Question about Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
Purchased generator last year, used one time and it will not start.
  • 714 Answers
Will not start.
Running it only one time Is the problem.
RECOMENDATION:
-Remove soak and clean high-speed jet in Carburetor and clean float valve in Carburetor.
-Do not use fuel with ethanol.
-Use a fuel inhibitor with your fuel. this will keep the fuel from braking down.
-When your done running the Gen-Set for the season fill tank and treat it with a fuel stabiliser and turn off fuel valve and let the gen set run out of fuel. This will ensure that fuel is not going to evaporate in the carburetor.
Hope this tip helps.
R/
David
Posted on Jan 31, 2010
Onan JB 7.5 KW with Transfer panel battery trickler lasted 10 years on deep cycle now only 2 years?
[PDF]Onan Master Service Manual.pdf
michaelstractors.com/forum/.../Onan%20Master%20Service%20Manual....
Jun 28, 1978 - rated at seventeen and one half (17.5) kilowatts or less. ... of an Onanengine generator set, automatic transfer switch, running time meter and .
Oct 12, 2015 | Electrical Supplies
I have a 16kW Generac Guardian Generator with a 200 amp house service RTS panel (installed 2007). Last night the power went out and the generator started but the unit did not switch to use generator
The problem with the repair service is another matter. Emergency generator and it's switch gear are there for emergency purposes. It has to be exercised periodically. The switch gear should have a toggle switch to simulate a power outage. the switch cuts power to the sensor sensing power from the utility company. This tells the switch gear that power was lost, start the engine and switch over to generator power. Run for a period where engine reached running temperature and switch back to stand by to shut down. Do this periodically, and be grateful the event was not a disaster. Think of your back up electrical system as the spare tire of your car and similar equipment and enjoy your investment. Good people brings you happiness, bad people brings you experience !.
Nov 11, 2014 | Generac Guardian Electrical Supplies
Model EG5000, one year old;last fire up in March, now it doesn't start. Has fresh gasoline
i'm sure you primed it - or go get a can of ether spray in carburetor
Oct 28, 2012 | Honda EG5000 Generator
I have a 2003 dodge durango, it has 119,000 miles and I noticed that when I stop at a signal light or just stop vehicle, sometimes it just cuts off. I purchased vehicle used.
Greetings:
What engine does your Durango have? Your tune up interval for spark plugs is every 30K. When was the last time that was done?
The 2003 was the last year of the Generation 1 Durango, and is considered the best of the 98-03 years.
Aug 04, 2011 | 2003 Dodge Durango
My Yamaha Ef2400iS inverter shuts off when I use my 3/8th electric drill. This problem started last fall. I could use the drill and portable saw, not at the same time, since the inverter was new three...
yes, the problem is that electronic/electrical components age with use. especially voltage regulators and switching transistors. as they age they can no longer sustain the current you are demandiing from the unit. the units are designed to run in the middle zone, not at full maximum load all the time, if you do that you will weat it out quicker. Always buy a power supply that is double your intended wattage and it will last many years. Hope this answers your question
Mar 21, 2011 | RTO New Yamaha Inverter Ef2400is / Yamaha...
My son purchased this generator about a year and half ago and has used it very little. during a power outage we got it out and used it for a day and the circut board went out. shouldnt it have lasted...
That sux! Thats NOT acceptable in any way... Take it back and demand it gets repaired.. With devices such as this it is not the simple passing of time that ages it, but the actual POWER ON time... & Yes if Overloaded it should simply have "Tripped" a breaker or the like.
Feb 02, 2010 | Coleman Powermate Premium Plus 6250W...
I purchased an acer aspire one with qvc last year in dec the
Hello, Adonis.
Depending on its use, a battery lasting 2.5 hours after one year is not terrible. Over time, the battery loses power.
If the battery were totally dead in less that one year, I'd suggest contacting Acer, since it's still under warranty.
Hope this helps.
Oct 17, 2009 | Acer Computers & Internet
Need a battery for honda eu3000is
New battery for Honda eu3000is can be found on amazon. take a look here Charge your devices with guaranteed safety and chose the best one. P.S. watch out on seller reviews. I hope this was helpful. cheers
Mar 28, 2009 | Honda 3000 Watt Portable Generator
Coleman 6200 won't work
Hi Judy,
Generators DO last a good long time for the money, but they have to be both used and maintained in order to keep working properly. What has most likely happened is that you didn't use the generator at all for a year, after it sat on your dealers shelf for a few months not being used, and so the tiny bit of magnetism it uses to "kickstart" the process of making electricity has worn down. The good news is that this is easy for a generator shop to repair, no parts involved and the minimum labor that they charge. They need to do something called flashing the field of the generator. What they can't do is get Coleman to pay for it since they aren't around anymore, go ahead try the 800 number (waits patiently).
Be nice to the poor generator techs at the shop.
Nov 24, 2008 | Coleman Powermate Premium Plus 6250W...
Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241 Logo
174 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
