Question about Toshiba 55H70 55" Rear Projection Television
Flickers caves in on sides then shuts down
I had convergence chips replaced, and the repairman resodered suspect connections. TV worked for a couple of months with perfect resolution and then sudently went back to the same flickering and shutting down. It has been in a local toshiba dealer repair shop for two weeks and they say they cant find the problem. They said they replaced a couple of bad capacitors but didn't help. They suggest I buy a new TV?
  • gtracy2117 Feb 18, 2008
    Could you give me a ball park idea of how much a new board might cost? Thanks so much!
    Novelist:
    Champion:
  • 211 Answers
I can understand the frustration of the repair shop, as getting help from Toshiba is almost non existent. When the boards in any big screen gets hot and used, many components on the board degrade and in your case, it sounds as though the fix would be a replacement board. Unfortunately, you may not be able to get one. If your local repair shop can't find the problem you might ask them for the board number and do some research on your own for a board. Most wholesalers will sell to the consumer if you have a credit card, and if you can find the board, have your local shop install the new/refirb board and do whatever adjustments are necessary. Good luck. I hope this has helped in some way
Ed
NC Electronics
Mills, Wyoming
Have a Great Presidents Day
Posted on Feb 18, 2008
  • Ed Meshechek
    Ed Meshechek Feb 18, 2008
    I just called last Friday on another model and the price was 482.00. Although the set I called on was a different model, I have found that the convergence boards run anywhere from 350 to 700 dollars, depending on what it is. It's sure not cheap.
    Since I personally own the exact type of set you have, I personally think the set is worth the value.( I am fortunate that I have not had any problems on mine yet ) I hope you get your problem solved in a timely and inexpensive manner.
    Good Luck
    Ed
    NC Electronics
    Mills, Wyoming
Will not power up has constant on off flicker , when I turn it on the green light clicks off and turns red and the cycle repeats. I have checked the fuses and also resolderd the power board. is there any...
Hi Eric,
First of all, thank you for contacting Fixya.com regarding on your TV problem.
I've suspected a convergence chips failure not the power supply board issue in this kind of symptoms. To confirm it, locate the convergence board inside the set, it has a Sanyo convergence chip STK392-110 that are mounted on the large heat sink. This board has a LED (light emitting diode) that will light up once the board gone to malfunction. Turn on the unit and then check if the LED will lit after the shuts down. If yes, then I would advice you to replaced both convergence Chips and check the resistance of the resistors in line with the +25V and -20V supply of the chips.
Let me know if the LED at the convergence board does not lit to continue our diagnosis... Check also the LED at the power supply board and on the deflection board(this is where the flyback transformer is located)
Have a nice day!
Goodluck and take care!
Kind Regards,
Jdvillanueva
Dec 03, 2011 | Pioneer PRO-99 TV
I have a Panasonic PT-47WX53, this morning when i went to turn the TV on the picture was not align. The red and blue look aligned but not the green, i opened the back and when I coved the green light the...
This kind of problem occurs due to failure of convergence output chips located on main circuit board of tv and replacement of convergence output chips will hopefully solve your tv problem.
Soldering work is involve to replace these two chips so have local tv repairman for that job if you are not familiar doing so.
Thanks.
Jun 29, 2011 | Panasonic PT-47WX53 47" Rear Projection...
Colors overlap each other and looks 3d
This is symptom of bad convergence that happens due to failure of convergence output chips in tv, there are two big black chips attached with big aluminum heat sink that will be replaced to solve tv issue.
If you are not familiar with electronics stuff repair then call local tv repairman to replace above said chips to fix the problem.
Hope this will help.
Thanks.
Apr 05, 2011 | Panasonic PT-47WX53 47" Rear Projection...
Red and green doubled words on tv is this a bulb problem
No, it is convergence problem due to convergence output chips failure in rear projection tv.
Local tv repairman will fix it because it requires soldering work to replace bad chips in circuit board.
Thanks.
Mar 27, 2011 | Zenith R57W46 57" Rear Projection...
Have a sony 46 inch rear projection model #kp 46wt510! Purchased it new in 2004! Have nothing but great things to say about picture untill today! I have a color seperation with red, whatever line or...
This is problem of convergence output chips failure and it is fixable.
Replacement of convergence output chips on D board will solve tv problem, local tv repairman will do this job because convergence output chips replacement requires soldering work on circuit board.
Thanks.
Jan 01, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Hitachi 46f500 46 in problem double picture end two collor
This is symptom of convergence output chips failure in rear projection tv, replacement of convergence output chips will fix the problem.
Chips/ IC replacement requires soldering work in circuit board, if you are not familiar with electronics stuff fixing an soldering work, call local tv repairman to help you.
Thanks.
Oct 26, 2010 | Hitachi 46F500 46" Rear Projection...
Tv started ghosting in red green and blue
The tv is have a problems call convergence,it dead.U have all the tools like soldering iron,solder and desoldering pump.Know basic soldering?The convergence fuses FL231 three of them on the right side of FBT,a big block of plastic of a flyback transformer.Resoder the FBT,replaced the convergence fuse FL231 in the middle.The Ebay.com sell the convergence fuse.
Aug 25, 2010 | RCA HD52W59 HDTV Projection Television
Free 2-3 year old rca prjctn tv needing convrgnc chip
I had this problem with my Proj. tv also it cost me $135. to have the convergence chip replaced. i would call a tv tech. to get the true cost.
Sep 19, 2009 | RCA P46920BL 46" Rear Projection...
Picture flickers in and out rapidly,gets blurry for about 5sec then looks like new for about 5sec then back again
Did you replaced 2 IC convergence as well or just 2 resitors 3.9 ohms ? if you did replaced 2 IC then you might have probelm in convergence drive it is1 of the PCB mount vertical on the left side from the rear view under part BP95-00415C you need to readjust the convergence by using your remote control just follow in the servive manual
Nov 22, 2008 | Samsung HC-P4752W 47" Rear Projection...
Toshiba projection TV Flickers
You may have bad convergence chips in the set. I have worked on some with similar problems and replacing the convergence chips was the solution. Good luck and I hope this has helped.
Ed
NC Electronic
Mills, Wyoming
Feb 18, 2008 | Toshiba 55H70 55" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
52 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
