Question about Dayton G73 Utility Heater
FIRST TIME USE WILL NOT COME ON IS GETTING POWER
  • 456 Answers
Do you hear a click when you turn thermostat all the way up? If this is a
220volt unit, then the contactor is porbably not pulled in. One sure way
to make sure you have power and functions is to have a electrically inclined person push the contactor in, unit shouldrun
Posted on Jan 31, 2010
2000 toyota 4 runner. Has no power. Sounds like it isn'tt getting the gas. changed fuel filter,plugs
Bad gas or diesel in tank???
getting misfiring on all cylinders and coils won't ever fail at same time. Usually only 1 at a time.
don't ever replace the fuel filter. only if it has lack of power on highway speeds.
Apr 04, 2014 | 2000 Toyota 4Runner
My yamaha ttr 50 won't start I don't no what to do to fix it help
Three things get your cycle to start and run: gas, electricity from battery to spark plug and air! Do one at a time...Are you getting gasoline to the carburator and eventually to the cylinder? Are you getting power from the battery? Is the spark plug getting power? Is the starter motor getting power? Trial and error!
Jan 19, 2013 | Motorcycles
WHY IS THE BATTERY LIGHT FLASHING ORANGE,AND THE BATTERY IS GETTING VERY HOT.
Some adapters do get very hot after a long time of use. flashing light alot of the time indicates that it is no longer charging. Might be time to replace adapter
Aug 12, 2012 | MSI Computers & Internet
No fuel pressure till the asd relay clicks1993 jeep
The real reason the ASD relay is not getting power is because the ecu is slow to send power to it. Next time the ASD relay is not getting power, look at the dash to see if the check engine light is on. If it's not on and the ASD relay does not have power at that time, then the ecu is in need of repair. It's what's called the delayed check engine light problem.
Sep 30, 2011 | 1995 Jeep Cherokee
G1 mobile ic getting hot
first you tell me that your mobile is getting hot at charging time or it always getting hot
but according to me this is not a problem because some device are getting hot at long calling time because at that time your device use more power and due to the continous use of more power its system get heated
Jan 29, 2011 | HTC G1
My lowrance 520c GPS stopped working. When I turn it on it shows the last lake I was AT. And the trail marker does not work
I have a 525... Several things and go step by step... First, make sure your getting 12v of power to your "puck"... On the Lowrance site there is a step by step guide for testing. Just because your getting power to the main unit does not mean your getting power to your the gps module. There are three different power sources on these units. Main power, sonar and gps! If your getting 12v coming out of the data port then check power to the cords, and to the T... If all that is correct the its likely your gps module. You can order a new one directly from Lowrance customer support for 50% off the normal price as a replacement. They will likely upgrade you to the 4000 series. Comes with all wiring, T connector but not the resistor cap. Best time to call Lowrance is 8:15 am central time when the phones are turned on!
Mar 04, 2010 | Boating
Ps3 wont stay on.
HI, if you are getting a yellow light during this ordeal, i would suggest purchasing a mini cooler for this unit. it is overheating at this time. this will destroy your power unit soon. If you are getting the red light at this time, the power board may be already damaged.
In this case, contact Sony for a power unit replacement procedure.
Jun 24, 2009 | Sony Playstation 3 (PS3) Console
Dayton G73 Utility Heater Logo
110 people viewed this question
Top Dayton Heating & Cooling Experts
paulcarew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
