I hooked my DVD player to my new HDTV and the DVD worked but everything was blue the people/trees/hourses and i tried several DVD's Ithen pulled the blue cable out and we were able to watch in black and white. Any suggestions?
  • 2 more comments
  • bsbjl Jan 30, 2010
    The Geek squad hooked up the DVD to the TV but never tested it. WE went to use it and the DVD player playes and works fine the color of everything is blue/gray in color. When I take the blue cable out of the connection on the TV the DVD plays in Black and white. The player itself works fine we were using it the past three days on our old Tv before the HDTV and Digital cable were installed. I changed the HMDI cable and had the same results. I used the old cable from the DVD player and went direct to the AV1 connection and had the same results. The TV works great colors are gereat HD is great. Is it possible that the DVD player is to old (5yrs) to work with digital and HDTV? I could takd DVD out but there's alot to that because of how it was installed into furniture ect. I can try a WI through the TV and see what happens same concept.
  • bsbjl Feb 01, 2010
    I hooked the DVD player backup to my old TV and it works fine
  • TragicManner May 11, 2010
    Wow, this is indeed a strange issue. Especially because you have the same results going over AV1. Since you're saying the TV works fine with other things like HD TV, I am starting to lean towards the DVD player being faulty. What likely happened is that the DVD player has gotten a little old and, in the move, something might have been bumped or the player may have just started to fail about the same time you brought in the new TV. Even though it is hard to get the DVD player unplugged (I know exactly what you mean, I have all my AV stuff routed through furniture as well) I think that's going to be the only way to find out what is going on for sure. If you unplug the DVD player and try it on a different HD TV somewhere, you will be able to verify if it is a TV problem or the DVD player's problem. If you find the DVD player is broken, then you can go ahead and replace it while it is all unplugged anyways, but if you find it is working fine, I would recommend that you contact Best Buy (I'm assuming you bought the TV there) or the TV manufacture to see if you can get it replaced. Unfortunately, in this kind of situation, it's a total pain to find out what's going on and to get everything working again.
    It sounds like you are using a component cable, and that there is either something wrong with the output on the DVD player, the input on the TV, or there is a problem with the cable itself. Can you take the DVD player to a friends house or to another TV and try it and see if you get the same results? Using the same cable and same DVD Player somewhere else causes the same problem, then you will know something is up with you TV, or how you hooked your TV up. Give that a try and let us know how it went.
    Scholar:
  • 106 Answers
Set HDTV Color settings to the Highest Quality level :)
Posted on Jan 30, 2010
Bought new sony bravio blue ray dvd player hooked to hdmi port changed inout to digital one then tried changing port and trying in digital 2. same symptom on both sound perfect but no picture of any kind....
There are three only three possibility's here, one there is a problem with the HDMI HOOK UP ON THE BACK OF THE TV, SECONDLY IT COULD BE THE DVD PLAYER IS NOT COMPATIBLE WITH THAT TV, AND LASTLY YOU MIGHT NEED TO HAVE THE TV SERVICED FOR SYSTEM ISSUES
Mar 06, 2011 | JVC HD-70G886 70" Rear Projection HDTV
Ihave a bose 321gsx, I want to hook up my hdtv . ,blue ray dvd and vcr. Brain is frozen right now. Could use some help.
How to Connect an HDTV to a DVD Player
Hooking up a DVD player to an HDTV, or high-definition TV, is just as simple as hooking one up to a standard-definition TV. While a regular DVD player may be hooked up to an HDTV, it does not necessarily mean it will have high-definition quality picture. Unless a Blu-Ray player is connected to the HDTV, only a standard-definition picture will be shown.
Things You'll Need:
* Component cables
Instructions
Turn off and unplug the HDTV set and the DVD player before attempting to connect component cables to them.
Match the red, green and blue colored cables to each of the color-coded counterparts on the back of the DVD player. Be sure the cables are being plugged into the TV-out section of the DVD player.
Plug the other end of the color coded cables into the HDTV set. There should only be a red, green and blue cable being plugged into the TV. It does not matter what input these cables are plugged in, but keep track of which particular one it is. Most HDTV sets will have more than one A/V input, which is why it's important to take note of where the component cables are located.
Power on the DVD player and the HDTV set. If not already plugged in, ensure both of these are properly plugged into an outlet.
