Question about Sony Televison & Video
I have a ev-c3 that the loading \of the tape
I have a ev-c3 that the loading of the tape does not work corretlty , it did
work a time or two but now is does mot
Thanks but I need a repair shop, the loading is ok but it will not
go in play mode , so I thinks that i need some one to look at it thanks Alan
Posted on Feb 01, 2010
Moto Guzzi 2001 California Neutral light not working Please refer to additional detail
Hi, Frank I would have to agree on your diagnosis and theory and here's what I would do:
1. Remove the neutral switch and using smoke and mirrors especially mirrors, if necessary, shine a flashlight in the hole to view the detent/lug situation.
2. If that looks ok then spray the sh*t out of the neutral switch with carb cleaner, while depressing the spring loaded plunger 3-4 times then blow dry with compressed air.
3. If that doesn't work buy a new switch.
for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Neutral Light not coming on Technical Topics
Neutral safety switch issues
MOTO GUZZI California EV Workshop Manual
Parts Lookup 1990 1999 Moto Guzzi California EV V11 EV Usa 1100 1997 2001...
MOTO GUZZI California Jackal Owner Manual
Dec 01, 2016 | 2001 Moto Guzzi California Jackal
Ev-c100 ejects on rewind
Try cleaning or replacing the mode switch.
Jul 28, 2013 | Televison & Video
Tape isn't retracted into cassette upon eject on Sony EV-C100
l would sacrifice a old or bad tape here, remove all the tape inside a cassette and tape off the small sensor holes on each side.
That way no tape to damage and you can insert it to see what is happening.
What likely is the issue is when stop it, it or if the tape does not fully load against the drum with heads, when the arms retract that pull the tape out of the cassette the mechanism is not switching to rewind it back into the cassette.
Usually this means a belt is slipping or the idler unit is not working---belts can break or stretch or even come off---belts will get slopply or bad from NO use and it is common.
Dec 09, 2012 | Sony Video Hi8 Ev-c100 Ntsc Video Cassette...
I have taken a rarely used Sony EVS2000 out of the closet to transfer some 8MM tapes but after loading the first tape I can't get any motor functions to work. No play, FF, Rewind or eject will function....
sounds like the mechanic is stucked. this happens because due time the used grease is loosing its viscosity. cleaning mechanic and regreasing will help. btw change of old rubber parts are recommended also.
Feb 27, 2011 | Sony EV-S2000 Hi8 VCR
Brand new Sony EV-S2000 vcr will not play Hi8 tapes
I'm not sure what you mean by brand new as Sony has not made these for a while. What exactly is the problem? Is the unit NOS (new old stock) and unused but a bit older? If that is the case, the rubber parts inside may need to be changed. Rubber dries out and gets slippery with age and may not have enough friction to allow the unit to work properly.
Please update this with the symptoms.
Thanks,
Dan
Aug 31, 2010 | Sony EV-S2000 Hi8 VCR
VCR won't eject tape - timing of loading mechanism is off
Now-a-days most of the gears are made out of plastic(HDPE, if I remember correctly), when the rewinding command is given even if one gear tooth is worn/broken it will throw the entire timing out of 'gear'. Since the problem has already occurred, and, this is the only function that has malfunctioned my advice would be to leave it as it is! ('cos repairing/replacing it is manual & therefore a costly affair plus there is no guarantee that the replacedment will function properly)....sodeep
May 09, 2009 | Sony SLV-940HF VCR
My Problem with IF Function ,Can u help Me PLZ :(
You don't need the AND statements, just the IF:
=IF(C3>95,"5.0",IF(C3>90,"4.75",IF(C3>85,"4.5",IF(C3>80,"4.0",IF(C3>75,"3.5",IF(C3>70,"3.0",IF(C3>65,"2.5",IF(C3>60,"2.0","1.0"))))))))
I tried it several times and it works like a charm!
Jan 04, 2009 | Microsoft Excel for PC
Loading 8mm tape into sony ev 80 vcr
The tape should automatically load in when you push the tape to the tape holder.
Aug 18, 2017 | Sony SLV-D370P DVD Player/VCR
I actually own the EV-S3000. Playback problems.
I dont think the tapes is the problem, i think its the heads, if you have not sealed the unit up in a air tight unit while its not been used you can get, condensation in the heads and then that collects dust, then drys on the head, sometimes a wethead clear can clean this off, but if you don't have one of these then you could try alcohol cleaner and a cotton bud. and rubber gloves to touch the head. on the head sock with the alcohol on one bud and leave it to soak for a time. and then clean off with another bud., do the same with all heads and audio and tracking head,then leave to dry. when dry use a nother cotton bud just to check each head is clean. tapes can deteriorate over time but if you have keeped them in a dry damp free aria they should be fine. ...
Jul 04, 2017 | Sony EV-S2000 Hi8 VCR
Televison & Video Logo
102 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
