Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
I never set a password for my Belkin wire less router how do i do this?
  • 2,260 Answers
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Click Here for step by step instructions
Posted on Jan 30, 2010
How to reset belkin router password
To reset the Belkin back to the defaultsettings -
Press and hold the pinhole RESET button at the back of the router and thenpower for at least 15 secs. Then release the RESET button.
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open abrowser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter)You can now change the default admin password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
May 19, 2012 | Belkin F5D7234-4 Router
I forgot my password for my Belkin Router. How can I obtain my password?
Unless someone can tell you what it is, then you can't.
But there is a small reset button on the back, push this in for about 30sec (may be less, haven't done it in a while), you'll need a pencil or something to get at it. Once done you'll have to set up your router again.
Nov 26, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cant gain access to change settings on my router Belkin N1+
hardwire any computer to one of the wired ports in the router...
type 192.168.2.1 in any web browser and log in to router setup utility manually....
password....leave it blank and click submit..
now you can configure settings manually....
Apr 20, 2010 | Belkin N1 Vision Wireless Router
How do you extend the range of a Belkin N1 Vision router?
First connect your router to computer with ethenret cable.
Then you can access it with
http://192.168.15.1
If your rrouter is not access with this link then type in run "ipconfig /all"
then you get all adresese.
Gateway is ip adreese of yourt router so access it with those ip.
Type user name as "admin" and password as "blank or "admin" or "password"
then go to wi fi advanmced menu then change channel type 4,6 and 11
Try these 3 channel type 1 by 1 those give best result.
Set channel which give best result.
MAke sure when you set any settings in restart don't foget to save settings and restaret router .
Let me know if you need more assistanse.
Thanks.
Aug 27, 2009 | Belkin N1 Vision Router
Belkin wireless router reset password problems
You have to connect(wired) through one of the ports on the back of belkin to a laptop(or PC) physically.And this laptop(orPC) should have the software that came in the CD as part of the router packaging.
Then you open the web browser and and type http://192.168.1.1 on the address bar.This should let you access the router from where you can configure your settings..Network name,password,password for the router itself etc.
HTH
Aug 12, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Does a belkin n1 w/less modem router need to be wired to a pc before i connect my airport only mac
hi,
there is no need to connect the router to pc if u know the w/l settings means the ssid (network name) and security password or key if any. U can connect the pc to router to double check that thru wired u can go online.
thanx and regards
sukhiii
Jul 26, 2009 | Computers & Internet
Setting up a w.less repeater using an old w.less b.band router
Temporarily plug in wire network cable into Dell and log into Dell.
1. Set wireless up the same as the Belkin. Save these settings.
2. Set WAN to "Static IP Address and give it an address about 25 higher than Belkin. (Belkin 192.169.0.1 - Del 192.168.0.26). Save these settings.
3. Disable DHCP and Save these settings.
Exit web browser and disconnect network cable. Restart your complete system, first the Belkin, then the Dell, then your computers.
This way, the Belkin is running and able to assign IP addresses to all that start after it.
Jun 11, 2009 | Dell TrueMobile 2300 Wireless Broadband...
We have purchased a new notebook{higrade brand vista OS} to replace a packard bell using XP the XP laptop connected no problem the newone finds the belkin router but won't connect to the internet are...
Do you have a wireless security protocol enabled, and if so, what? Install a wired connection to the router (use an ehternet cable to connect your laptop's RJ-45--looks like a wide phone plug--into one of the Belkin router's network jacks). Go to the router's management page using your web browser (probably http://192.168.2.1). If you have not previously set the password in your router, simply leave the password field blank and CLICK "Submit". If you have previously password protected your Belkin router, use the known password. If you have forgotten your password... you'll need to reset your router.
Reest Router: there is usually a small hole into whiuch a pin or paper clip can be inserted for this purpose or a small button to press. Most Belkins--IIRC--have the button.
Once you are on the Belkin router's management page, look for the wireless link and set your security protocol to match what your wireless card is capable of, set the password, save and exit. Use the sasme password in configuring wireless networking in Windows.
Jul 17, 2008 | Belkin Computers & Internet
Yeah hey...belkin wireless router password reset
What is the brand of the router your using? This information will be from the router that you have. Use a wired connection from the router,check your default gateway (ipconfig) and type that numbers in your address bar. You will be able to access your set-up page, look for wireless tab and look for wireless security. You will see there your WEP key.
Jun 26, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Password protection
s u can login to ur belkin router like connect a pc through hard wired >and login to router screen>and go to wire less settings>and u can see security under w/l> go to there>and select WEP and under phaseprace type any 10 digit no as password which u can easyly remember one>and save it>and reboot the laptop>and login to ur w/l n/w and it will ask for password>rate me if its help full thx...
Oct 24, 2007 | Belkin (F5D7231-4) Wireless Router
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
160 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