Press the "Source" button using the HDTV remote and locate the input channel that has the component cables plugged into it. The HDTV set should now show the DVD player logo or an introduction to the DVD.
Do not purchase HDTV component cables to hook up a regular DVD player to an HDTV set. Unless using a Blu-Ray player, only standard component cables are required. HDTV sets consume a lot of energy and should be plugged directly into an electrical outlet rather than a power strip.
Turn off all electronics before connecting and disconnecting wires to reduce the chances of getting an electrical shock.
Ensure that you have the proper cables to hook up your new HDTV. Take inventory to see if you have an ANT-IN, DVI-D/HDCP IN, Video In or Component Video In cables. The placement of these plugs will be indicated in your user book.
Begin by connecting the coaxial cable to the back of your cable box. Run a video cable to the TV; an S-Video cable may be used as well if you do not have any other video cables.
Locate a digital audio cable, or analog audio cable. Connect the audio cable to the TV from the cable box.
Now connect all other components including DVDs, VCRs or LaserDISC players. Try using all digital audio and digital video connections for the most complete HDTV experience.
Use a splitter to connect multiple components such as cable box to DVD or TV to VCR to avoid running out of chords. Calibrate your HDTV before enjoying fully, adjust the brightness, contrast and color settings.
Tips & Warnings
You can utilize a program to help with proper calibration of your HDTV system; these instructional videos can be purchased from many electronic stores.
You can opt for the store from which you purchased your HDTV to hook up the system for you. They will often calibrate the system for you as well.
Hope it helped.
Have a nice day...
Feb 26, 2011 | Bose 3 2 1 GSX System
I'M TRYING TO HOOK UP MY INSIGNIA 42'' 1080P FLAT-PANEL LCD HDTV TO OUR DVD PLAYER USING THE COMPONENTS (RED, BLUE, GREEN, RED & WHITE CABLES) PROVIDED AND THE PICTURE IS IN BLACK & WHITE....
The three picture cords (red/blue/green) often are a little larger around than the sound cords (red/white). If they are they same size, they are often grouped separate by picture and sound. Double check to verify if you have the "red" cords correct. Good luck.
Jan 20, 2011 | Insignia 42" LCD Flat-Panel HDTV
No owners manual can't get new blue ray dvd player to work on tv
Here is the manual:
http://www.hdtvsolutions.com/pdf/JVG%20HD52G56G.pdf
When using the HDMI connections you may have to tell the DVD to output to that port.  Also you may have to connect additional sound cables from the DVD output to the TV.
Jun 02, 2009 | JVC HD-52G786 52" Rear Projection HDTV
When the DVD is inserted, an error appears
have you tried or have you been using a laser lens cleaning disc ?
if not then the glass lens will need to be manually cleaned with a q-tip and lens cleaning solution
Feb 19, 2009 | Philips Magnavox DVD/VCR Dual Player
Novice installing HDTV(Samsung),DVD(Sony) no pic on TV
Purchased a newer HDMI DVD player,(Sony)as well as found that I do need the video cables.Also found that I need to change the input to component on the DVD player by using a regular coxial to at least get a display from the DVD player had I kept the older one.
Oct 08, 2008 | Televison & Video
Nintendo 64 HDTV
I am not an HDTV expert but I believe they are all backwards compatible so the fact it is HD should not be a problem. Have you tried a vcr or dvd player on the same hook ups? It is possible you are trying to use a video input that is already in use? I know on my TV I have the DVD hooked up with an S-video cable to "Video 2". Right next to the S-video hookup are the red, yellow, white RCA jacks. On my TV these can't be used when the S-video is in use so I have to have the games hooked up to the front panel "Video 3". I would disconnect everything and try hooking the N64 up in each input to see if you can find one that works.
Mar 02, 2008 | Nintendo 64 Console
DVD movies do not play
A blue screen means the TV is not receiving a video signal. Check all connections, then try another player, cable, etc. Also, check DVD and TV AV settings.
Dec 10, 2007 | Pioneer VSX-D912 Receiver
I put the disc in the player ithen tries to play then it says disc not valid .
Same here!!! We've only used it maybe 8 or 9 times. And it's been worthless for the past month because of it. It reads everything "no valid disk" and nothing will work. And I tried e-mailing customer support several times, with no luck.
Nov 21, 2007 | Durabrand DUR7 Portable DVD Player
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
