Question about Lexmark X2600 InkJet Printer
Need to reset ink levels on printer (lexmark 2600)
Installed a refillable ink cartage (black) in my lexmark X2600. now my ink level is still empty and my printer says to replace cartage.
  • 4,041 Answers
Hi
It is the chips on the inks that make it shore empty nothing you can do about it.
But I have found this bit of read up on the internet forum Gave it a go may work if it works come back let us know so I can pass it on to others Thanks.
1 Take a small pice of clear tape. Try covering one of the outside vertical row of contacts at thr front of the cartridge. Re-insert it and it shoudl "fool" the printer into thinking it is a new cartridge. It works for my Lexmark 2600 series all in one.
2 Use clear tape over left hand row of sensors on front of cartridge and re-insert. ink now shows with question mark but reads as full and prints fine.
3 I had fully covered the contacts because it was the full length of my Scotch tape. It did not work. I went back and re-read thread, wiped the contacts the computer was telling me, took off the strip and put on just a sliver covering the left vertical side of the contact only. It worked! Yippee! Thanks a million!
Go to this website to see all
You can go to this link to see all the read up about it.
http://www.fixyourownprinter.com/forums/inkjet/35235
I not have this printer myself so I not can say if it works or not.
All The Best Hope it works for you
Posted on Jan 31, 2010
Thanks, worked well here, this was my procedure. cover the first point, the upper right, put the cartridge, then cover the line right, put the cartridge, then repeat with the left line procedure, this time let more covered, ready! use and recharge. lexmark printer 2600 series X2695.
Posted on Jul 21, 2011
For me doesent work :(. When i print the agliment page she don't want to print the black color, she print only blue. Do you have other solution ?
Posted on Apr 18, 2011
Lexmark x2600 reads (new) ink cartriges as empty
If the cartridges were replaced while it was empty and not using the maintenance the software will not detect . so to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
Apr 06, 2011 | Lexmark X2600 InkJet Printer
I refill the black catrige in lexmark x2650 but it does not support it. how i can?
You need to google lexmark ink refill. There seems to be lots of people having problems refilling lexmark inks. There may be an chip resetter available
Sep 04, 2010 | Lexmark X2600 InkJet Printer
I had my black ink cartridge refilled and I cannot get the printer software to recognize that it is no longer empty
Lexmark is a company with a simple model: sell the printers cheap and ink expensive. Many brand name cartridges have little sensors that trip when it's empty. This paired with software that tells cartridges to expire after they reach a certain amount of time.
The X2600 is especially made to sell ink. As I'm sure you know, she won't print unless she has a color cartridge.
If you paid someone to do this, they should have known #14 & #15 inks (the one's the x2600 takes) auto expire after a given amount of time. Because of this a newer cartridge may refill just fine and suddenly, once it passes the "expiration date" the cartridge just shuts down.
There are sophisticated hacks were you modify your print software and OS registry to ignore such things but you may be happier just buying the refill cartridge.
I know, it's unfair! Lexmark covered their bases on that one too. Like most companies, the terms you agreed to when you installed the printer and the manual include a commitment to only use Lexmark brand refills and not to refill cartridges as it "may damage your printer."
Here's a good article that addresses the issue in more detail.
Hope this helps!
Aug 14, 2010 | Lexmark X2600 InkJet Printer
I refill black cartridge but still show no ink
Hi There
It simpble you cant refill Lexmarks they made there inks so it will fuse so cant use the for refilling
Sorry .
May 15, 2010 | Lexmark X2600 InkJet Printer
Empty ink
According to your problem it seems your cartridge has been damaged or choked so change your cartridge. Because some times when we use refilled cartridge, Ink goes dry and printer's sensor can not sense the ink.
Regards
Ashly
Feb 23, 2010 | Lexmark X2600 InkJet Printer
I refiiled my black ink cartridge at Walgreens and now the printer thinks my black is empty and will not print.
Normaly when you refill a cartridge the level is not reset & is normal.
I assume if you read your instructions you should be able to press a button on your printer for 5 seconds & it should override the software.
Also on some lexmark printers you can tell the printer software you have installed a new cartridge.
Another common problem is when a cartridge is refilled if the correct type of head seal is not used the cartridge head clogs or dries up, to rectify that get a piece of tissue paper, wet it and place the printhead on it, just dab it, after a few dabs you should see a nice block of ink the same size of the printhead, if you do replace back into printer & it will work.
if you don't get a good band after a dozen goes the printhead is either blocked or when they refilled it they did'nt do it correctly.
Nov 08, 2009 | Lexmark X2600 InkJet Printer
How to refill a lexmark x2600 black ink cartridge?
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Nov 05, 2009 | Lexmark X2600 InkJet Printer
Black Ink has been re-filled, canon MP240 says its empty )=
i thnk you need to replace the cartridge maybe the ciruit has been destroy in the event of refilling the cartridge..so that the computer cannot read the ink level ..
I hope it help.
thanks for using FIXYA.
May 22, 2009 | Lexmark X3650 Printer
Lexmark X2600 refill problem
many printer manufacturers put something (a chip?) in the circuit of the cartridge to prevent refilled ones from being recognized by the printer....when the "factory" cartridge is empty, the only way for the printer to see a full cartridge again is by using a "new" factory one, ...i guess it's the big name brands way of making sure you buy "their" ink and not use refulls.
Oct 22, 2008 | Nukote Nu-kote RF196 Black Refill Kit
Lexmark z845 ink refill problem
i need adisk to install z645 printer towindows vista couputer
May 08, 2008 | Lexmark Z645 InkJet Photo Printer
Lexmark X2600 InkJet Printer Logo
5,401 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
