "Zune/Xbox 360 Device" – "Xbox 360 HD Video (*. Wmv)". By the way, if you wanna combine multiple files into a single file so that there are no intervals while playing, you can tick the checkbox "Merge into one file" to achieve it.
3. Click "Settings" button to do advanced settings and select 5.1 channels
All the items including codec, bit rate, frame rate, aspect ratio, sample rate and audio channels are changeable. Do remember adjust the audio as 5.1 channels. Following are my settings, which result a good playback quality on my Xbox 360 console.
4. Click "Convert" button to start conversion
Once finished, you can get the output files for your console via clicking "Open" button effortlessly.
More features of this Xbox 360 Converter I have found:
1. The converting speed of this software is 1-2 times faster than the similar converters. Batch conversion can be done in a few minutes.
2. It does not have the audio and video out of sync issues.
3. With exception of adding text as watermark, images, GIF animations, and videos can also be added as watermarks to realize the picture-in-picture effect.
4. You can use the "Trim" function to select certain video clips to convert. And you can also take advantage of the "Crop" function to remove black edges or change the screen size.
5. Special effect models are provided, such as "Simple gauss blur", "Simple laplacian sharpen", "Aged film", "Flip color", and "Invert".
For more: http://www.pavtube.com/video_converter/
on Feb 27, 2010 | Audio Players & Recorders
I can hear my xbox 360 but the picture isnt showing up on the tv
check that your color cables are secure in the tv... Possibly your audio is in securely but you need to tighten the picture one.
May 14, 2010 | Microsoft Xbox 360 Console
I suddenly lost just the visual with my 360. The audio is still coming through normally, but the picture isn't showing up on the screen. I've rechecked the av inputs, checked the cord and made sure it...
If your Xbox 360 does not have display you need to stop the heat getting to the chips. You can actually do this yourself as many have in this forum using the recommended Xbox 360 Repair guide.
Basically the guide will show you how to stop the heat build up with videos and household items, of course if you are in doubt send it in.
It has a preview video on the website.
Or of course you can send it in to have it fixed.
Jan 27, 2010 | Microsoft Xbox 360 Console
Xbox 360-no audio output
You may need to go into your TV settings and turn on HDMI Audio. If this is not enabled (Typically on HDMI 1) The TV will not ask the 360 for Audio and as such won't pull it.
Jun 20, 2009 | Microsoft Xbox 360 Console
Xbox 360 with no picture
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. Try another television
3. If the steps dont work, call xbox customer support to have your xbox serviced. Good Luck! hope your console still has warranty
The main reason why its acting that way its possible that the AV PORT is faulty or its your cables..
Apr 07, 2009 | Microsoft Xbox 360 Console
Problems picture not showing
Red ring is not the only problem with Microsoft Xbox 360. This amazing device also has some more common problems like Audio but no video problem, disc read error etc. Microsoft is providing extended warranty only for red ring problem. Means you will have to spend some money to get this problem repaired also if you plan to send your xbox to Microsoft, you will have to wait for 3-4 weeks to get back your favourite Xbox. There is one more option in the form of DIY guide, this guide explains solving No Video problem with step by step instruction, so any novice can fix this problem..........
Nov 30, 2008 | Microsoft Xbox 360 Console
No picture
it could be that u r not hoooking it
Jul 28, 2008 | Microsoft Xbox 360 Console
Audio but no video when i turn xbox 360 on
Jun 30, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
50 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
