Question about Dell 922 All-In-One InkJet Printer
Printer cartridge has ink but not printing well
  • 4,041 Answers
Ok it got to be the heads blockage
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones
Posted on Jan 31, 2010
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
I have a Lexmark Pinnacle Pro 901 printer and its set up to print using black ink only, but it keeps telling to replace color cartridges and it won't let me print at all, how do I print using blac
The printer would need all cartridges to have sufficient ink levels to continue printing - that's to prevent damaging the printhead. Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
To save on your ink investment, try printing in draft mode and by making sure that your printing preferences is set to print using black ink only.
Oct 25, 2012 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
I have the Dell AIO 926 and i have an Error Message. Error 1203 Consult User's Guide I cannot print, what do i do?
error 1203's error name is print head short which indicates a short circuit in the print head has occurred. solution to this problem is to disconnect and then reconnect the printer power cable. Reinstall the ink cartridges.For more information, see Replacing Ink Cartridges.
  • Turn on your printer.
  • Lift the printer unit, and then position the scanner support between the tabs to hold it open.
  • The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  • Press down on the ink cartridge lever to raise each ink cartridge lid.
    Remove the old ink cartridges.
  • Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
  • If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: The following illustration shows a black cartridge and a color cartridge (used for normal printing). For photo printing, use a photo cartridge and a color cartridge.
    Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
    Snap each lid closed.
    Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
  • Jun 05, 2011 | Office Equipment & Supplies
    Says to replace cartridge which i did but it still wont print.
    Why isn't any ink coming out of a new ink cartridge that has just been installed?
    The ink cartridge may have a plastic tag covering the print head, which should be removed before the cartridge is installed. If the tag has been removed and the problem persists, there may be air bubbles blocking the print head. In this case, you can try using the print head cleaning function of your printer or leave the ink cartridge in your printer for about an hour to allow the air bubbles to rise to the top of the ink cartridge.
    What should be done if the ink cartridge doesn't print or some of the colors don't print?
    The nozzle may be clogged with dried ink. The print head should be blotted with a damp lint-free cloth to remove the dried ink. If this does not work, try soaking the ink cartridge in water for a few minutes. To soak the ink cartridge, place it in a Styrofoam cup and fill the cup with water until the ink cartridge is halfway immersed in water. If the ink cartridge does not print after this is done, try soaking the ink cartridge overnight.
    Hope it helped...
    Oct 28, 2010 | Canon imageCLASS MF5750 All-In-One Laser...
    How do I change ink cartridge on my HP inkjet 6500 wireless printer.
    Hi, When using refilled print cartridges, the Estimated Ink level and the Printer Status Window may indicate that the print cartridge is out of ink. Either continue to use the print cartridge until print quality degrades, or replace the print cartridge with a new HP print cartridge.
    The methods of replacing the ink cartridge of the printer follows here:
    Open the printer cover
    The printer ink carriage will automatically goes to center
    Once the carriage is in the center, the printer was ready to replace the ink.
    Pull the down slowly the ink tank off the carriage..
    Remember the place where the color/black position.
    Remove each tank one at a time, and replace the ink with a new one.
    Close the printer cover and it now ready to printer.
    HP Deskjet 6500 Series Printer - Setting Definitions
    Hope the instructions provided helps.
    Dec 03, 2009 | HP Officejet 6500 Wireless All-in-One...
    How do you check ink levels
    Introduction This describes how to check the estimated ink level in the cartridge. NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, keep a replacement ink cartridge available to avoid possible printing delays. Ink cartridges do not need to be replaced until print quality becomes unacceptable. Checking ink levels Perform the following steps to check the estimated ink levels: NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
    1. Open the Printer Toolbox . There are two ways to do this:
      • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
      • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
    2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink. Figure 1: Estimated ink levels
    Nov 23, 2008 | Office Equipment & Supplies
    Ink cartridge light keeps blinking
    you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
    Jul 07, 2008 | HP DeskJet 940c InkJet Printer
    HP Deskjet D4160
    hi,
    Ink-backup mode lets you continue printing with one print
    cartridge when the other print cartridge has run out of ink.
    Ink-backup mode allows the printer to operate using only one print cartridge. It is initiated
    when a print cartridge is removed from the cradle.
    Exiting Ink Backup mode
    Install two print cartridges in the printer to exit ink-backup mode.
    Cheers !!!!
    Feb 15, 2008 | HP 83 3-ink Black UV Cartridge Multipack...
    Dell 922 All-In-One InkJet Printer Logo
    61 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Electro Med Services...
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
