Question about Metra Toyota Lead To Oem Radio 94 87
Need a pin out for a Toyota radio 86120-04090
What is radio code?
Hi Sarah, You need to take your registration papers with your licence (licence is to prove YOU own the car) to a car dealer ie: Holden, Ford, Toyota, Chrysler and ask at the sales office for the RADIO SECURITY PIN NUMBER, You'll receive your radio security pin number and radio serial number. These numbers belong to that car and once you have them DON'T loose them because in Australia some dealers charge a fee and some don't.... Hope this helped....CHEERS..
Apr 02, 2016 | 2006 Chevrolet Malibu
Radio-code of model no.mr563520
Hi, You need to take your registration papers with your licence (licence is to prove YOU own the car) to a car dealer ie: Holden, Ford, Toyota, Chrysler and ask at the sales office for the RADIO SECURITY PIN NUMBER, You'll receive your BCM security number, Car key number-Ignition, Radio security pin number and Radio serial number. These numbers belong to that car and once you have them DON'T loose them because in Australia some dealers charge a fee and some don't.... Hope this helped....CHEERS..
Mar 31, 2016 | 2001 Mitsubishi Montero
Ford falcon radio code
Hi Fezekile, You need to take your registration papers with your licence (licence is to prove YOU own the car) to a car dealer ie: Holden, Ford, Toyota, Chrysler and ask at the sales office for the RADIO SECURITY PIN NUMBER, You'll receive your BCM security number, Car key number-Ignition, Radio security pin number and Radio serial number. These numbers belong to that car and once you have them DON'T loose them because in Australia some dealers charge a fee and some don't.... Hope this helped....CHEERS..
Mar 27, 2016 | Ford Cars & Trucks
Radio in toyota carolla just say help try to put pin in
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your Toyota servicecentre and get them to enter this code for you.
Aug 06, 2012 | Toyota Corolla Cars & Trucks
04 toyoya camry radio wireing harness pin
Hi there:
According with the diagram on 2004 Toyota Camry Car Radio Wiring Diagram...
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink/Blue
Car Stereo Amplifier Location: Located to the right of the glovebox behind the passenger side of the dash.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Left Front Tweeter: Powered by the same wires as the left front speaker.
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Right Front Tweeter: Powered by the same wires as the right front speaker.
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Tehy could be harnesses 15 or 20 pins, try to look your right replacement in this links:
- 2004 Toyota Camry Stereo Wiring Harness
- 1990-2013 Toyota Camry Auxiliary Car Audio Input Adapter Kit
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 06, 2012 | Toyota Camry Solara Cars & Trucks
2 CONNECTORS ON THE BACK OF A TOYOTA OEM RADIO MADE BY FUJITSU-TEN. MODEL 86120-AC111. WHAT ARE THE PIN OUTS
http://www.tehnomagazin.com/Auto-radio-car-connector/TOYOTA-Car-Radio-Wiring-Connector.htm
Jul 05, 2010 | Car Audio & Video
I need a radio pin for a toyota car cd number 08600-00975 serial no NA800784
Toyota Codes are only available from a Main Toyota Dealer or a Radio Decoding Service
Feb 09, 2010 | 2002 Toyota Camry
Security Pin for radio lost
Call the parts or service department at your local Toyota dealership. Tell them you bought it there (maybe you did) and ask for the radio code. have your vin number ready (its on your registration card or in the corner of the windshield). Maybe you have to pay for it but I hope not.
Jul 02, 2009 | 2003 Toyota Corolla
JBL Prius Radio Tuning Knob Broke
Search for your model number on eBay. You should be able to find used radios taken from a totaled Prius much cheaper than buying a replacement from Toyota.
Apr 17, 2009 | Car Audio & Video
Wiring schematic
Goto this link http://www.scosche.com/ They sell wiring kits cheap.
Apr 06, 2009 | 1987 Toyota Corolla 2 Door
Metra Toyota Lead To Oem Radio 94 87 Logo
1,233 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
