Question about KitchenAid Food Mixers
I caught a spoon in my kitchen aid stand mixer. The mixer will not turn, and oil leaked out of the side
    New Friend:
  • 87 Answers
It sounds like you have lost some teeth from your worm gear. This usually happens when the mixer has been overloaded. The teeth on the worm gear are designed to fail first to prevent more serious damage. To replace the part you will need to open the head on your mixer. The gears are at the front of the mixer packed in grease. It should be obvious that the worm gear has broken once the head is open. If it is not the worm gear, with the head open it should be easy to spot the problem. The gears are available as spare parts from several places on the internet. search for "kitchenaid worm gear".
When you replace the worm gear, you should be able to see if you need more grease. This will have been the "oil" you saw escaping.
Posted on Feb 01, 2010
Kitchen Aid Classic Stand Mixer beater stops when it touches anything.
Very much the symptom of a worm (follower) gear needing replacement. Three are videos of this posted on the net and you can find the Service Manual at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Jun 09, 2013 | KitchenAid K45SS Classic Stand Mixer
I have kitchen aid stand mixer and i can't get the beater to attach because the button is stuck??
The button doesn't move. You must push the beater up beyond th notch and turn it while pushing up.
Jan 14, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
Oil leaked when inadvertently stored on its side. what kind of oil do i need and where do i get it? thanks brian
gear grease is kitchen aid specific; sold by the can though a KA part supplier. while you're at it, replace the gear housing gasket as well.
Aug 24, 2010 | KitchenAid K45SS Classic Stand Mixer
Turned over and oil leaked out. Not sure how to replace and with what type of oil. Thank you.
There should be no oil. It is probably grease that has leaked due to a gasket not sealed tight. Go to Mendingshed.com and if you type in Kitchen Aid Mixer you can find a manual that shows what type of grease.
Nov 10, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Mechanical burning smell on kitchen aid stand mixer
i think its time to retire it its has had a good run time to put it to rest and buy a new on it don't sound safe to use anymore
Sep 21, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
Leaking oil from the main part. Kitchen aid mixer, only used a few times a year
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Jul 09, 2009 | Food Mixers
Food made with KitchenAid Stand mixer tastes like grease
The likelyhood of grease coming from the mixer is extremely small. As long as the beater & bowl were washed first and the shortening you used was fresh, there shouldn't be a grease taste.
Feb 17, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen aid mixer leaking yellow oil is it repairable it still tu
It can be. This may require replaing the plate that the shaft comes through, since there is now enough play to allow the grease that is in the nead to leak through. You can find the parts online, but be ware, it involves tapping out pins and undoing many screws. Manuals are available online at Kitchenaid.com
Jan 24, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
Leaking oil at the base
A TV show "How it is made" was in the Kitchen Aid factory and they used a thick grease and no oil in the mixer. Does your unit get hot? Maybe its melting the grease (dark brown)..
Oct 25, 2008 | KitchenAid KP2671 Professional 6 Series...
Food Mixers Logo
163 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
