Question about Denon RC-H800 Remote Control
Buttons won't work it seems it doesn't send the signal to the receiver.I got new battries but still won;t work
    Scholar:
  • 106 Answers
Try to check the remote Model matches the Receiver's model number. If it does not, then try to get Universal Remote Controller
Posted on Jan 30, 2010
Sennheiser ew g2 bodypack with shure u2 receiver compatibility: When I tune the frequencies similar to each other, the U 2 gets an RF-Signal, but it doesn`t receive any audio-signal, when i talk into...
Sorry, that will not work. Typically, it is not possible to use one manufacturers transmitter with another manufacturers receiver. The two manufacturers use different tone-key squelch, different noise reduction, and different companding schemes.
Aug 09, 2013 | Shure U2 / 87 With SM-87 Professional...
Dell Inspiron 8500 won't shut down, on/off button doesn't repond
Hold down the ON/OFF button for several seconds until it shuts off.
Mar 04, 2013 | Dell Inspiron 8500 Notebook
Kenwood TK-3131 15-channel radio. I purchased a couple of these about a month ago and try worked fine. Turned them on recently and now one doesn't function as it should...it sends a signal when the mic...
By checking initially of your radio,insert your NEW FULLY CHARGE BATTERY,Switch On your radio,select the channel the same as your other working radio,and try it once more,
If you can not heard an alert sounds when you turn on the radio, and pressing any Button/key,probably you'll having a problem on the audio circuits/speaker,etc, if it is working before,
Thank you
Jan 30, 2013 | Radio Communications
The remote to my aircon doesn't seem to be sending a signal
If you get a mobile phone and select its camera, then look at the LED at the front of the remote thru the camera, press some keys on the remote unit and you should see the LED light up on the remote on the mobile phone camera screen (it picks up Infra Red which we can't see). this will let you know if the remote control is working. if it is, the receiver at the indoor unit is either covered with something, check thoroughly, or the receiver is faulted, replace via technician. Have fun Tim B TB Electrical
Nov 29, 2012 | Carrier Heating & Cooling
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
Uniden uh015sx won't receive or scan
FM Detector/demodulation issue. These radios have a problem in this department. I have had a few come through work that were on mine sites and no longer receive or scan. On the display it will show the signal bars fully lit as if there is a strong signal, but no RF is heard. The giveaway is being able to hear button press beeps and alike but no signal noise is ever heard.
If the unit is still under warranty send it back and have it repaired. If no longer under warranty, then it's spare parts.
Jul 28, 2012 | Radio Communications
MojogiMy GHD1621F2 freeview recorder is frozen on one programme, won't respond to the remote at all (have new batterys) and won't respond to buttons on front. Turning off and on doesn't work...
Hi mojogill,
It sounds like the receiver may be locked up. If the buttons on the front do not work, then try unplugging the receiver for 5 seconds and plug back in then check to see if everything is working fine.
If you need any further assistance with this, feel free to contact me at thomas.faust@dishnetwork.com. Thanks!
Tommy Faust
DISH Network
May 25, 2011 | DISH Network ViP722 DTV Receiver /...
My blackberry won't send or receive either texts or calls. But I can still do everything else like browse the web or send bbms..
This problem could be due to the lack of GPRS service. GPRS stands for General Packet Radio Service, and it's what allows your device to access data. The first thing you should do is perform a soft reset. If that doesn't work, perform a hard reset. After both resets, check your wireless antenna signal strength. The antenna should show GPRS. If you can still make phone calls and access the Web, then your GSM service is still available. Try sending yourself an email . Does it work? If it doesn't, call your BlackBerry provider. Sometimes, your service could be delayed due to a billing problem or to downtime on the network.
May 17, 2011 | RIM BlackBerry Pearl 8100
Hi, I have a Yamaha rx-v450 amp that won't change sound modes (stereo, hall, jazz, rock etc) from the remote control but it works from the buttons on the unit. I've checked my remote by pointing it...
Hi! Transmitting doesn't mean it's working, What you should do to test it is use a good quality universal remote such as a Logitech Harmony and first program the preset code for your receiver into the Universal Remote. If that works, you know your OEM remote has gone bad, at least for those buttons. If it doesn't then you you should attempt to have your Universal Remote "learn" the IR signals from your receiver's remote If the controls still don't work, there is a problem with either your IR receiver on your receiver or the the circuitry that proceesses the signals into commands. Good Luck!
May 11, 2011 | Yamaha RX-V450 Receiver
Doesn work at all
I've had the same problem. Get the technical assistance phone # out of the manual that came with the fan. They can give you the proper part # so that you can then call Home Depot and special order the receiver. However, I have done this and then installed the new receiver as advised by Hampton Bay and I still am unable to get the remote to operate the fan or the lights. I know the fan works becaue I bypassed the receiver and wired directly to house power. I don't know if perhaps I have a bad transmitter (remote). I'll try that next. The fan worked for about a year, now its just a headache.
Jan 30, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Denon RC-H800 Remote Control Logo
239 people viewed this question
Top Denon Televison & Video Experts
Jonathon summesfield
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
