Question about McCulloch Garden
I have a McCulloch 3516, The oiler isnt pumping. The screen is clean and free of dirt in the resevoir but the saw isnt pumping out any oil?/ How can I toubleshoot/ fix this problem?
    President:
  • 2,220 Answers
Your basic model number is 600035. There are 11-, 21-, and 22- prefixes used with 600035s. There are also a ton of suffixes with the 600035s. I think the suffix is on your saw immediately after the basic model number somewhere (usually on bottom of older Macs along with the serial number. The dash of the serial on older Macs is the prefix). I must defer to you to find your exact IPL, here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
I chose this one as an example "22-600035-58" for an IPL
http://www.ordertree.com/modelinfo/MCC/22-600035-58-Mac-3516-IPL-211229-01/139.22-600035-58-Mac-3516-IPL-211229-01.1.59.1.html
The "Powerhead Assembly" lists an oil pump (1) and a worm gear (10). These are the most common failure on most saws but Macs have many more hoses than most. There are oiler components on at least 2 different details. It sounds as though you have done most of 1. Continue with 2. It appears the oil pump is on the starter side of the engine. and you may need to remove the fly wheel for access. I would examine every connection and perhaps try the "Kit Gear/Plunger Assembly" before trying to access the oil pump and gear.
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
Please see the IPL to aid in oiler component identification. Good luck with your project
You can reply below with any questions. I hope you found this most helpful.
Lou
Posted on Jan 31, 2010
How do you get to the oil filter and how do you clean it and change it.
How to clean the chainsaw's air filter - YouTube
? 3:11
https://www.youtube.com/watch?v=wozSufvtbfE
May 30, 2012 - Uploaded by iScaper1
Tips for removing and cleaning the air filter on a Stihl MS250chainsaw. ... A very dirty air cleaner, a little maintenance can help them live longer ... Poulan Chainsaw Review- Should youbuy one? ... chainsawbars.co.uk - cleaning the air filter andchanging spark plug ... Get video URL at current time.
Mac 3200 chainsaw oil tank repair - YouTube
? 3:21
https://www.youtube.com/watch?v=XXlm-o8sD6A
Jul 17, 2012 - Uploaded by conan6868
Repairing oil tank. ... Could You Fix This Mini Mac Chain Saw! ...The chainsaw guy takes the McCulloch Mini Mac ChainsawChallenge 9 23.
Mucculloch 3516 chain saw assembly - YouTube? 49:25https://www.youtube.com/watch?v=Xm4YL3pDG8cJan 20, 2014 - Uploaded by Dragracer64In this video I take a box of dirty chain saw parts that has been sitting in my attic for about 12 ... Is there supposed to be a filteron the line in the chain oil tank? .... How to replace MCCULLOCH chainsaw MAC 3516 fuel line.How to replace MCCULLOCH chainsaw MAC 3516 fuel line ...? 1:32https://www.youtube.com/watch?v=GMjXYKza-NYJan 13, 2013 - Uploaded by Lambda ITCMCCULLOCH chain saw MAC 3516 chainsaw fuel line replacement. Three fuel lines. 1) First line in the tank ...
Dec 27, 2015 | McCulloch Garden
How to adjust oiler on mcculloch timber bear
some saws dont have oiler adjustments and if it worked before it dont need adjusting some things you need to check are you using the correct viscosity of oil have you checked the chain bar is clean and free of sawdust and dirt especially where oil enters the bar. after you reassemble ,start the saw and hold it 2 inches from the ground and rev the engine up and down several times watch for oil sling before you cut wood if you have trouble after all this try motor oil instead of bar oil
Feb 12, 2015 | McCulloch Garden
Chain oiling
yuo need to remove chain and bar.then remove clutch,remove flat plate covering oiler. NOTE:some saws requier a special tool to remove clutch left handed threads inspect oiler .sometimes the sawdust and dirt can be cleaned out and it will start workin again. and sometimes not
Oct 25, 2012 | McCulloch Garden
McCulloch EB428 chainsaw and the auto oiler won't work
Good on you for what attempted already. I looked at the print and it appears there is a worm gear (item 50) and a driven pump (item 61) behind the clutch. I suspect one of the 2 has failed. I know you have done most of this already But does it ooze with the bar off?
