Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Ice maker will not make ice. Red light blinks
Ice maker will not make ice. Red light blinks when door is open.
  • 4 Answers
I have a kitchenaid with the same problem. Red light blinks twice when open is normal. Hold the flap down and the red light will be on.= normal= optics are working. If the ice rakes rotate, module is probably fine. Check the simplest solutions first, defrost the freezer in case the icemaker water nozzel might be frozen. That solved my problem. I then increased my freezer temp by a couple of degrees and so far, no problems.
Good luck.
Posted on Jan 31, 2010
Ice maker on/off light?
ice bucket full and/or door open so ice maker does not dump ice when you have door open.
Apr 04, 2014 | Refrigerators
The ice maker has stopped making ice. The red light is flashing (in the freezer. Part ot technician?
Hi, The blinking red light is just a sensor that shuts down the ice maker when the door is open so that it will not dump. This should have no effect on why the ice maker is not working unless the little door that blocks the beam does not return when the door is shut again...
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Oct 02, 2010 | Whirlpool Refrigerators
Blinking light in refrigerator
I think that's the light letting you know the door is open so it won't drop ice. When I held in the catch on the left side (as if the door was closed) the red light went off for me.
-Drew
Jun 21, 2009 | KitchenAid KSCS25FKSS Side by Side...
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
Red light on ice maker blinking twice, no ice.
I would assume you are referring to the ice level sensor that is on the center divider. It is normal for it to blink if the door is open. You can test out this theory by holding the flap on the left side closed but not blocking the sensor. The light should go steady. If the ice maker is not working then you either need to change the lazer sensor or the ice maker itself.
Feb 01, 2009 | KitchenAid KSRG25FK Side by Side...
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid KSCS25 Refrigerator Ice Maker Inop
you should not be able to push the stripper at all so that tells me that the gear on the icemaker module is bad. get part number 8201515 and you should be fixed up.
Jan 06, 2008 | Refrigerators
Optical sensor or valve problem
Your ice maker has an automatic shutoff. The ice maker sensor passes a beam from one freezer wall to the other, automatically stopping ice production when the storage bin is full. When you open the freezer door, you should see a red light on the top right freezer wall.When the freezer door is open or the ice storage bin is removed, the sensor cover or "flipper door" on the left wall of the freezer stops the ice maker from producing ice by blocking this sensor, When the beam is blocked, the red light on the right will blink twice. This is normal operation. as for the blink twice and pause I'm still checking on that. Make sure the water flow is coming from the solenoid valve located on back and bottom of refrigerator to the ice maker. Check the solenoid to see if the magnetic field is pulling the internal plunger open when ice maker ask for water. That can be checked with a multi meter at the wireing going to the solenoid and if the ice optics are telling the tray to fill voltage should be present. Insure that water supply is not restricted before it comes to the solenoid , like a bent line or clogged piercing valve.  Check that an ice cube is not jammed in the ejector arm of the ice maker. Remove jammed ice from the ejector arm using only a plastic utensil so the ice maker is not damaged. Call toll free in USA and a trained consultant will be happy to assist you. 1-866-698-2538
Oct 22, 2007 | Whirlpool GC5SHEXN Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
1,380 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
