Question about Panasonic KX-T7730 Corded Phone
Phone cords This morning my phone decided to stop working, there is no display or dial tone at all on the phone - no power, i unplugged the phone cord and plugged it back in and it made no difference, so i tried it at another phone point in the office, now that phone is doing the same thing, both lines are constantly lit up on all other phones!!!
  • 38 Answers
With the lines lit on the phone, it's indicating an off-hook condition or no battery from the line. Check the lines for dial tone at the demarc to determine if it's phone company problem. Thank you. Jer
Posted on Feb 25, 2008
I have a working phone line and my phone is connected correctly but I cannot get a dial tone.
I see you stated that another phone lights up,so you have power. But do you get a dial tone on the other phone. Power is only required for cordless phones. Most other phones do not need power to get dial tone.
if you have more than one phone outlet take a known working phone and the cord and plug it into the outlet where the one that is not working is. If this phone does not work, then you have a problem with the outlet.
If the phone does work,hook the phone that was not working to the same phone cord and plug into power if needed.
If the phone now has dial tone you have a bad phone cord.
If the phone is not working you have a bad phone. You can dpouble check by taking this phone to a known working outlet and connecting it there.
Apr 01, 2018 | Lands Phones
My phones are not working at says out of range.
When a cordless phone says "Out of Range" or "Searching for Signal", there are a number of possible issues (assuming you are close to the base). 1) The handset battery may be low and not taking a charge. If the battery is more than a year old (including time spent in storage), replace the batteries for both handsets.
2) The base may not have power or an incoming telephone line signal. Check that the power adapter is warm (power to the base). Use another phone cord (and a second phone (preferably corded) to check for a dial tone). If a second phone has no dial tone, see below for diagnosing a phone line.
3) The phone base has lost the registration information for the handsets. A way to reset the phone is to unplug the power cord (from both the wall outlet and the phone base) and the phone data line and unplug the batteries from all handsets. Wait several minutes then plug in the base power and data cords and then reconnect the phone batteries. You may want to re-register the handsets. This is done by putting the handset in the main charging base for 20 seconds when the handset is fully charged. (See your phone manual) The phone was made by Thomson Electronics for GE; the manual is available here: http://www.home-electronics.net/USER-GUIDES/25952_DOM_EN_CL_IB.pdf .
4) The phone base or handsets are not transmitting or receiving the signals properly. This means that the phone needs repair or replacement. If it is under warranty, contact the manufacturer. Otherwise decide if the phone is worth the repair costs.
If you have no dial tone at the jack where the base is connected, check another phone jack on that line. If you still have no dial tone, find where the phone service comes in. Then open the service box and if the service is fairly new, plug in the RJ-11 test phone and listen for a dial tone. If you can't plug in the phone cord or there is no dial tone, contact your service provider. They will test and fix any outside problem.
If the problem is inside, inspect the visible wires. If you have a DSL filter as part of the inside wiring, check/replace it. If only one jack has a problem, open the faceplate and fix any loose wires. There are two faceplate designs - screw terminals or keystone jacks. For the screw-type, the conductors must be stripped and secured under the screws. For the keystones, the conductors are not stripped but pressed into the terminals with a punch-down tool. This tool is available at many home improvement stores in the wiring aisle. See http://www.lanshack.com/wire_phone_jack.aspx for a diagram of the wiring.
If the problem is not in a visible part of your wiring, you may want a professional to find and fix the problem. Your telephone provider will be willing to do the work for a fee.
I hope this helps.
Jan 20, 2012 | GE 25952 Cordless Phone
Fax wont' go through. Plugged phone jack into phone line and when I try to fax it doesn't connect. Any suggestions? Thanks
Can you receive any faxes. Run a Fax Test from the Tools menu. Is the problem with only one fax receipient? (Check the phone number and make sure they are set to receive. I have dealt with one fax receipient where the call-waiting service caught the fax call.)
Does the Fax see a dial tone? If there is no dial tone, use a single line phone (corded) to listen for a dial tone at that jack. If there is no dial tone, check the incoming service for a dial tone. (If you have no dial tone at all, contact your service provider.) Try a new phone cable (2-wire RJ-11) Try calling the number from another phone line with the single line phone attached. If the phone doesn't ring with a new cable, check your wiring and then contact your provider. Is the signal analog or digital (the all-in-one is designed for digital)?
Go back through the fax settings and set it as directed in Step 2 here: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458259&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3643612 . You need the fax error reporting setting.
Disconnect any items that are plugged into the 2-Ext port.
Try reinitializing the unit. Unplug the power cord with the unit on. Make sure that the phone cord is fully seated in the 1-Line port. Then reconnect the power cord.
Try resetting the all-in-one, this may require 2 people. With the printer on, unplug the power cord and wait at least 20 seconds. Press and hold # and 3 while plugging in the power cord. Release the buttons after the unit starts up.
If none of these steps help the unit may need service.
Jun 27, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
No dial tone, cannot receive or phone out. Phone
First check to make sure that the phone line is working. Unplug the telephone cord from teh telephone (Do not unplug it from the wall as you will want to make sure the telephone cord is good also) Plug in another phone and see if it works, if it does the problem is the phone, if it doesnt the problem is either the telephone cord, or the wiring in the wall or the jack.
Jun 29, 2009 | Uniden 5.8GHz Dual Cordless Phone
One phone just stopped working
some DECT handsets have an internal fuse and please swap the batteries to check if both batteries are Ok
Nov 27, 2008 | Vtech Cordless 6041 Phone
Will not call out!!! 25204RE1
I just encountered this same problem on my phone. To resolve, you must hard reset the phone as follows: unplug power cord, unplug phone cord, remove all batteries. Leave disconnected in this state for at least 10 minutes. Now reconnect in following order: reinstalling batteries, reattach the phone cord followed by plugging in the power cord. This restores the phone to the original settings. You will lose items in memory, but the phone dial function should be restored. This was recommended by customer service and resolved my issue which sounds identical to yours. You can now proceed with resetting up your phone as desired.
Jun 10, 2008 | RCA 25414RE3 Corded Phone
Uniden Dect2080 with 5 cordless phones
phone appears to be on hold cannot get a dial tone on any of the phones what is the solution
Apr 05, 2008 | Uniden DECT 6.0 Cordless Telephone...
Panasonic KX-T7730 Corded Phone Logo
104 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