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
A link to the only IPL for a McCulloch EB428 follows:
http://www.ordertree.com/modelinfo/MCC/EB428-Chainsaw/139.EB428-Chainsaw.1.59.1.html
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Apr 30, 2010 | McCulloch Garden
Oil pouring out of mac3516,chain oiler
You have my condolences.
Your saw is here, which one?
Chainsaws 32cc-35cc-38cc Anti-Vibe
I chose "22-600035-18" as an example , it follows (more detailed print - may not be your saw):
http://www.ordertree.com/modelinfo/MCC/22-600035-18-Mac-3516-IPL-211318-01/139.22-600035-18-Mac-3516-IPL-211318-01.1.59.1.html
On this block of saws the oil pump is under the flywheel and there are many hoses. Please use the IPL to identify and locate oiler parts. I hope you find a burst hose. There are oil pump repair kits listed. Unless the pump has an obvious crack or hole I would not attempt to change it until I had exhausted all other possibilities.
This works for older MCs but MTD (this one) saws often deviate from the explanation. It will give you a little guidance if you try to locate a different IPL.
http://www.fixya.com/support/r3558917-mcculloch_chain_saw_ipl_illustrated_par
The IPL (exploded parts list) for your saw is the only detail for the oil system is sketchy at best. Oiler components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
McCulloch IPLs (all)
I know it is not plugged but this may also be helpful.
Oil System Plugged:
These are very difficult to work on, most saw shops will not attempt a repair. I hope the chainsaw Gods smile on your undertaking. Good Luck. If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa HTH
Lou
Mar 22, 2010 | McCulloch Garden
Chain not getting oil
Extremely difficult! If the oil pump or worm gear is defective it may be the most difficult saw to repair. This is the only saw I have seen with the oiler mounted behind the fly wheel.
McCulloch IPLs
The "Powerhead Assembly" lists an oil pump (1) and a worm gear (10). These are the most common failure on most saws but Macs have many more hoses than most. There are oiler components on at least 2 different details. It appears the oil pump is on the starter side of the engine. and you may need to remove the fly wheel for access. I would examine every connection and perhaps try the "Kit Gear/Plunger Assembly" before trying to access the oil pump and gear.
Oil System Plugged.
  2. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear. Please see the IPL to aid in oiler component identification.
You can reply below with any questions. I hope you found this most helpful. Good Luck
Lou
If you opt to remove the fly wheel PLEASE reply to me first. I can probably save you a couple of headaches and may prevent component breakage.
Feb 01, 2010 | McCulloch Garden
Hi i got a mcculloch chainsaw and the oil isnt releasing onto the chain, what do i need to do
Oil System Plugged.
Most McCullochs have an impulse driven oil system. If it does not oil on completion of 1 it is most often a defective or disconnected hose. If you provide a model and serial number I can usually find the IPL to aid in oiler component identification. HTH
Lou
Jan 23, 2010 | McCulloch Garden
Mcculloch 14" chainsaw no oil at chain??
Oil System Plugged.
If it does not oil on completion of 1 on a McCulloch it is most often a plugged or disconnected hose.
There are in excess of 230 different McCulloch chainsaws. Oilers are often specific to one model. Please reply below with the model and serial number of yours so I can provide a more complete answer and an IPL. HTH
Lou
Jan 22, 2010 | McCulloch Garden
Where could i get an oil pump for the chain.
Sorry Lynda
I did not want to close this until you had replied. A clarification will still post (below), I will check for your input.
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear. Please see the IPL to aid in oiler component identification. HTH
Lou
No clutch but I need the model, serial, and whether European to help further.
Jan 04, 2010 | McCulloch 10" Electric Pole / Chain Saw
Garden Logo
948 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
