Question about NetGear WGR614 Wireless Router
How to connect
How do I connect the netgear to the modem and lap top?
I HAVE WIRELESS ONLY AND NEED TO RECONFINURE MY ROUTER IT SAYS CUSTOMER ID ONLY
Posted on Feb 22, 2008
My wireless broadband very slow
Posted on Feb 18, 2008
In my lap with windows 8 version netconnection i s not available,but with same wifi modem..NETGEAR N150 WIRELESS D S L Modem Router mobile is net.connected.
Netgear are products that are last to just about 90 days. I am a computer tech and do a lot of house and business calls to TS networks. Most problems come from Netgear, once they switch to another brand, the problem disappear. Even I had a wireless Netgear router, and had to return it because the life span was about 4 month and the complimentary support is only 90 days.
Just by rebooting the modem (turning it off and on) usually fix it for about 8 hours, then the cycle start again. After rebooting the modem/router, delete your saved network from Windows 8 and start fresh. That should work.
Mar 21, 2015 | NetGear N150 Wireless-N ADSL2 Modem Router...
Router problem. unable to connect wirelessly
This is usually up address conflict. You will have to assign the wifi or lap top to different IP addresses. You have to refer to the modem manufacturers instructions or search on net / YouTube how to do this. It's too detailed to do it here I think.
Oct 17, 2017 | NetGear WGR614 Wireless Router
I am a Comcast customer with high speed internet. I am trying to get my wireless router to work on my lap top (Toshiba). The lap top will work if connected to the modem directly. However, when I try to...
to configure the netgear router and to secure its network. . . .1, first make sure that your laptop is connected directly to the netgear router via ethernet cable.2. after securing step 1, on your computer, open browser, ( internet explorer or firefox )3. go to the address bar, the one with the http:\\ and erase everything inside it.4. type in there, 192.168.1.1 or www.routerlogin.net.5. username is " admin "password is " password "6. you would see netgear set up wizard. 7. for wireless configuration, click wireless settings on the left side of the set up wizard.8. you can edit network name, and get your network security key under security options. make sure to choose WPA PSK TKIP. so that you can have a personalize network key9. the network security key is the " passphrase "then click apply.then your all set for wireless connectivity.
Aug 12, 2011 | NetGear WGR614 Wireless Router
I cannot get wirelessconect to my laptop from my netgear modem router DG834G.I can see the signal but unable to connect
check whether the dhcp option is turned on in ur wireless router. if its turned off, change it to on state and try. u will be able to connect. still if u din get access. use some other lap to connect to ur wireless network. if it is possible to connect with someother lap, then the problem is with ur lap. the wifi drivers might get corrupted. re-install it to fix the problems. if all above doesn't gets work, then the problem is with ur wireless router.
Jul 21, 2010 | NetGear DG834G Router
Net gear box won't connect wirelessly with my lap
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 20, 2010 | NetGear WGR614 Wireless Router
How can I my up my comcast netgear modems wireless to work? when I try my PS3 it detects a sginal but wont obtain an IP address. The same with my lap top.
You have to change the ipddress on the router different then the modem. For example 192.168.9.1 and leave the modems ip alone. Plug the cable into the Lan port of the router. Go to the setup screen on the router and tell give your username and password that
Comcast gives you. You will need comcast gateway address and dns numbers. There will be a connect button on the router and tell it connect it to the modem. You are trying to let the router receive that only ip address.
Nov 09, 2009 | NetGear CG814M Wireless Cable Modem...
Question on setting up two computers
Yes, I have pretty much the same setup at home. Wired desktop and wireless laptop. On the back of your wireless router, there should be 4 or 5 wired connections which you can use. You will only have to use the setup disk on one computer. Basically, the setup disk is for the router, not the computers, it simply guides you through the router configuration process. You can also do this manually, the manual for the router will give those instructions as well.
Apr 07, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
53 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
