Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
KENMORE HE3T BASKET RUBBING ON THE PLASTIC FRONT TUB
THE BASKET IS RUBBING ON THE PLASTIC FRONT TUB AND TEARING IT UP.
HOW DO YOU REPAIR THIS AND HOW MUCH SHOULD IT COST ? SHOULD I JUST BUY A NEW WASHER ?
  • fixitathome Apr 11, 2008
    I have the same problem, no gray seal damage, just the plastic tub getting ripped up. Had the Sears repair guy out who claimed that "something left in a pocket" probably got caught in there and started ripping things up. Didn't even open things up to look or check if anything else was wrong--like a shock absorber. Told me I needed to have both halves of the plastic tub replaced and the stainless drum, since it was probably damaged also, and it should be replaced so it wouldn't damage the new tub. $1700 to repair. I personally think something like the bearings went bad, and the drum does not spin true, and it is tearing things up.
    President:
  • Kenmore Master
  • 2,651 Answers
If ripped obvioussly youl need to replace the front rubber bellow, i would remove the bottom panel and have a look inside sounds like you have a broken shock aborber or 2 not properly supporting tub assy
Posted on Feb 28, 2008
Basket rubs on door boot seal.
Be sure both lower and upper halves are correctly connect together
May 01, 2017 | Frigidaire Washing Machines
During the spin cycle basket vibrates very badly - very rough
I had a similar problem. During the final high spin and there was POW and the drum went funky eating into the plastic. I opened the back of the washer and look things over,.The belt for spinning was intact. I set the washer on a drain/spin option and watched from the front and back. While watching the pulley on the drum and could tell there was a hiccup as it went around. I pulled the pulley off and put on a new pulley. The new pulley was going in a perfect circle to spin the drum. It's not a hard repair, just need a little muscle to loosen the nut holding the pulley on and the same muscle to tighten the nut as much as possible. Hope this helps.
Nov 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
I have a Kenmore Elite HE3 that has plastic pieces breaking off and falling into the washer. It is coming from a part that is inside the front door gasket and it loks like the tub is supposed to ride on...
I can't solve the problem, but my HE3 42824 has done the exact same thing...the kenmore subcontractor repair people have been less than helpful and want to charge 180 just to come out and service it. We were told on the phone that it MAY be the plastic tub, and it MAY be covered under warranty. After waiting 5 days for a maintenance appointment, only to have them cancel it for 5 days, we had enough...I we bought a Samsung last night! I don't think the Kenmore cleans well, anyhow, and it adds a bit of a musty smell to my clothes, so I am glad to be rid of it!
Nov 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Front Load Washer Drive Belt Keeps rubbing up against Tub
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 05, 2009 | Kenmore Elite 45986 Front Load Washer
Worn out front rim of plastic tub surrounding stainless basket
well not sure about yours but some front load washers have a five year warranty on the tub but you have to pay the labor which is between 100-150dollars
Dec 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite ET3
The plastic casing (tub shell) around the stainless spin basket should not become worn unless the spin basket is hitting the outer shell. From my past experience, this is usually caused by a cracked or broken spin basket support (spider) arm on the back of the spin basket, or a shot tub bearing (which is also behind the spin basket). The bearing is actually part of the rear tub shell and is molded into the plastic. It cannot be replaced separately and requires the replacmeent of the shell.
If the spin basket supports become broken, the basket becomes off balance and rubs against the outer shell. This results in excessive vibration, which may be the reason why the support shocks were broken. No...this is not normally expected. Unfortnately, this is not a simple or inexpensive repair, either. If you have a service plan, or warranty coverage, I would recommend pursuing that as a repair option. If you wish to repair this yourself, I can post a link for you to follow, but it is expensive. This will usually require the replacement of the following parts:
Spin Basket
Rear Tub Shell (if bearing is bad)
Front Tub Shell (if spin basket caused significant damage)
Support Shocks (I would recommend replacing all 4)
Optional:
Drive Belt Pulley (can become warped or bent)
Drive Belt (if showing signs of wear)
Rubber Door Bellow (if vibration as caused damage to the rubber)
You can go to searspartsdirect.com and type in your model number to get prices for everything if you like. Everything can be found under the "Tub and Basket Parts" heading, with the exception of the rubber door bellow. It can be located under the "Door and Latch Parts" heading.
I know none of this sounds like positive news, but I do hope you find some of this information helpful. Let me know if you need further assistance.
Aug 20, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3T door seal tear
tear may be from pulling something across it with sharp edges..to replace seall not major job front part of seal held in place with spring ..remove and pull boot away from front edge inlet tub slides out of boot opening rear held in place with LARGE screw clamp a little patience is usually all that's needed ..did 2 today
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3t water fills by itself! with door open too! doesnt always drain fully
If you tip the machine back at an angle, you should see a clear plastic sausage shaped thing with a plastic tube coming from it, you will need to remove the plastic thig (pressure vessl) and clean it out.
Nov 30, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Frigidaire front loader washer
one of the welds on your inner stainless steal tub may have broke causing the drop of your tub.  The tub has a warranty on it but the labor to put it in is around 3hrs give or take any hour.
Oct 23, 2007 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
351 people viewed this question
Sal De
fordexpert
Robert Rankin
