Question about Sony VAIO VGN-CS260J/P Laptop
The fan goes on, loudly, for no apparent reason. The laptop is not overheated. It goes on and off for a few minutes, and then stops. This will happen a few times a day, and only started recently. My laptop is approximately six months old.
I HAVE THE SAME MODEL WITH SAME PROBLEM, YOU CAN CALL SONY AND THEY WILL REPLACE THE FAN FOR NO CHARGE UP TO 48MONTHS,HOPE THIS HELPS
Posted on Mar 02, 2012
  • MASON Mar 02, 2012
    Novelist:
  • 157 Answers
Sony laptops have a thermostat which monitors the heat internally. When it gets too hot, the fan will turn on, when the unit cools back down, it will then turn off. There is nothing to worry about.
Posted on Jan 30, 2010
Volume decreases drasticly after playing loud 15-20minutes
Shes overheating and thus goes into emergency mode and shuts down the volume to help cool down the built in amp . Dont know if it has a built in fan (likely not) but its overheating which can be a number of reasons why...from a failed heatsink componet, inadequet venting, shorted circuit. Can you take it out and inspect it?
Dec 03, 2013 | Kenwood Kdc-x994 Car CD/ MP3 Player
When I start the car there's a loud sqeeking noise that goes away after 1 minute 2003 es 330
if it was mine, I would buy some "fan belt dressing spray" and spray my fan belts or have them adjusted. first spray them once, if sound stops a few days, have the tension adjusted. if spray does not work the first time, this is not the problem.
Apr 16, 2012 | 2004 Lexus ES 330
When I plug the unit into power, the CPU fan runs very fast but no boot, and then when I press power on the fan slows down and the PC boots normally. It shuts down in about 30 minutes with no sign of...
Sounds like you are overheating. One way to tell if it's overheating is you say it will run for about 30 minutes then shuts down. When it shuts down try rebooting to see if the boots successfully. If it fails to boot successfully right after it shut down then you are probably overheating. If you wait awhile to let it cool down for 30 minutes or so and if you reboot and it does it successfully you definitely have a overheating problem. If I remember correctly all those compaq sr series have loud and fast running fans. Computers overheat because of three reasons for the most part: 1) A fan has stopped working. 2) The Thermal Paste on the CPU and Heat Sink has dried up or is not thick enough to keep the unit cool. 3) Dust has clogged the fan vents and inside the computer. Fortunately for you desktops don't have to be completely disassembled like laptops to get to the fan, CPU and heatsink. Just pop the case and you'll see the components attached to the motherboard
Mar 18, 2012 | HEWLETT-PACKARD Compaq Presario SR5518F...
My acer laptop aspire 4730z just shuts down with no apparent reason..i just cant get rid of it..what seems to be the problem!?
It may be due to overheating. Make sure all air vents are clear of dust. Check that the internal fan is working - usually located under the keyboard. The fan should usually ony come on intermittently, first when you boot up, then intermittently in Windows when the processor is working hard. If the fan is on all the time and especially if it is running fast then your processor is overheating.
If you go into the bios setup and the laptop resets within a few minutes with the fan running fast then you have a definite processor overheating problem. This may be a faulty processor or a fault on the motherboard.
Mar 10, 2011 | Computers & Internet
Compaq presario desktop sr1503wm fan at rear of cpu box won't turn. can it be fixed or replaced? apparently the other fan is overworking and causing a loud buzzing which goes off and on again every few...
If it is the fan in the power supply, replace the power supply.
The case fan is easily replaced. Measure it (in mm) and purchase a new one. The standard fan is usually 40 mm, I think.
Oct 07, 2010 | HP Compaq Presario SR1503wm PC Desktop
2004 jeep grand cherokee overheating and loud noise
sounds like one of two problems your fan is not working properly or you radiator is particularly restricted
May 20, 2010 | 2004 Jeep Grand Cherokee
Shuts down for reason
soundslike it could be overheating, check the system fan and buy a can of compressed air and blast it through the vents and fan systems, hopefully this will resolve the problem
kind regards and please don't forget to rate us
Dec 08, 2008 | Toshiba Satellite 1905-S301 Notebook
I HAVE P5RD1-VM ASUS BOARD NOW COMPUTER STARTED PROBLEM
several reasons for this.
1:) CPU Overheating.
2:) RAM Overheating.
3:) Motherboard Component Overheating.
4:) FAN not operating correctly.
These are a few things that can shutdown a computer after a few minutes, also viruses/trojans et,c.
can shut off hard-drives. and even instruct the bios to change settings.
Check that the CPU And case fans work correctly.
Mike @ compurepair.
Nov 17, 2008 | ASUS P5RD1-VM Motherboard
My t.v. shuts off after a few minutes
try this link...it tells you what the LEDs indicate. Apparently the cover on the back is not sealed properly, my guess is that it is a fan not working properly or some other reason the set is overheating.
http://downloadcenter.samsung.com/content/EM/200604/20060404091311750/EN/3_sub.htm
Oct 31, 2008 | Samsung HL-S4266W 42" HDTV
Overheating?
yes - it is cutting out on overheat. there are two fans - which one was replaced - cavity fan or casing fan?
possible reasons are:
faulty casing fan
not enough ventilation
faulty overheat stat
faulty fan stat
oven operating stat faulty but you would be burning your cooking in this case
Dec 21, 2007 | Electrolux EOB5665G Ultrafan Electric...
Sony VAIO VGN-CS260J/P Laptop Logo
336 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
