Question about RCA F27442 27" TV
No picture but has sound
Rca F27442 has no picture but has sound what can i do to fix?
  • RCA Master
  • 1,212 Answers
Coil L14401 is not making a good ground. Remove him carefully, scrape the ends clean and the board where he was removed. Now reinsert and resolder this little guy,and Bingo you have your TV back. This is a common problem with your TV! Thanks for asking!
Posted on May 08, 2010
No picture but have sound. RCA Model F27442
you have the problem in the heater try to resolder the parts in the crt socket the one that is connected in your picture tube if nothing happens check the resistor if open replace it common value is 5.6ohms.
Oct 14, 2010 | RCA F27442 27" TV
My RCA F27442 dosen't any picture put it dose have sound what can i do
Coil L14401 needs removed and the ends scraped clean. Clean the board where the coil was removed and reinsert this coil and resolder. Your TV will be back as as good as new! This coil is located near the Horizontal Output transistor!
Dec 05, 2009 | RCA F27442 27" TV
I have a rca f27442 tv and the picture is half
yes!!!! very common problem. soldering the vertical section and the grounds around the tuner section will fix it. guaranteed fix. for a quick fix, take off back and while tv is on, take the plastic side of screwdriver and tap tap tap the tuner section. see i told you that would fix it.
Nov 10, 2009 | RCA F27442 27" TV
"snow sound" on rca tv, perfect picture
Although your picture is perfect, I would think the fine tuning is slightly off. This can also be to do with the cable box frequency setting. Call out the cable people & get them to check the box & the setting up to the TV.
Aug 24, 2009 | RCA F27442 27" TV
Got sound but no picture
We Start tv Then Sound come But Picture Is Not come
Aug 22, 2009 | RCA F27442 27" TV
I have an RCA F27442. I get a popping sound and
You have a bad flybacktransformer. This is what is causing the popping!
Aug 10, 2009 | RCA F27442 27" TV
RCA Model F27442 has sound but no picture
check to see if you have B+ to the horz.output transistor.
also you may have bad solder connections on the countdown osc. ceramic resonator.
Dec 24, 2007 | RCA F27442 27" TV
RCA F27442: no picture.
you may have bad solder connection in the horiz.countdown section.
you may also have a GEM Star module bad.
Nov 06, 2007 | RCA F27442 27" TV
Tv F27442
The TV does not have a reset button. If you have no picture and no sound, there is something wrong with the chassis. In this case the set should be serviced by someone experienced in the RCA CTC203 chassis. If you have no picture but do have sound, then it is possible that the 2 controls in the 2 little holes in the back of the set are not adjusted correctly. This is quite possible since you said you put a screwdriver in there and got a fuzzy picture. The control on the bottom is called "screen" and is the overall brightness of the picture and the control on top is called "focus" and is the sharpness of the picture.
May 20, 2007 | RCA F27442 27" TV
RCA F27442 27" TV Logo
88 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
